CL160808T-100K-N
CL160808T-100K-N
    CHILISIN(奇力新)
    固定电感器
CL160808T-100K-N 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BSCL Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors - CL Series CL Series The SMD multi-layered ferrite chip inductors provide a cost-effective solution for densely packed PC board designs. CL series comes in 4 sizes and is suitable for low frequency applications. Features Applications  RoHS compliant  Personal computers, HDDs, other various electronic devices  High mounting density of compact circuit due to crosstalk  Any portable device where compact size and high mounting elimination that results from a closed magnetic flux in a ferrite densities are required material  Suitable for flow and re-flow soldering  Available in 5 sizes Product Identification  Packaging :T:Tape and Reel;B:Bulk Shape and Dimensions Recommended Pattern B Ferrite Terminal Electrode D D C A C A B Dimensions in mm Dimensions in mm TYPE A B C D TYPE A B C CL160808 1.60.20 0.800.20 0.800.20 0.30.20 CL160808 0.7 ~ 0.8 1.8 ~ 2.0 0.6 ~ 0.8 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 CL201209 2.00.20 1.250.20 0.900.20 0.50.30 CL201209 CL201212 2.00.20 1.250.20 1.250.20 0.50.30 CL201212 1.0 ~ 1.2 2.6 ~ 4.0 1.0 ~ 1.2 CL321611 3.20.20 1.600.20 1.100.20 0.50.30 CL321611 2.0 4.2 ~ 5.2 1.2 SMD Multilayer Ferrite Chip Inductors – CL Series Electrical Characteristics Inductance Tolerance Q (H) (±%) Min CL160808T-10N-N 0.010 20 15 CL160808T-33N-N 0.033 20 CL160808T-47N-N 0.047 20 CL160808T-56N-N 0.056 CL160808T-68N-N CL160808T-82N-N Test SRF RDC IDC (MHz) Min (Ω) Max (mA) Max 50 300 0.2 50 15 50 270 0.2 50 15 50 260 0.3 50 20 15 50 255 0.3 50 0.068 20 15 50 250 0.3 50 0.082 20 15 50 245 0.3 50 CL160808T-R10-N 0.10 20 / 15 / 10 25 25 240 0.5 50 CL160808T-R12-N 0.12 20 / 15 / 10 25 25 205 0.5 50 CL160808T-R15-N 0.15 20 / 15 / 10 25 25 180 0.6 50 CL160808T-R18-N 0.18 20 / 15 / 10 25 25 165 0.6 50 CL160808T-R22-N 0.22 20 / 15 / 10 25 25 150 0.8 50 CL160808T-R27-N 0.27 20 / 15 / 10 25 25 136 0.8 50 CL160808T-R33-N 0.33 20 / 15 / 10 25 25 125 0.85 35 CL160808T-R39-N 0.39 20 / 15 / 10 25 25 110 1.00 35 CL160808T-R47-N 0.47 20 / 15 / 10 25 25 105 1.35 35 CL160808T-R56-N 0.56 20 / 15 / 10 25 25 95 1.50 35 CL160808T-R68-N 0.68 20 / 15 / 10 25 25 85 1.70 35 CL160808T-R82-N 0.82 20 / 15 / 10 25 25 75 2.10 35 CL160808T-1R0-N 1.0 20 / 15 / 10 35 10 65 0.60 25 CL160808T-1R2-N 1.2 20 / 15 / 10 35 10 60 0.80 25 CL160808T-1R5-N 1.5 20 / 15 / 10 35 10 55 0.80 25 CL160808T-1R8-N 1.8 20 / 15 / 10 35 10 50 0.95 25 CL160808T-2R2-N 2.2 20 / 15 / 10 35 10 45 1.00 15 CL160808T-2R7-N 2.7 20 / 15 / 10 35 10 40 1.15 15 CL160808T-3R3-N 3.3 20 / 15 / 10 35 10 38 1.30 15 CL160808T-3R9-N 3.9 20 / 15 / 10 35 10 36 1.50 15 CL160808T-4R7-N 4.7 20 / 15 / 10 35 10 33 1.60 15 CL160808T-5R6-N 5.6 20 / 15 / 10 35 4 22 1.10 5 CL160808T-6R8-N 6.8 20 / 15 / 10 35 4 20 1.30 5 CL160808T-8R2-N 8.2 20 / 15 / 10 30 4 18 1.50 5 CL160808T-100-N 10 20 / 15 / 10 30 2 17 1.70 5 CL160808T-120-N 12 20 / 