RGA680M1VBK-0611
RGA680M1VBK-0611
    LELON(立隆电子)
    插件,D6.3xL11mm
    直插铝电解电容 AEC_D6.3X11MM_TM
RGA680M1VBK-0611 数据手册
Aluminum Electrolytic Capacitors RGA Features ‧ 105℃, for general purpose, standard series ‧ RoHS Compliance ‧ If there is any requirement on ESR, it’s suggested to use low ESR series instead of RGA. Please consult our contact window for any inquiry. Sleeve & Marking Color: Green & Black Black & White SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Leakage Current (at 20℃) Dissipation Factor (Tanδ at 120 Hz, 20℃) Low Temperature Characteristics (at 120Hz) Endurance Shelf Life Test Ripple Current & Frequency Multipliers Performance -40℃ ~ +105℃ ±20% Rated voltage ≦100V Time after 2 minutes (at 120Hz, 20℃) >100V after 5 minutes CV > 1,000 CV ≦ 1,000 I = 0.01CV or 3 (μ A) Leakage Current I = 0.03CV+15(μ A) I = 0.02CV+25(μ A) whichever is greater Where, C = rated capacitance in μF V = rated DC working voltage in V Rated Voltage 6.3 10 16 25 35 50 63 100 160 200 250 350 400 450 Tanδ(max) 0.23 0.20 0.16 0.14 0.12 0.10 0.09 0.08 0.12 0.14 0.17 0.20 0.25 0.25 When the capacitance exceeds 1,000μ F, 0.02 shall be added every 1,000μ F increase. Impedance ratio shall not exceed the values given in the table below. Rated Voltage 6.3 10 Z(-25℃) φD<16 4 3 Impedance /Z(+20℃) φD≧16 6 4 Z(-40℃) φD<16 8 Ratio 6 /Z(+20℃) φD≧16 12 10 16 3 4 6 8 25 2 3 4 8 35 2 3 4 8 50 2 3 3 8 63 100 160 200 250 350 400 450 2 2 3 6 8 12 14 16 3 3 3 3 4 8 10 16 18 20 6 6 Test Time 2,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000 hours at 105℃. Test Time 1,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors before the measurements for 160 ~ 450V (Refer to JIS C 5101-4 4.1). Freq.(Hz) Cap.(μ F) Under 100 100 < C ≦ 1,000 1,000 up above 60(50) 120 500 1k 10k up 0.70 0.75 0.80 1.00 1.00 1.00 1.30 1.20 1.10 1.40 1.30 1.12 1.50 1.35 1.15 2011 Verison Aluminum Electrolytic Capacitors RGA DIAGRAM OF DIMENSIONS φD+βmax 15 min Sleeve LEAD SPACING AND DIAMETER φD 5 6.3 P 2.0 2.5 0.5 φd α 1.0 β P±0.5 L+α max φd Vent≧6.3φ 4 min µF 4.7 6.3V (0J) Contents φD×L mA *φD×L 10V (1A) mA φD×L mA 10 12.5 16 18 5.0 5.0 7.5 7.5 0.6 0.8 1.5 0.5 *φD×L 16V (1C) mA φD×L mA *φD×L 100 22 220 33 330 5×11 47 470 100 φD×L mA 5×11 26 5×11 35 5×11 43 5×11 49 5×11 58 5×11 62 54 5×11 60 5×11 71 5×11 76 5×11 65 5×11 76 5×11 85 5×11 97 101 5×11 95 5×11 105 6.3×11 133 5×11 110 6.3×11 142 220 221 6.3×11 160 5×11 140 6.3×11 175 6.3×11 190 330 331 8×11.5 195 6.3×11 190 8×11.5 245 470 471 8×11.5 270 6.3×11 230 8×11.5 290 1,000 102 10×12.5 460 8×11.5 380 10×16 550 10×12.5 460 2,200 222 10×16 10×20 690 710 12.5×16 700 10×20 12.5×20 760 860 12.5×16 690 3,300 332 12.5×20 960 1,090 1,330 1,460 1,640 1,990 2,200 2,780 3,100 10,000 103 15,000 153 12.5×20 16×25 12.5×25 16×25 16×25 16×31.5 18×35.5 22,000 223 18×40 10×20 