RXQ221M2CBK-1825
RXQ221M2CBK-1825
    LELON(立隆电子)
    插件,D18xL25mm
    直插铝电解电容 AEC_D18X25MM_TM
RXQ221M2CBK-1825 数据手册
Aluminum Electrolytic Capacitors RXQ Features ‧ 105℃, 8,000 ~ 10,000 hours assured ‧ Suitable for switching power supplies, UPS, Ballast ‧ Smaller case size current ‧ RoHS Compliance Sleeve & Marking Color: Black & Golden SPECIFICATIONS Items Category Temperature Range Performance 160 ~ 400V -40℃ ~ +105℃ 450V -25℃ ~ +105℃ (at 120Hz, 20℃) ±20% Capacitance Tolerance Time Leakage Current (at 20℃) Dissipation Factor (Tanδat 120Hz, 20℃) Low Temperature Characteristics (at 120Hz) after 5 minutes CV ≦ 1,000 CV > 1,000 Leakage Current I = 0.03CV+15(µA) I = 0.02CV+25(µA) Where, C = rated capacitance in µF V = rated DC working voltage in V Rated Voltage Tanδ(max) 160 0.20 200 0.20 250 0.20 350 0.24 400 0.24 450 0.24 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 160 200 250 350 400 Impedance Z(-25)/Z(+20℃) 3 3 3 5 5 Z(-40)/Z(+20℃) Ratio 6 6 6 6 6 450 6 - 8,000 Hrs for φD = 10mm; 10,000 Hrs for φD ≥ 12.5mm Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20°C after the rated voltage applied with rated ripple current for 8,000 / 10,000 hours at 105°C. Test Time Endurance Shelf Life Test Ripple Current & Frequency Multipliers 2011 Version Test Time 1,000 Hrs Capacitance Change With in ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Less than 500% of specified value * The above specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Frequency (Hz) Cap. ( μF) 6.8 ~ 82 100 up 120 1k 10k 100k up 1.00 1.00 1.75 1.67 2.25 2.05 2.50 2.25 Aluminum Electrolytic Capacitors RXQ DIAGRAM OF DIMENSIONS 15 min Sleeve Unit: mm LEAD SPACING AND DIAMETER φD+βmax φd L+α max φD P φd α β P±0.5 Vent≧10φ 4 min V.DC 160V (2C) φD×L µF 200V (2D) Ripple Current 120 Hz 100k Hz φD×L 250V (2E) Ripple Current 120 Hz 100k Hz 12.5 16 5.0 0.6 18 7.5 0.8 1.5 0.5 Dimension: φD × L(mm) Ripple Current: mA/rms at 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT Contents 10 φD×L 350V (2V) Ripple Current 120 Hz 100k Hz 6.8 φD×L 10×16 400V (2G) Ripple Current 120 Hz 100k Hz 110 275 φD×L 10×16 Ripple Current 120 Hz 100k Hz 110 275 10 10×16 125 313 10×16 125 313 10×20 140 350 10×20 140 350 10×20 140 350 22 10×20 200 500 10×20 200 500 10×20 200 500 12.5×20 260 650 12.5×20 260 650 33 10×20 250 625 10×20 260 650 12.5×20 320 800 16×20 360 900 47 10×20 300 750 12.5×20 390 975 12.5×20 390 975 16×20 430 1,075 16×20 16×25 18×20 360 470 450 900 1,175 1,125 560 550 610 1,400 1,375 1,525 18×25 585 1,463 68 12.5×20 470 1,175 12.5×20 470 1,175 16×20 520 1,300 82 12.5×20 12.5×25 16×20 510 620 630 1,275 1,395 1,418 16×20 550 1,375 16×20 550 1,375 16×25 18×20 18×25 18×25 610 1,525 16×20 630 1,418 16×25 680 1,530 18×25 700 1,575 18×31.5 765 1,721 18×31.5 830 1,868 18×35.5 865 1,946 18×35.5 960 2,160 18×40 985 2,216 100 120 150 16×20 770 1,733 16×25 840 1,890 18×25 860 1,935 220 16×25 1,020 2,295 18×25 1,050 2,363 18×31.5 1,130 2,543 330 18×31.5 1,390 3,128 18×35.5 1,430 3,218 V.DC Contents 450V (2W) φD×L µF Ripple Current 120 Hz 100k Hz 110 275 6.8 10×20 10 12.5×20 180 450 22 47 16×20 16×25 18×20 18×25 290 390 380 480 725 975 950 1,200 68 18×31.5 630 1,575 82 18×35.5 715 1,788 33 100 18×40 800 1,800 Remark: The case size of 16×20, 18×20 and 18×25 are used flat type rubber bung 2011 Verison
RXQ221M2CBK-1825 价格&库存
很抱歉,暂时无法提供与“RXQ221M2CBK-1825”相匹配的价格&库存,您可以联系我们找货
