MP1103K30B1R5LC
MP1103K30B1R5LC
    SRD(圣融达)
    插件,P=7.5mm
    安规电容 径向
MP1103K30B1R5LC 数据手册
Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 300VAC Series) ■ 引用标准 Reference standards GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14 IEC60384-14 /EN60384-14 ■ 结构 Structure 介质:(金属化)聚丙烯膜 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: Metallized Polypropylene film Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0 Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0 典型应用 Typical ■ Application 跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等 Interlines, Surge suppression, Across-in-line as EMI filter; Power switch etc. Such as: Lamps, Power Sources etc. 特点 Features ■ 外观一致性好;有良好自愈性 抗湿性强;高耐温 长寿命,耐过电压优良 ■ 符合 RoHS 及 REACH 环保标准 ■ 电性能规范 Good appearance consistency; Good self-healing property; Good resistance to humidity; Can withstand high temperature; Long lifetime; Good ability to withstand surge voltage. Compliance with RoHs & REACH requirements. Performance Specifications 气候类别 Climate category 40/110/56 阻燃等级 Passive flammability class B 额定电压 Rated Voltage 300VAC 容量误差 Capacitance Tolerance K: ±10% 容量范围 0.0022μF~4.7μF Capacitance Range Test Condition: 耐电压 No breakdown or electric arcing Withstand Voltage Terminal to terminal:4.3UR(Vdc),5S Terminal to shell:2380VAC 60S 损耗角 ≤0.0020 10KHZ CR≤1.0μF Test Condition : Dissipation factor ≤0.0010 1KHZ CR>1.0μF 绝缘电阻或时间常数 CR≤0.33μF IR≥15000MΩ Insulation Resistance CR>0.33μF IR≥5000S 最大脉冲爬升速率 P=10mm dV / dt = 500V/μs P=15mm dV / dt = 400V/μs P=22.5mm dV / dt = 200V/μs P=27.5mm dV / dt = 150V/μs P=31.5mm dV / dt = 100V/μs P=41mm dV / dt = 60V/μs Max. Pulse Rise Time (dV / dt) 20℃, 1KHz, 1Vrms 20℃ 1V Test Condition : 20℃ 100V 1 min Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 300VAC Series) ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change:△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0080(10KHZ),CR≤1uF Rise ≤0.0050(1KHZ),CR>1uF 绝缘电阻 Insulation Resistance 耐久性试验 温度 Temp.: +110℃, Endurance Test 施加电压:1.25×额定电压(每小时增加 IR:≥ 50% of rated value 电压到 1000Vac,0.1 秒,1 次) 容量变化(相对初始值):△C/C≤±10% Test Voltage: Capacitance change: △C/C≤±10% 1.25 Times Rated Voltage(Rise the voltage to 1000Vac for .01s once per hours ) 持续时间 Duration Time: 1000H ■ ■ 安规认证 Safety Certification 认证标志 额定电压 证书号码 引用标准 认证国家 Certification Rated Voltage Certificate No. Reference standard Certification Country UL/CUL 300VAC E319615 UL60384-14 VDE 300VAC 40025029 EN60384-14 德国 Germany ENEC 300VAC 40025029 EN60384-14 欧盟 Europe CQC 300VAC CQC12001070301 GB/T6346.14-2015 中国 China 产品编码说明 美国、加拿大 America / Canada Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 M 4 R 8 * * Digit 1-3 P 1 1 0 4 K 型号代码 Product Name Code 3 0 D MP1= Class X1 Capacitors Digit 4-6 标称容量 Rated Capacitance Value For example : 104= 10×104pF = 0.1F Digit 7 容量偏差 Capacitance Tolerance K=±10% Digit 8-9 额定电压 Rated Voltage Code 30=300VAC Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 300VAC Series) ■ 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 等级 电压 尺寸 Dimension (mm) Class Voltage Capacitance (μF) MP1103K30B1R5LC X1 300VAC 0.01 10 4 9 7.5 0.5 MP1103K30C2R6LC X1 300VAC 0.01 13 5 11 10 0.6 MP1103K30D1R6LC