XXDCELNANF-13.56M
XXDCELNANF-13.56M
    TAITIEN(泰艺)
    SMD3225_4P
    无源晶振 13.56MHz ±20ppm 12pF -40℃~+85℃
XXDCELNANF-13.56M 数据手册
High Frequency SMD Crystal Actual Size Actual Size FEATURE - Inverted-mesa structured quartz blanks for high frequency in fundamental mode up to 400MHz. - Tight tolerance 10 ppm available. TYPICAL APPLICATION - Wireless LAN, Telecom - High-Speed, High-Volume Data Transmissions XX Type XX DIMENSION (mm) XV Type RoHS Compliant Standard SOLDER PAD LAYOUT (mm) [ T O P V IE W ] #1 #2 2.2 Marking #2 and #4 are connected to metal cap of top #2 0.9 1.5 [ B O T T O M V IE W ] 2.1 #1 #3 1.5 [ S ID E V IE W ] GND #4 1.1 0.65 ± 0.1 2.5 ± 0.2 3.2 ± 0.2 #4 1.2 #3 XV (XX) 1.0 (XX) [ TOP VIEW ] 5.0±0.2 GND #4 #3 3.2±0.2 3.8 #1 [ BOTTOM VIEW ] 3.8 2.2 #2 1.5 0.9 2.2 #1 #2 Marking #2 and #4 are connected to metal cap of top 1.2 1.0max [ SIDE VIEW ] #4 #3 (XV) 1.2 (XV) ELECTRICAL SPECIFICATION Parameter Min. Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (C0) Insulation Resistance Aging Typical Max. Unit -55 125 122.326, 122.344,122.408, 122.430, 125, 156.125 10 300 3.0 500 MΩ@ DC100V ±3.0 ℃ MHz µw pF ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E.S.R) TYPE FREQUENCY MODE 80MHz ≦Freq. ≦400 MHz A1 FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) * ppm ±5 ±10 E.S.R
XXDCELNANF-13.56M 价格&库存
很抱歉,暂时无法提供与“XXDCELNANF-13.56M”相匹配的价格&库存,您可以联系我们找货