840 6.3×11 200 8×11.5 215 8×11.5 270 10×12.5 370 8×11.5 310 10×20 640 10×16 560 920 1,000 1,170 1,300 1,480 1,600 1,930 2,170 16×16 830 16×16 16×20 16×20 18×20 12.5×20 1,100 16×16 940 1,260 1,400 1,690 1,880 2,220 2,400 2,780 16×16 16×20 16×20 18×20 1,060 1,120 1,270 1,330 12.5×20 12.5×25 12.5×25 16×25 16×25 16×31.5 16×31.5 18×35.5 18×25 1,800 18×35.5 2,640 16×35.5 2,500 18×40 2,950 22×40 3,460 φD×L 5×11 mA 236 335 8×11.5 310 440 680 770 1,110 1,170 1,440 1,460 1,710 1,780 10×12.5 380 12.5×16 590 16×20 970 950 1,050 1,185 1,260 10×16 10×20 12.5×20 12.5×25 16×25 16×25 16×31.5 16×31.5 18×35.5 18×20 1,220 18×25 1,470 18×25 1,650 18×40 2,280 18×35.5 2,160 18×31.5 2,330 22×40 2,720 mA φD×L 5×11 mA 1,010 16×20 1,190 16×20 18×20 16×35.5 1,340 1,440 2,500 18×35.5 2,930 18×40 3,100 mA mA 0R1 φD×L 5×11 0.22 R22 5×11 4.9 5×11 5.1 5×11 6 0.33 R33 5×11 6 5×11 7.5 5×11 8 0.47 R47 5×11 7.1 5×11 9 5×11 9 1 010 5×11 13 5×11 15 5×11 15 2.2 2R2 5×11 20 5×11 30 5×11 30 3.3 3R3 5×11 30 5×11 31 5×11 31 4.7 4R7 5×11 30 5×11 33 5×11 36 6.3×11 40 10 100 5×11 46 5×11 50 5×11 54 8×11.5 22 220 5×11 71 5×11 78 6.3×11 86 8×11.5 33 330 6.3×11 90 6.3×11 96 8×11.5 114 6.3×11 100 6.3×11 130 6,800 682 V. DC µF 0.1 35V (1V) Contents φD×L mA *φD×L 5×11 50V (1H) 75 *φD×L 63V (1J) mA 3.2 5×11 90 *φD×L 100V (2A) 3.5 47 470 6.3×11 110 5×11 90 6.3×11 120 8×11.5 141 100 101 8×11.5 180 6.3×11 150 8×11.5 188 10×12.5 235 220 221 10×12.5 300 8×11.5 270 10×16 300 10×12.5 240 10×20 450 10×16 330 331 10×16 400 10×12.5 350 10×20 520 10×16 460 10×16 12.5×16 16×16 410 425 535 540 471 460 530 610 950 1,080 12.5×20 470 10×20 10×20 12.5×25 12.5×25 16×25 12.5×25 720 *φD×L mA 66 6.3×11 54 99 6.3×11 93 10×12.5 148 8×11.5 130 4 10×16 180 10×12.5 165 12.5×20 320 10×20 265 335 16×25 570 12.5×25 440 10×20 510 16×31.5 700 16×25 540 12.5×20 640 18×35.5 880 16×31.5 715 22×40 1,760 18×40 985 12.5×20 810 12.5×16 600 1,000 102 16×20 830 16×31.5 1,210 16×25 930 920 12.5×25 16×16 720 16×25 1,260 2,200 222 18×20 1,110 18×35.5 1,600 16×35.5 1,470 18×40 2,340 16×31.5 1,340 16×31.5 1,420 3,300 332 18×25 1,570 22×40 2,290 18×35.5 1,770 22×40 2,510 16×35.5 1,610 4,700 472 18×40 1,920 18×35.5 1,900 25×40 2,610 22×40 2,340 25×40 3,000 Remark: The Case size 12.5×16, 16×16, 16×20, 18×20 and 18×25 are used flat type rubber bung. Case size in mark of “*” is downsize. 2011 Version mA 8×11.5 16×16 472 *φD×L 10×12.5 12.5×25 16×25 16×25 16×31.5 16×31.5 16×35.5 18×35.5 4,700 Unit: mm 22 25 10 12.5 1.0 2.0 25V (1E) mA 4R7 10 20 10 Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 8 3.5 Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC µF 0.47 Contents φD×L 160V (2C) mA *φD×L mA φD×L RGA 200V (2D) mA *φD×L mA φD×L 250V (2E) mA *φD×L mA φD×L 350V (2V) mA *φD×L mA R47 6.3×11 13 5×11 11 6.3×11 14 5×11 12 8×11.5 18 5×11 11 8×11.5 18 6.3×11 16 1 010 6.3×11 