15 / 10 30 2 15 1.80 3 CL160808T-150-N 15 20 / 15 / 10 20 1 14 1.50 1 CL160808T-220-N 22 20 / 15 / 10 20 1 11 1.70 1 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – CL Series Electrical Characteristics Part Number Inductance Tolerance Q Test Frequency SRF RDC IDC (H) (±%) Min (MHz) MHz) Min (Ω) Max (mA) Max CL201209T-22N-N 0.022 20 20 50 320 0.20 300 CL201209T-33N-N 0.033 20 / 15 20 50 320 0.20 300 CL201209T-47N-N 0.047 20 / 15 20 50 320 0.20 300 CL201209T-56N-N 0.056 20 / 15 20 50 320 0.20 300 CL201209T-68N-N 0.068 20 / 15 20 50 280 0.20 300 CL201209T-82N-N 0.082 20 / 15 20 50 255 0.20 300 CL201209T-R10-N 0.10 20 / 15 / 0 25 25 235 0.30 250 CL201209T-R12-N 0.12 20 / 15 / 10 25 25 220 0.30 250 CL201209T-R15-N 0.15 20 / 15 / 10 25 25 200 0.40 250 CL201209T-R18-N 0.18 20 / 15 / 10 25 25 185 0.40 250 CL201209T-R22-N 0.22 20 / 15 / 10 25 25 170 0.50 250 CL201209T-R27-N 0.27 20 / 15 / 10 25 25 150 0.50 250 CL201209T-R33-N 0.33 20 / 15 / 10 25 25 145 0.55 250 CL201209T-R39-N 0.39 20 / 15 / 10 25 25 135 0.65 250 CL201209T-R47-N 0.47 20 / 15 / 10 25 25 125 0.65 250 CL201209T-R56-N 0.56 20 / 15 / 10 25 25 115 0.75 150 CL201209T-R68-N 0.68 20 / 15 / 10 25 25 105 0.80 150 CL201209T-R82-N 0.82 20 / 15 / 10 25 25 100 1.00 150 CL201209T-1R0-N 1.0 20 / 15 / 10 45 10 75 0.40 50 CL201209T-1R2-N 1.2 20 / 15 / 10 45 10 65 0.50 50 CL201209T-1R5-N 1.5 20 / 15 / 10 45 10 60 0.50 50 CL201209T-1R8-N 1.8 20 / 15 / 10 45 10 55 0.60 50 CL201209T-2R2-N 2.2 20 / 15 / 10 45 10 50 0.65 30 Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – CL Series Electrical Characteristics Part Number Inductance Tolerance Q Test Frequency SRF RDC IDC (H) (±%) Min (MHz) (MHz) Min (Ω) Max (mA) Max CL201212T-2R7-N 2.7 20 / 15 / 10 45 10 45 0.75 30 CL201212T-3R3-N 3.3 20 / 15 / 10 45 10 41 0.80 30 CL201212T-3R9-N 3.9 20 / 15 / 10 45 10 38 0.90 30 CL201212T-4R7-N 4.7 20 / 15 / 10 45 10 35 1.00 30 CL201212T-5R6-N 5.6 20 / 15 / 10 45 4 32 0.90 15 CL201212T-6R8-N 6.8 20 / 15 / 10 45 4 29 1.00 15 CL201212T-8R2-N 8.2 20 / 15 / 10 45 4 26 1.10 15 CL201212T-100-N 10 20 / 15 / 10 45 2 24 1.10 15 CL201212T-120-N 12 20 / 15 / 10 45 2 22 1.20 15 CL201212T-150-N 15 20 / 15 / 10 30 1 19 0.80 5 CL201212T-180-N 18 20 / 15 / 10 30 1 18 0.90 5 CL201212T-220-N 22 20 / 15 / 10 30 1 16 1.1 5 Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – CL Series Electrical Characteristics Inductance Tolerance Q (H) (±%) Min CL321611T-47N-N 0.047 20 20 CL321611T-56N-N 0.056 20 CL321611T-68N-N 0.068 20 CL321611T-82N-N 0.082 CL321611T-R10-N CL321611T-R12-N Test SRF RDC IDC (MHz) Min (Ω) Max (mA) Max 50 320 0.15 300 20 50 280 0.25 300 20 50 280 0.25 300 20 20 50 250 0.25 300 0.10 20 / 15 / 10 25 25 235 0.25 250 0.12 20 / 15 / 10 25 25 220 0.30 250 CL321611T-R15-N 0.15 20 / 15 / 10 25 25 200 0.30 250 CL321611T-R18-N 0.18 20 / 15 / 10 25 25 185 0.40 250 CL321611T-R22-N 0.22 20 / 15 / 10 25 25 170 0.40 250 CL321611T-R27-N 0.27 20 / 15 / 10 25 25 150 0.50 250 CL321611T-R33-N 0.33 20 / 15 / 10 25 25 145 0.60 250 CL321611T-R39-N 0.39 