MCF-1040-2R2-S1
MCF-1040-2R2-S1
    HOTLAND(合泰盟方)
    SMD,11.2x10mm
    2.2UH ±20%
MCF-1040-2R2-S1 数据手册
    方         合 盟 ※ Application 合 泰 Thin type of on-board power supply module for       合 泰 盟 方 (C)3.5±0.5   (E)0~0.15 泰 盟 方   合   4,1   方     盟 泰 合       ④ Inductance Value:2R2=2.2µH; 方 ⑤ The Material Code; 方 ⑥ Material Type; 盟 泰 合 19 S 1 ⑤ ⑥ 盟 方 盟 泰 -     ④ 泰 2R2     合 方 泰 - 合 1040 ③   方 盟 the diagram above applies to values 0.56uH and below 合 泰 合 - ② ③ Dimensions(unit:mm):10.0x10.0x4.0; 泰 12,2 Suggested pad layout Dimensions are in mm   盟 泰   MC F 4,1 盟 the diagram above applies to values 0.56uH and above The rated current as listed is either the saturation current or the heating current depending on which value is lower. 12,2 Suggested pad layout Dimensions are in mm 方 盟 方 should be verified in the end application. 合 (B)10.0±0.3 5,4         component.PWB trace size and thickness, airflow and other   (D)4.0Max 合 泰 (F)2.0±0.5     125℃ under the worst case operating conditions.Circuit design, cooling provision all affect the part temperature.Part temperature     (C)3.0±0.5 盟 泰 合 合     (E)0~0.15 泰 合 方 盟 方 方   盟 泰 (F)2.0±0.5 5,4 The part temperature (ambient + temp rise ) should not exceed ① (A)11.15±0.35 盟 (B)10.0±0.3 (D)4.0Max               合 合 泰 泰 盟 盟 方 方   (A)11.15±0.35 方         ※ Dimensions in inches (unit:mm) Operat between temperature range -55℃ to +125℃       合 合 Voltage regulator VRM for server 泰 盟 泰 DC/DC converters for laptop motherboards/CPU Isat :DC current (A) that will cause L0 to drop approximately 20% ※ Regulation of Part number 方     盟 方   方 方     100% lead (Pb) free meet RoHS standards Idc: DC current (A) that will cause an approximate △T of 40℃         Low loss and low resistance Test Condition:100KHz,1.0Vrms ② Mold Categories:F;   Low profile:Thickness max.4.0mm All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. Capable of corresponding high frequency (3MHz) 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-1040-XXX-S1 Series
MCF-1040-2R2-S1 价格&库存
很抱歉,暂时无法提供与“MCF-1040-2R2-S1”相匹配的价格&库存,您可以联系我们找货
