BCNR3010C-2R2N
BCNR3010C-2R2N
    BC(台湾诚阳)
    SMD
    功率电感 SMD
BCNR3010C-2R2N 数据手册
ROH S Compliant 承 認 書 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N PART NO: DESCRIPTION: PRODUCTS NO: PRODUCTS REV: DATE: SMD POWER INDUCTORS BCNR3010C-2R2M 01 2018-6-7 PURCHASER CONFIRMED. APPROVAL BY CHECK BY DRAWN BY REMARK PROVIDER ENGINEER DEPT. APPROVAL BY CHECK BY Chenlinli 誠 陽 實 業 有 限 公 司 TAIPEI OFF ICE TAIWAN CHENG YANG COMPONENT CORP 2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C) 新北市中和區建一路 176 號 2 樓之一 POSTAL CODE: 23500 TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net 寶 誠 電 子 有 限 公 司 CHINA FACTORY ZHUHAI BAO CHENG ELECTRONICSCO.,LTD Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA 中國廣東省珠海市塘家灣鎮官塘工業區 POSTAL CODE: 519085 TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz 昆 山 誠 陽 電 子 有 限 公 司 KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, China 江蘇省昆山市高科技工業園區強安路 35 號 POSTAL CODE: 215300 TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw [SPECIFICATION] [POWER INDUCTOR] ( BCNR3010C-2R2M) *All the materials used in this product are registered material under the Law Concerning the Examination and Regulation of Manufacture, etc. of Chemical Substances. *This product has not been manufactured with any ozone-depleting chemical controlled under the Montreal Protocol. *All the materials used in this product contain no brominated materials of PBBOs or PBBs as the flame-retardant. * “The Term of Validity” of Product Specifications for Information Unless otherwise requested (including from customer), the term of validity shall be renewed automatically. Then, information and specifications shall be not issued. 1. SCOPE This specification covers the Power Inductor to be delivered to. 2. PART NUMBER OF PRODUCTS This part number of the products in this specification shall be SNR3010F-2R2M-T -PFs. 3. TEST CONDITIONS The ambient temperature shall be 5℃ to 35℃ and the relative humidity 35% to 85%, unless otherwise specified. When the test result is doubtful, the sample in question shall be tested again at 20±2 ℃, 65±5%RH. 4. APPEARANCE DIMENSIONS AND CONSTRUCTION Inductors shall be free from distortion, damage, contaminants, whysker and shall be within dimensions specified. 5. ELECTRICAL CHARACTERISTICS As specified in the electrical characteristics table. 6. RELIABILITY CHARACTERISTICS As specified in the reliability characteristics table. 7. PACKAGE The products shall be packed so as not allow absorption damage. 8. OPERATING TEMPERATURE -40℃~+125℃ 9. OTHERS The customer is requested to store the products at the normal temperature (-5~35℃) and the normal humidity (85%RH max.) in the packages we supplied. The package shall not be exposed to direct sunlight and harmful gas and care should be taken so as not to cause dew. No. Date Revision Check APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] ( BCNR3010C-2R2M) ■ Apperance Dimentions and Construction A= 3.0±0.2 m/m B= 3.0±0.2 m/m C= 1.0 m/m Max D= 1.0 m/m ref ‧ Schematic Diagram ‧ Connection(Bottom View) RoHS Halogen Free ■ Part Number S N R 30 10 F 2R2 M T (1) (2) (2) (3) (4) (5) (6) (7) (8) -PF (19) (1) Product Code: Power Inductor (2) Series Type:QH (3) Size Code: Demension : 3.0 ± 0.2 m/m × 3.0 ± 0.2 m/m (4) Hight: 10= 1.00 m/m Max (5) Material Code: C: Ceramic F: Fritte N:Iron (6) Inductance Code: United is uH and 3 digits are used 860nH=R86 2.2uH=2R2 47uH=470 (7) Tolerance Code: K: ±10% 220uH=221 M: ±20% N: ±30% (8) Outer Coating Resin: Epoxy resin with ferrite powder (9) PF:pb-FREE POE APPROVED CHECKED DRAWN 2012/8/29 [SPECIFICATION] [POWER INDUCTOR] (BCNR3010C-2R2M ) Part No. Inductance H) SNR3010F-2R2M-T-PF 2.2±20% (μ Heat Rating Current (A) Marking Max Test Condition DCR(mΩ) ±30% Rated DC current(A) Max 100kHz,1V 87 0.96 2.00 APPROVED CHECKED DRAWN ■ Note (1) All test date is reternced to 25℃ ambient. (2) Operating temperature range:-40℃ to +125℃ . (3) Isat:DC Current (A) that will cause Lo to drop approximately 30% (4) Irms:DC Current (A) that will cause an approximate △T of 40℃ . ■ Test Eguipment (1) Inductance:LCR test meter:HP4284A (2) DCR test meter:DU5010 (3) Rate current:LCR test meter:Chroma 16502, or equivalent 2R2 [SPECIFICATION] [POWER INDUCTOR] (BCNR3010C-2R2M) ITEM TEST METHOD/CONDITION SPECIFICATION DIELECTRIC STRENGT HWithout damage 100V DC shall be applied for 60s between the INSULATION RESISTANCE 100MΩ or more 100V DC shall be applied between the terminal and the core TEMPERATURE CHARACTERISTICS Must be satisfy electrical characteristics -40~+85℃ Standard: Values at 20℃ HUMIDITY CHARACTERISTICS *There shall not be case deformation or change in HEAT RESISTANCE appearance. *Variation of inductance shall within ±3%. THERMAL SHOCK *Must be satisfy electrical characteristics Inductors shall be stored to 90~95%RH at 60±2℃for 500±8 hours. Measurements shall be made after 1 hour Sstabilization at room temperature. Inductors shall be stored to 85±2℃ for 500±8 hours. Measurements shall be made after 1 hour stabillization at room temperature. Inductors shall be stored 100 times to the following temperature cycle. 1. -40℃, 30 minutes 2. +85℃, 30 minutes Measurements shall be made after 1 hour stabillization at room temperature. Inductors shall be stored to -40+2℃ for 500±8 hours. Measurements shall be made after 1 hour stabillization at room temperature. LOW TEMPARATURE STRAGE HIGH TEMPERATURE LOAD LIFE terminal and the core *There shall not be case deformation or change in appearance. With rated current applied. Indicators shall be stored at 85±2℃ for 500±8 hours. Measurements shall be made after 1 hour stabillization at room temperature. *Variation of inductance shall HUMIDITY LOAD LIFE within ±3%. With rated current applied. Indicators shall be subjected to 90~95%RH *Must be satisfy electrical characteristics at 60±2℃for 500±8 hours. Measurements shall be made after 1 hour stabillization at room temperature. APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] ( SNR3010F-2R2M-T -PF ) BCNR3010C-2R2M ITEM SPECIFICATION 11 -7 TEST METHOD/CONDITION Resistance To Soldering Heat *There shall not be case deformation or change in appearance. The coil shall be passed thruogh the reflow furnace with the condition shown in profile below for 2 times And then the coil shall be subjected to standard atmospheric conditions for 1 to 2 hours after which *Variation of inductance shall be within ±3%. measurement shall be made. For other procedures, refer to IEC Pub. 68-20, Test Tb. *Must be satisfy electrical characteristics. A temperature does a temperature on a board. Vibration Only endurance conditioning by a frequency sweep shall be made. The entire frequency range, from 10 to 55Hz and return to 10Hz, shall be traversed in 1 minute. *Variation of inductance shall be within ±3%. Amplitude (total excursion):1.5mm This motion shall be applied for a period of 2 hours *Must be satisfy electrical characteristics. in each of 3 mutually perpendicular directions (a total of 6 hours). *There shall not be case deformation or change in