OVH222M0ETR-1010
OVH222M0ETR-1010
    LELON(立隆电子)
    SMD,D10xL10mm
    贴片铝电解电容 AEC_D10X10MM_SM
OVH222M0ETR-1010 数据手册
Organic Conductive Polymer Capacitors OVH Features ˙105℃, 2,000 hours assured ˙Ultra low ESR, solid capacitors of SMD type ˙RoHS Compliance Marking color: Blue SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Performance -55℃ ~ +105℃ ±20% (at 120Hz, 20℃) Rated voltage applied, after 2 minutes at 20℃. See Standard Ratings Leakage Current (at 20℃ )* Dissipation Factor (Tanδ at 120Hz, 20℃ ) ESR (at 100k ~ 300k Hz, 20℃ ) See Standard Ratings See Standard Ratings Test Time 2,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 105℃. Endurance Test Time 1,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them at 60℃, 90 to 95% RH for 1,000 hours. Leakage current should be tested after voltage treatment*. Moisture Resistance Within ±10% of initial value Less than 130% of specified value Less than 130% of specified value Within specified value Capacitance Change Dissipation Factor ESR Leakage Current Resistance to Soldering Heat * (Please refer to page 23 for reflow soldering conditions) Ripple Current & Frequency Multipliers Frequency (Hz) 120 ≦ f < 1k 1k ≦ f < 10k Multiplier 0.05 0.3 10k ≦ f < 100k 100k ≦ f < 500k 0.7 1.0 * For any doubt about measured values, measure the leakage current again after the following voltage treatment. Voltage treatment: Applying DC rated voltage to the capacitors for 2 hours at 105 oC. DIAGRAM OF DIMENSIONS B±0.2 φD±0.5 LEAD SPACING AND DIAMETER φD 6.3 8 10 10 W L 0.3 Max A±0.2 0.4 max L A 5.9 +0.1 / -0.3 6.6 6.7 ± 0.3 8.4 7.7 ± 0.3 10.4 9.9 +0.1 / -0.3 10.4 B 6.6 8.4 10.4 10.4 Unit: mm C 7.4 9.2 11.2 11.2 P ± 0.2 W 0.5 ~ 0.8 2.0 0.7 ~ 1.1 3.1 0.7 ~ 1.1 4.7 0.7 ~ 1.1 4.7 P C±0.2 MARKING φD = 6.3 Negative polarity φD = 8 ~ 10 a1 10 16H Date code Rated cap. Rated voltage & Series code Negative polarity a1 OVH 470 6.3V Date code Series name Rated cap. Rated voltage 2011 Verison Organic Conductive Polymer Capacitors Dimension: φD× L(mm) Ripple Current: mA/rms at 100k Hz, 105℃ STANDARD RATINGS W. V. (V) 2.5V (0E) 4V (0G) 6.3V (0J) 2011 Version Capacitance (µF) Size φD×L(mm) 390 6.3×5.9 560 OVH Tanδ (120Hz, 20℃ ) 0.12 LC (µA) ESR (mΩ/at 100k ~ 300k Hz, 20℃ Max) Rated R. C. (mA/rms at 100k Hz, 105℃ ) 293 10 3,900 6.3×5.9 0.12 420 10 3,900 8×6.7 0.12 420 9 4,200 680 8×6.7 0.12 510 9 4,500 1,200 10×7.7 0.12 900 9 5,000 2,200 10×9.9 0.12 1,650 8 6,000 330 6.3×5.9 0.12 396 10 3,900 470 8×6.7 0.12 564 9 4,500 560 8×6.7 0.12 894 9 4,500 1,000 10×7.7 0.12 1,200 9 5,000 1,800 10×9.9 0.12 2,160 8 6,000 220 6.3×5.9 0.12 416 10 3,900 330 8×6.7 0.12 624 9 4,500 390 8×6.7 0.12 737 9 4,500 820 10×7.7 0.12 1,550 9 5,000 1,500 10×9.9 0.12 2,835 8 6,000
OVH222M0ETR-1010 价格&库存
很抱歉,暂时无法提供与“OVH222M0ETR-1010”相匹配的价格&库存,您可以联系我们找货
