MHCHL201610A-1R5M-Q8
    CHILISIN(奇力新)
    功率电感 SMD
MHCHL201610A-1R5M-Q8 数据手册
Form No.: QF-1274 Edition: 2 RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 各廠家 Customer: : Customer P/N: Drawing No: : Quantity: : 0 Pcs. Chilisin P/N: : Date : 2018/10/24 MHCHL201610A-R33M-Q8 SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 東莞奇力新電子( 東莞奇力新電子(東莞廠) 東莞廠)有限公司 奇力新電子股份有限公司 Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL +86-769-8773-0251~3 FAX +86-769-8773-0232 E-mail cect@chilisin.com Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com http //www.chilisin.com : : : : : : : 奇力新電子( 奇力新電子(越南廠) 越南廠)有限公司 奇力新電子( 奇力新電子(湖南廠) 湖南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel 84-316 255 688 Fax 84-316 255 689 E-mail sales@chilisin.com : : Drawn by 陳瑞揚 ryan.chen : HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel 86-745-867-5882 E-mail cect@chilisin.com : : Checked by ling 溫美玲 Approved by 陳瑞揚 ryan.chen YG18A01307 MHCHL201610A Series Specification 1 Scope: This specification applies to Molding power inductors 2 Part Numbering: 3 Rating: Operating Temperature: -40℃ ~ 125℃(Including self - temperature rise) Storage Temperature: -40℃ ~ 125℃(after PCB) -5℃~35℃,Humidity 45%~85%(before PCB) 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35 ) Ordinary Humidity(25 to 85% RH) ℃ In case of doubt 20 to 30 50 to 80 %RH ℃ MHCHL201610A Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Inductance (uH ) Tolerance (±%) Test Freq. Irms(A) Max.(Typ) Isat(A) Max.(Typ) RDC(mΩ) Max.(Typ) MHCHL201610A-R24M-Q8 0.24 20 2MHz,0.2V 3.9(4.8) 5.6(7.0) 27(21) MHCHL201610A-R33M-Q8 0.33 20 2MHz,0.2V 4.7(5.1) 5.3(6.0) 23(17.5) MHCHL201610A-R47M-Q8 0.47 20 2MHz,0.2V 3.5(4.2) 3.9(4.8) 42(33) MHCHL201610A-R68M-Q8 0.68 20 2MHz,0.2V 2.7(3.4) 3.2(4.0) 56(43) Part No. MHCHL201610A-1R0M-Q8 1 20 2MHz,0.2V 2.5(3.1) 2.9(3.6) 65(53) MHCHL201610A-1R5M-Q8 1.5 20 2MHz,0.2V 2.3(2.7) 2.5(2.8) 85(75) NOTE: 1.Operating temperature range -40℃ ~ 125℃(Including self - temperature rise) 2.Isat for Inductance drop 30% from its value without current. ℃ temperature rise from 25℃ ambient. ℃ ambient 3.Irms for a 40 4.All test data is referenced to 25 5.Absolute maximum voltage 20VDC MHCHL201610A Series Specification 8 MHCHL201610A Series 8.1 Construction: 8.2 Material List: MHCHL201610A Series Specification 9 Packaging: 9.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. 9.2 Packaging Quantity 9.3 Reel Dimensions MHCHL201610A Series Specification 9 Packaging: 9.4 Tape Dimensions in mm 10 Recommended Land Pattern: 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5.After manufacturing process, there might be slight irregular shape on the edge of the products, and it's a normal phenomenon that can be neglected 6.The moisture sensitivity level (MSL) of products is classified as level 1. MHCHL201610A Series Specification 12 Graph: MHCHL201610A-R33M-Q8
MHCHL201610A-1R5M-Q8 价格&库存
很抱歉,暂时无法提供与“MHCHL201610A-1R5M-Q8”相匹配的价格&库存,您可以联系我们找货
