SFD5D28-4R7N-LF
SFD5D28-4R7N-LF
    SUNLORD(顺络)
    功率电感 6030
SFD5D28-4R7N-LF 数据手册
SMD Power Inductor(HLSFD Series) 贴片功率电感 HLSFD 系列 FEATURES 特点 ● Excellent solderability and high heat resistance. 良好的可焊性 ● Low cost and packed in embossed carrier tape. 低成本编带包装 ● Magnetically shielded construction. 磁屏蔽结构 APPLICATIONS 应用 ● Ideally used in Mobilephone,PDA,MP3,MDSC/DVC,Portable DVD, etc as DC-DC Converter. 用于移动电话、PDA、MP3、影碟机、便携式 DVD、DC-DC 转换等。 Product Identification 产品标识 HLSFD 4D28 - 100 ② ① N - LF ③ ④ ⑤ ① Series name 系列名称 ② Product dimensions 产品尺寸: (4.8*4.8*2.8 mm ) ③ Inductance Value 电感量: (3R3:3.3uH 100: 10uH; 101:100uH) ④ Inductance Tolerance 电感量公差:(K:10% ; M:20% ; N:30% or 25%) ⑤ Lead free products 无铅产品 1.2 Max. 1. 0 3 4. 1. 3 3.2 Max. 4. 5 M 3. ax. 3 Shapes And Dimensions 外形及尺寸示意图 3.2 Max. 7 1. 3 1. MGSFD2D11, MGSFD2D11HP Series A H F G E B G D C Series Dimensions(mm) A Max. B Max. C Max. D Max. E F G H HLSFD4D18 5.0 5.0 2.0 6.9 1.5 1.5 1.9 5.3 HLSFD4D28 5.0 5.0 3.0 6.9 1.5 1.5 1.9 5.3 HLSFD5D18 6.0 6.0 2.0 8.2 2.0 2.0 2.15 6.3 HLSFD5D28 6.0 6.0 3.0 8.2 2.0 2.0 2.15 6.3 HLSFD6D28 7.0 7.0 3.0 9.5 2.0 2.0 2.65 7.3 Electrical Characteristics 电气性能 HLSFD2D11 Series L±30% DCR max. Isat Irms (uH) (Ohms) (A) (A) HLSFD2D11-1R5N-LF 1.5 0.068 0.90 1.48 HLSFD2D11-2R2N-LF 2.2 0.098 0.78 1.27 HLSFD2D11-3R3N-LF 3.3 0.123 0.60 1.02 HLSFD2D11-4R7N-LF 4.7 0.170 0.50 0.88 HLSFD2D11-6R8N-LF 6.8 0.260 0.44 0.80 HLSFD2D11-100N-LF 10.0 0.400 0.35 0.65 Part Number 1. Test freq. at 100KHz. 2. Isat: DC current at which the inductance drops 35% from its value without current 3. Irms: Current that causes a 40℃ temperature rise from 25℃ ambient. HLSFD2D11HP Series L±30% DCR max. Isat Irms (uH) (Ohms) (A) (A) HLSFD2D11HP-1R5N-LF 1.5 0.080 1.35 1.60 HLSFD2D11HP-2R2N-LF 2.2 0.120 1.10 1.30 HLSFD2D11HP-3R3N-LF 3.3 0.173 0.90 0.90 HLSFD2D11HP-4R7N-LF 4.7 0.238 0.75 0.85 HLSFD2D11HP-6R8N-LF 6.8 0.371 0.63 0.65 HLSFD2D11HP-100N-LF 10.0 0.559 0.52 0.52 Part Number 1. Test freq. at 100KHz. 2. Isat: DC current at which the inductance drops 35% from its value without current 3. Irms: Current that causes a 40℃ temperature rise from 25℃ ambient. HLSFD4D18 Series L±30% Test freq. DCR max. Rated Current (uH) (MHz) (Ohms) (A) HLSFD4D18-1R0N-LF 1.0 7.96 0.045 1.72 HLSFD4D18-2R2N-LF 2.2 7.96 0.075 1.32 HLSFD4D18-2R7N-LF 2.7 7.96 0.105 1.28 HLSFD4D18-3R3N-LF 3.3 7.96 0.110 1.04 HLSFD4D18-3R9N-LF 3.9 7.96 0.155 0.88 HLSFD4D18-4R7N-LF 4.7 7.96 0.162 0.84 HLSFD4D18-5R6N-LF 5.6 7.96 0.170 0.80 HLSFD4D18-6R8N-LF 6.8 7.96 0.200 0.76 HLSFD4D18-8R2N-LF 8.2 7.96 0.245 0.68 HLSFD4D18-100N-LF 10.0 0.1 0.200 0.61 HLSFD4D18-120N-LF 12.0 0.1 0.210 0.56 HLSFD4D18-150N-LF 15.0 0.1 0.240 0.50 HLSFD4D18-180N-LF 18.0 0.1 0.338 0.48 HLSFD4D18-220N-LF 22.0 0.1 0.397 0.41 HLSFD4D18-270N-LF 27.0 0.1 0.441 0.35 HLSFD4D18-330N-LF 33.0 0.1 0.694 0.32 HLSFD4D18-390N-LF 39.0 0.1 0.709 0.30 HLSFD4D18-470N-LF 47.0 0.1 0.922 0.28 HLSFD4D18-560N-LF 56.0 0.1 1.080 0.26 HLSFD4D18-680N-LF 68.0 0.1 1.300 0.24 HLSFD4D18-820N-LF 82.0 0.1 1.560 0.22 HLSFD4D18-101N-LF 100.0 0.1 1.730 0.20 HLSFD4D18-121N-LF 120.0 0.1 2.390 0.18 HLSFD4D18-151N-LF 150.0 0.1 2.670 0.15 HLSFD4D18-181N-LF 180.0 0.1 4.000 