20 / 15 / 10 25 25 135 0.50 200 CL321611T-R47-N 0.47 20 / 15 / 10 25 25 125 0.60 200 CL321611T-R56-N 0.56 20 / 15 / 10 25 25 115 0.70 150 CL321611T-R68-N 0.68 20 / 15 / 10 25 25 105 0.80 150 CL321611T-R82-N 0.82 20 / 15 / 10 25 25 100 0.90 150 CL321611T-1R0-N 1.0 20 / 15 / 10 45 10 75 0.40 100 CL321611T-1R2-N 1.2 20 / 15 / 10 45 10 65 0.50 100 CL321611T-1R5-N 1.5 20 / 15 / 10 45 10 60 0.50 80 CL321611T-1R8-N 1.8 20 / 15 / 10 45 10 55 0.50 70 CL321611T-2R2-N 2.2 20 / 15 / 10 45 10 50 0.60 60 CL321611T-2R7-N 2.7 20 / 15 / 10 45 10 45 0.60 60 CL321611T-3R3-N 3.3 20 / 15 / 10 45 10 41 0.70 60 CL321611T-3R9-N 3.9 20 / 15 / 10 45 10 38 0.80 50 CL321611T-4R7-N 4.7 20 / 15 / 10 45 10 35 0.90 50 CL321611T-5R6-N 5.6 20 / 15 / 10 45 4 32 0.70 25 CL321611T-6R8-N 6.8 20 / 15 / 10 45 4 29 0.80 25 CL321611T-8R2-N 8.2 20 / 15 / 10 45 4 26 0.90 25 CL321611T-100-N 10 20 / 15 / 10 45 2 24 1.00 25 CL321611T-120-N 12 20 / 15 / 10 45 2 22 1.00 15 CL321611T-150-N 15 20 / 15 / 10 35 1 19 0.70 5 CL321611T-180-N 18 20 / 15 / 10 35 1 18 0.75 5 CL321611T-220-N 22 20 / 15 / 10 35 1 16 0.90 5 CL321611T-270-N 27 20 / 15 / 10 35 1 14 0.90 5 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : K=±10% , L=±15% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  IDC:Applied the current to coils, the inductance shall be less than 10% initial value  Measure Equipment: L & Q:HP4291A SRF:Agilent HP8753D/Agilent E4991A RDC:HP4338B or CHEN HWA 502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Multilayer Ferrite Chip Inductors – CL Series Test Instruments:Agilent E4991A Impedance / Material Analyzer CL160808 Q v s. FREQUENCY CHARACTERISTICS INDUCTANCE v s. FREQUENCY CHARACTERISTICS 80 100 6.8uH 70 1.8uH 10 60 6.8uH 50 0.12uH Q L( uH) 1.8uH 1 40 30 0.12uH 20 0.1 10 0.01 0 1 10 100 1000 1 10 FREQUENCY(MHz) 100 FREQUENCY(MHz) CL201209 Q v s. FREQUENCY CHARACTERISTICS INDUCTANCE v s. FREQUENCY CHARACTERISTICS 90 100 2.2uH 5.6uH 80 5.6uH 70 10 0.47uH 2.2uH 60 50 Q L( uH) 0.47uH 1 40 30 0.1 20 10 0.01 0 1 10 100 1000 1 10 FREQUENCY(MHz) 100 FREQUENCY(MHz) CL321611 INDUCTANCE v s. FREQUENCY CHARACTERISTICS Q v s. FREQUENCY CHARACTERISTICS 100 100 10uH 2.7uH 90 0.47uH 80 10uH 70 10 L( uH) 60 Q 2.7uH 50 40 0.47uH 1 30 20 10 0 0.1 1 10 100 FREQUENCY(MHz) 1000 1 10 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 100 SMD Multilayer Ferrite Chip Inductors - CL Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K Tape A B C D PCS / Reel CL160808 1.05 1.85 0.95 8.0 4.0 3.5 - B 178 60 12 1.5 4000 CL201209 1.50 2.30 0.97 8.0 4.0 3.5 - B 178 60 12 1.5 4000 CL201212 1.35 2.25 0.22 8.0 4.0 3.5 1.35 A 178 60 12 1.5 3000 CL321611 1.88 3.50 0.22 8.0 4.0 3.5 1.27 A 178 60 12 1.5 3000
CL160808T-100K-N 价格&库存
很抱歉,暂时无法提供与“CL160808T-100K-N”相匹配的价格&库存,您可以联系我们找货
CL160808T-100K-N
    • 1+0.55250
    • 100+0.31930
    • 1000+0.22470
    • 2000+0.13750
    • 4000+0.10100
    库存:3400
    CL160808T-100K-N
    • 20+0.15570
    • 100+0.09660
    • 1000+0.06370
    • 4000+0.04550
    • 8000+0.04320
    • 40000+0.04000