appearance. Shock Pulse shape:Half sine Peak acceleration:981m/s² (100G) Duration of the pulse:6ms Three successive shocks shall be applied in both directions of 3 mutually perpendicular axis (a total of 6 hours). Terminal Pull Strength There shall not be case deformation or change in appearance. There shall be no evidence of intermittent contact or open circuiting. A 4.9N load shall be applied to both terminals in the horizonal direction for 1±0.05 minutes. Resistance To Solvents There shall not be case deformation or change in appearance. Inductors shall be stored to ISOPROPYL-ALCOHO for 10 minutes respectively. APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] ( SNR3010F-2R2M-T -PF ) 11 -8 BCNR3010C-2R2M ■ Packing ‧Tape Material-Embossed tape ‧Reel size T2 0.8 0.6 0.4 REEL DIMENSIONS UNIT:mm product series W D 180ψ 178±2.0 21.0±0.8 N W RL 07 120900 EIAJ-RRM08B 0.2 T1 C T1 N T2 13.0±0.8 18MAX 50.0MIN 20.5Ttp ‧Leader and Black Portion ‧Taping Dimensions Type W AO BO KO D E F P PO P2 Reel Q’ty(Pcs) Size m/m 2,000 180ψ 4 Reel / Box Q’ty(Pcs) Size m/m 8,000 365×365×90 UNIT:mm SNR3010F 8.0 ± 0.1 3.15 ± 0.1 3.15 ± 0.1 1.10 ± 0.1 1.55 ± 0.05 1.75 ± 0.1 3.50 ± 0.1 4.00 ± 0.1 4.00 ± 0.1 2.0 ± 0.1 2Box / Carton Q’ty(Pcs) Size m/m 16,000 380×380×230 APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] (BCNR3010C-2R2M) ▓ Tearing Off Force The force for tearing off cover tape is 15to 60 grams in the arrow direction under the following conditions. Room Temp. (℃) Room Humidity (%) Room atm (hPa) Tearing Speed mm/min 5~35 45~85 860~1060 300 Application Notice ‧ Storage Conditions To maintain the solderability of terminal electrodes: 1. Temperature and humidity conditions:Less than 40℃ and 70% RH. 2. Recommended products should be used within 6 months from the time of delivery. 3. The packaging material should be kept where no chlorine or sulfur exists in the air. ‧ Transportation 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils. 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. 3. Bulk handling should ensure that abrasion and mechanical shock are minimized. ▓ Void Appearance tolerance Limit A≦ W/2 GOOD A> W/2 NG APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] ( BCNR3010C-2R2M) ITEM CONTENTS 1. FLOW SOLDERING Fow solderong should be conducted at a temperature of 260 ℃ or lower for 6 seconds or less. 2. INFRARED REFLOW SOLDERING Please implement it with the following condition Second reflow soldering should be conducted after PCB cool off. [1] In case of outectic solder Preheat:130~150℃, 60~180s Soldering:200℃min, 70s max. Peak temp.&time:230+/-5℃,5s ※maximum:250+0/-5℃ max. Time: 2times max. SOLDERING [2] In case of lead-less solder Preheat:150~180℃, 60~120s Soldering:230℃min, 40s max. Peak temp.&time:255+/-5℃, 10s ※maximum:260+0/-5℃ 10s max. Time: 2times max. APPROVED CHECKED DRAWN [SPECIFICATION] [POWER INDUCTOR] ( BCNR3010C-2R2M ) PRECAUTION FOR USE OF POWER INDUCTOR ITEM CONTENTS RESOLDERING WITH The temperature of the soldering iron should be 390℃ or less, 5seconds. A SOLDERING IRON And resoldering with a soldering iron should be limited to 1time, and after that should be cooling these. Do not touch the resist of grip inductor with the tip of the soldering iron. RECOMMENDED LAND DIMENTIONS A B C 3.0 1.0 1.0 (m/m ) APPROVED CHECKED DRAWN
BCNR3010C-2R2N 价格&库存
很抱歉,暂时无法提供与“BCNR3010C-2R2N”相匹配的价格&库存,您可以联系我们找货
BCNR3010C-2R2N
    • 5+0.17717
    • 50+0.09427
    • 150+0.04117
    • 500+0.03670
    • 3000+0.03313
    • 6000+0.03133
    库存:164