X1 300VAC 0.01 18 5 11 15 0.6 MP1104K30C3R6LC X1 300VAC 0.1 13 6 12 10 0.6 MP1104K30D2R8LC X1 300VAC 0.1 18 6 12 15 0.8 MP1105K30E6R8LC X1 300VAC 1.0 26 12 21.5 22.5 0.8 MP1125K30E6R8LC X1 300VAC 1.2 26 12 21.5 22.5 0.8 MP1153K30C2R6LC X1 300VAC 0.015 13 5 11 10 0.6 MP1154K30C3R6LC X1 300VAC 0.15 13 6 12 10 0.6 MP1103K30B1R5LC X1 300VAC 0.01 10 4 9 7.5 0.5 MP1103K30C2R6LC X1 300VAC 0.01 13 5 11 10 0.6 MP1103K30D1R6LC X1 300VAC 0.01 18 5 11 15 0.6 MP1104K30C3R6LC X1 300VAC 0.1 13 6 12 10 0.6 MP1104K30D2R8LC X1 300VAC 0.1 18 6 12 15 0.8 MP1105K30E6R8LC X1 300VAC 1.0 26 12 21.5 22.5 0.8 MP1125K30E6R8LC X1 300VAC 1.2 26 12 21.5 22.5 0.8 MP1153K30C2R6LC X1 300VAC 0.015 13 5 11 10 0.6 MP1154K30C3R6LC X1 300VAC 0.15 13 6 12 10 0.6 MP1103K30B1R5LC X1 300VAC 0.01 10 4 9 7.5 0.5 MP1103K30C2R6LC X1 300VAC 0.01 13 5 11 10 0.6 MP1103K30D1R6LC X1 300VAC 0.01 18 5 11 15 0.6 MP1104K30C3R6LC X1 300VAC 0.1 13 6 12 10 0.6 MP1104K30D2R8LC X1 300VAC 0.1 18 6 12 15 0.8 MP1154K30D2R8LC X1 300VAC 0.15 18 6 12 15 0.8 MP1155K30E5R8LC X1 300VAC 1.5 26.5 11 20 22.5 0.8 MP1223K30C2R6LC X1 300VAC 0.022 13 5 11 10 0.6 MP1224K30C3R690 X1 300VAC 0.22 13 6 12 10 0.6 MP1224K30D4R8LC X1 300VAC 0.22 18 8.4 14.5 15 0.8 MP1224K30E2R8LC X1 300VAC 0.22 26.5 7 16.5 22.5 0.8 MP1225K30F3R8LC X1 300VAC 2.2 31 14 25 27.5 0.8 MP1333K30C2R6LC X1 300VAC 0.033 13 5 11 10 0.6 MP1334K30D4R8LC X1 300VAC 0.33 18 8.4 14.5 15 0.8 MP1335K30F8R8LC X1 300VAC 3.3 31.5 21 31 27.5 0.8 Part No. 说明 Note: “**”表示内部特征码 “**”=Internal use. W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 300VAC Series) ■ 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 等级 电压 尺寸 Dimension (mm) Part No. Class Voltage Capacitance (μF) MP1394K30D6R8LC X1 300VAC 0.39 18 10 15.8 15 0.8 MP1472K30C2R6LC X1 300VAC 0.0047 13 5 11 10 0.6 MP1473K30C2R6LC X1 300VAC 0.047 13 5 11 10 0.6 MP1474K30D6R8LC X1 300VAC 0.47 18 10 15.8 15 0.8 MP1474K30E4R8LC X1 300VAC 0.47 26.5 10 19 22.5 0.8 MP1474K30F1R8LC X1 300VAC 0.47 31.5 10.8 19.5 27.5 0.8 MP1564K30E4R8LC X1 300VAC 0.56 26.5 10 19 22.5 0.8 MP1683K30C2R6LC X1 300VAC 0.068 13 5 11 10 0.6 MP1683K30C3R6LC X1 300VAC 0.068 13 6 12 10 0.6 MP1684K30D8R8LC X1 300VAC 0.68 18 11.2 19.2 15 0.8 MP1394K30D6R8LC X1 300VAC 0.39 18 10 15.8 15 0.8 MP1472K30C2R6LC X1 300VAC 0.0047 13 5 11 10 0.6 MP1473K30C2R6LC X1 300VAC 0.047 13 5 11 10 0.6 MP1474K30D6R8LC X1 300VAC 0.47 18 10 15.8 15 0.8 MP1474K30E4R8LC X1 300VAC 0.47 26.5 10 19 22.5 0.8 MP1474K30F1R8LC X1 300VAC 0.47 31.5 10.8 19.5 27.5 0.8 MP1564K30E4R8LC X1 300VAC 0.56 26.5 10 19 22.5 0.8 MP1683K30C2R6LC X1 300VAC 0.068 13 5 11 10 0.6 MP1683K30C3R6LC X1 300VAC 0.068 13 6 12 10 0.6 说明 Note: “**”表示内部特征码 W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 “**”=Internal use. Note: We can customize the capacitors according to customers special requirements.
MP1103K30B1R5LC
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款具有锁存功能的六进制计数器/分频器,广泛应用于数字电路中进行计数和分频。
3. 引脚分配:EL817共有14个引脚,包括时钟输入、清零、使能、输出等。
4. 参数特性:工作电压范围为3.3V至5.5V,工作频率可达100MHz。
5. 功能详解:EL817内部包含6个D触发器,可实现同步计数和分频功能。
6. 应用信息:EL817适用于数字钟表、频率计等需要计数和分频功能的场合。
7. 封装信息:EL817采用双列直插式封装(DIP-14)。
MP1103K30B1R5LC 价格&库存
很抱歉,暂时无法提供与“MP1103K30B1R5LC”相匹配的价格&库存,您可以联系我们找货