0.14 Part Number 1. Rated current: It is either the inductance is 35% lover than its nominal value in D.C. saturation characteristics or temperature raise becomes ΔT=40℃,whichever is lover. HLSFD4D28 Series L±30% DCR max. Rated Current (uH) (Ohms) (A) HLSFD4D28-1R2N-LF 1.2 0.024 2.56 HLSFD4D28-1R8N-LF 1.8 0.028 2.20 HLSFD4D28-2R2N-LF 2.2 0.032 2.04 HLSFD4D28-2R7N-LF 2.7 0.044 1.60 HLSFD4D28-3R3N-LF 3.3 0.050 1.57 HLSFD4D28-3R9N-LF 3.9 0.065 1.44 HLSFD4D28-4R7N-LF 4.7 0.072 1.32 HLSFD4D28-5R6N-LF 5.6 0.101 1.17 HLSFD4D28-6R8N-LF 6.8 0.109 1.12 HLSFD4D28-8R2N-LF 8.2 0.118 1.04 HLSFD4D28-100N-LF 10.0 0.128 1.00 HLSFD4D28-120N-LF 12.0 0.132 0.84 HLSFD4D28-150N-LF 15.0 0.149 0.76 HLSFD4D28-180N-LF 18.0 0.166 0.72 HLSFD4D28-220N-LF 22.0 0.235 0.70 HLSFD4D28-270N-LF 27.0 0.261 0.58 HLSFD4D28-330N-LF 33.0 0.331 0.56 HLSFD4D28-390N-LF 39.0 0.384 0.50 HLSFD4D28-470N-LF 47.0 0.587 0.48 HLSFD4D28-560N-LF 56.0 0.625 0.41 HLSFD4D28-680N-LF 68.0 0.699 0.35 HLSFD4D28-820N-LF 82.0 0.915 0.32 HLSFD4D28-101N-LF 100.0 1.020 0.29 HLSFD4D28-121N-LF 120.0 1.270 0.27 HLSFD4D28-151N-LF 150.0 1.350 0.24 HLSFD4D28-181N-LF 180.0 1.540 0.22 Part Number 1. Test freq. at 100KHz. 2. Rated current: It is either the inductance is 35% lover than its nominal value in D.C. saturation characteristics or temperature raise becomes ΔT=40℃,whichever is lover. HLSFD5D18 Series L±30% DCR max. Rated Current (uH) (Ohms) (A) HLSFD5D18-4R1N-LF 4.1 0.057 1.95 HLSFD5D18-5R4N-LF 5.4 0.076 1.60 HLSFD5D18-6R2N-LF 6.2 0.096 1.40 HLSFD5D18-8R9N-LF 8.9 0.116 1.25 HLSFD5D18-100N-LF 10.0 0.124 1.20 HLSFD5D18-120N-LF 12.0 0.153 1.10 HLSFD5D18-150N-LF 15.0 0.196 0.97 HLSFD5D18-180N-LF 18.0 0.210 0.85 HLSFD5D18-220N-LF 22.0 0.290 0.80 HLSFD5D18-270N-LF 27.0 0.330 0.75 HLSFD5D18-330N-LF 33.0 0.385 0.65 HLSFD5D18-390N-LF 39.0 0.520 0.57 HLSFD5D18-470N-LF 47.0 0.595 0.54 HLSFD5D18-560N-LF 56.0 0.665 0.50 HLSFD5D18-680N-LF 68.0 0.840 0.43 HLSFD5D18-820N-LF 82.0 0.978 0.41 HLSFD5D18-101N-LF 100.0 1.200 0.36 Part Number 1. Test freq. at 100KHz. 2. Rated current: It is either the inductance is 35% lover than its nominal value in D.C. saturation characteristics or temperature raise becomes ΔT=40℃,whichever is lover. HLSFD6D28 Series L±30% DCR max. Rated Current (uH) (Ohms) (A) HLSFD6D28-3R0N-LF 3.0 0.024 3.00 HLSFD6D28-3R9N-LF 3.9 0.027 2.60 HLSFD6D28-5R0N-LF 5.0 0.031 2.40 HLSFD6D28-6R0N-LF 6.0 0.035 2.25 HLSFD6D28-7R3N-LF 7.3 0.054 2.10 HLSFD6D28-8R6N-LF 8.6 0.058 1.85 HLSFD6D28-100N-LF 10.0 0.065 1.70 HLSFD6D28-120N-LF 12.0 0.070 1.55 HLSFD6D28-150N-LF 15.0 0.084 1.40 HLSFD6D28-180N-LF 18.0 0.095 1.32 HLSFD6D28-220N-LF 22.0 0.128 1.20 HLSFD6D28-270N-LF 27.0 0.142 1.05 HLSFD6D28-330N-LF 33.0 0.165 0.97 HLSFD6D28-390N-LF 39.0 0.210 0.86 HLSFD6D28-470N-LF 47.0 0.238 0.80 HLSFD6D28-560N-LF 56.0 0.277 0.73 HLSFD6D28-680N-LF 68.0 0.304 0.65 HLSFD6D28-820N-LF 82.0 0.390 0.60 HLSFD6D28-101N-LF 100.0 0.535 0.54 Part Number 1. Test freq. at 10KHz. 2. Rated current: It is either the inductance is 35% lover than its nominal value in D.C. saturation characteristics or temperature raise becomes ΔT=40℃,whichever is lover.
SFD5D28-4R7N-LF 价格&库存
很抱歉,暂时无法提供与“SFD5D28-4R7N-LF”相匹配的价格&库存,您可以联系我们找货
