AP-CON Aluminum Solid Electrolytic Capacitor
AR5K Series Long Life
Ratted voltage: 2.5~25Vdc
Endurance 5000hrs at 105℃
Suitable for DC-DC converters, voltage regulators and decoupling applications
RoHS Compliant
Specification
Category Temperature Range -55 to 105℃
Rated Capacitance Range
10 to 1000 (μF)
Rated Voltage Range
2.5 to 25Vdc
Capacitance Tolerance
±20% (M)
Surge Voltage
Rated voltage X 1.15 (at 105°C) Dissipation Factor
Leakage Current
Shall not exceed values shown in standard ratings.
0.1 max. (at 20°C 120Hz)
(at 20°C after 2 mins.)
105℃, 5000hrs, rated voltage applied
Appearance
No significant damage
Endurance
Capacitance Change
≦ ±20% of the initial value
DF(tanδ)
≦ 150% of the initial specified value
ESR
Leakage current
≦ The initial specified value
60℃, 90 to 95% RH, 1000hrs, no voltage applied
Appearance
Damp Heat (Steady State)
Capacitance Change
DF(tanδ)
ESR
Leakage current
1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a
protective resistor (R=1kΩ) and discharge for 5.5min.
Appearance
Surge Voltage
Capacitance Change
DF(tanδ)
ESR
Leakage current
Dimensions and Marking
Series
Date code
Polarity
marking (-)
Capacitance
Voltage
Product Specifications are subject to change without notice.
SIZE
Code
øD±0.5
max
L
α
ød±
0.05
F±0.4
04X5
05X8
06X5
06X8
08X8
08A2
10A2
4.0
5.0
6.3
6.3
8.0
8.0
10.0
5.0
8.0
5.0
8.0
8.0
11.5
11.5
1.0
1.0
1.0
1.0
1.0
1.5
1.5
0.45
0.50
0.45
0.60
0.60
0.60
0.60
1.5
2.0
2.5
2.5
3.5
3.5
5.0
Standard Ratings
ESR
Rated Ripple
Current
(mArms/ 105℃
/100kHz)
Part No.
4,180
4,180
5,000
5,000
6,100
6,100
2R5AR5K391M05X8C
2R5AR5K561M05X8C
2R5AR5K561M06X8C
2R5AR5K821M06X8C
2R5AR5K821M08X8C
2R5AR5K102M08X8C
WV/Vdc
(SV)
Cap
(μF)
Size
Code
Leakage
Current
(μA)
2.5
(2.9)
390
560
560
820
820
1000
05X8
05X8
06X8
06X8
08X8
08X8
500
500
500
500
500
500
(mΩmax/20
%, 100k
to300kHz)
7
7
7
7
7
7
3
(3.4)
820
06X8
500
7
5,000
3R0AR5K821M06X8C
4
(4.6)
560
06X8
500
7
5,000
4R0AR5K561M06X8C
6.3
(7.2)
100
470
470
560
560
820
820
06X5
06X8
08X8
06X8
08X8
06X8
08X8
126
592
592
705
705
1,033
1,033
35
8
8
8
8
8
8
2,100
4,700
5,700
4,700
5,700
4,700
5,700
6R3AR5K101M06X5C
6R3AR5K471M06X8C
6R3AR5K471M08X8C
6R3AR5K561M06X8C
6R3AR5K561M08X8C
6R3AR5K821M06X8C
6R3AR5K821M08X8C
10
(11.5)
10
04X5
300
80
700
100AR5K100M04X5C
100
06X5
320
24
2,490
160AR5K101M06X5C
100
270
270
270
330
470
1000
06X8
06X8
08X8
08A2
08X8
08A2
10A2
320
864
864
864
1,056
1,505
3,200
25
10
10
10
10
10
12
2,820
5,000
5,000
5,230
5,000
5,230
5,400
160AR5K101M06X8C
160AR5K271M06X8C
160AR5K271M08X8C
160AR5K271M08A2C
160AR5K331M08X8C
160AR5K471M08A2C
160AR5K102M10A2C
56
82
100
06X5
06X8
08A2
280
410
500
30
28
22
2,800
2,780
3,600
250AR5K560M06X5C
250AR5K820M06X8C
250AR5K101M08A2C
16
(18.4)
25
(28.8)
很抱歉,暂时无法提供与“6R3AR5K561M0609C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64811
- 50+0.52380
- 150+0.46160
- 500+0.40209
- 2500+0.36472
- 5000+0.34614