20 5×11 17 6.3×11 21 5×11 18 8×11.5 27 5×11 16 8×11.5 27 6.3×11 23 2.2 2R2 6.3×11 29 5×11 25 8×11.5 37 6.3×11 30 8×11.5 41 6.3×11 35 10×16 53 8×11.5 41 3.3 3R3 8×11.5 42 6.3×11 36 8×11.5 45 6.3×11 39 8×11.5 50 6.3×11 40 10×12.5 59 8×11.5 50 4.7 4R7 8×11.5 50 6.3×11 43 8×11.5 54 6.3×11 43 10×16 93 8×11.5 60 10×16 93 10×12.5 65 10 100 10×12.5 87 8×11.5 73 10×20 115 10×12.5 94 92 10×20 125 10×16 115 220 10×20 158 10×16 135 10×20 170 10×16 142 12.5×16 200 12.5×25 235 12.5×20 220 33 330 12.5×20 225 10×20 190 365 16×25 325 47 470 16×20 320 16×31.5 395 16×25 365 68 680 18×20 350 100 101 18×25 420 16×35.5 610 18×40 530 16×31.5 450 150 151 230 275 330 395 420 510 215 250 275 300 330 16×31.5 12.5×16 16×16 16×20 16×20 18×20 18×25 12.5×16 16×16 16×16 16×20 16×20 250 265 295 240 265 270 315 350 485 565 16×16 12.5×20 12.5×25 12.5×20 12.5×25 12.5×20 12.5×25 18×20 16×25 16×35.5 115 200 220 315 348 350 365 10×12.5 22 10×16 10×20 12.5×20 12.5×20 12.5×25 12.5×25 16×25 220 18×40 885 18×35.5 835 18×40 885 330 450V (2W) mA *φD×L mA 12.5×25 16×25 425 485 221 18×35.5 750 16×31.5 660 331 18×40 865 18×35.5 820 400V (2G) mA *φD×L mA φD×L V. DC µF 0.47 Contents φD×L R47 8×11.5 18 6.3×11 15 10×12.5 22 8×11.5 18 1 010 8×11.5 27 6.3×11 21 10×12.5 32 8×11.5 27 2.2 2R2 10×12.5 48 8×11.5 39 10×12.5 48 8×11.5 39 3.3 3R3 10×16 65 65 4R7 47 70 50 120 150 10×16 4.7 8×11.5 10×12.5 8×11.5 12.5×16 16×16 10×20 86 10×12.5 10×16 8×11.5 55 75 50 12.5×25 160 12.5×20 145 16×20 220 16×25 265 12.5×20 200 16×31.5 340 12.5×25 235 18×20 270 16×31.5 360 16×25 325 10×20 86 125 145 205 265 310 325 360 375 370 420 460 10 100 22 220 27 270 33 330 39 390 47 470 56 560 10×20 12.5×20 10×25 16×25 16×25 16×25 16×31.5 16×31.5 16×25 16×35.5 18×25 68 680 16×25 440 16×25 340 16×35.5 400 18×25 350 18×31.5 430 16×25 400 18×40 480 82 820 18×31.5 500 16×31.5 475 22×40 600 18×31.5 500 100 101 20×40 600 18×35.5 540 20×45 690 18×35.5 540 120 121 20×40 720 20×50 780 150 151 22×40 850 22×50 930 20×40 850 180 181 20×50 960 18×35.5 835 220 221 22×50 1,130 20×45 950 Remark: The Case size 12.5×16, 16×16, 16×20, 18×20 and 18×25 are used flat type rubber bung. Case size in mark of “*” is downsize. 2011 Verison
RGA680M1VBK-0611
物料型号:Pelon RGA系列铝电解电容器。
器件简介:RGA系列电容器是标准系列,适用于一般用途,符合RoHS标准。若对等效串联电阻(ESR)有要求,建议使用低ESR系列,并咨询联系窗口。
引脚分配:文档中未明确提供引脚分配信息,但通常铝电解电容器的引脚分配为两个端子,一个阳极(正极),一个阴极(负极)。
参数特性: - 工作温度范围:-40°C至+105°C。 - 电容公差:±20%(在120Hz和20°C条件下)。 - 漏电流:在20°C条件下,额定电压≤100V和>100V的漏电流有具体数值要求。 - ESR:当电容超过1000μF时,每增加1000μF,ESR增加0.02。 - 阻抗比:在不同额定电压和频率下,阻抗比有具体数值要求。
功能详解:文档中未提供具体功能详解,但铝电解电容器通常用于电源滤波、能量存储等。
应用信息:适用于一般用途,但对于ESR有特别要求的应用,建议使用低ESR系列。
封装信息:提供了详细的尺寸图和允许的纹波电流表格,包括电容器的直径(D)、长度(L)、引脚间距(P)、引脚直径等信息。
RGA680M1VBK-0611 价格&库存
很抱歉,暂时无法提供与“RGA680M1VBK-0611”相匹配的价格&库存,您可以联系我们找货
RGA680M1VBK-0611
  • 10+0.34863
  • 100+0.27756
  • 300+0.24192
  • 1000+0.21525
库存:1198
