CMCW2012F100KTT
CMCW2012F100KTT
    CYBERMAX(思博)
    固定电感器
CMCW2012F100KTT 数据手册
CMCW2012F100KTT 承 认 书 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N: Cybermax P/N: CMCW2012F100KTT DRAWN NO.: CM18102701 DATE: REVISION NO. A 18.10.27 Signature: APPROVED BY Rev.01 CHECKED BY DRAWN BY 黄 谢 申 18.10.27 18.10.27 18.10.27 大燕 焕飞 双凤 Page 1 of 11 www.cybermaxtech.com CMCW2012F100KTT Chang Item DATE Rev.01 Page 2 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F100KTT CM18102701 1/10 18.10.27 SHAPE & DIMENSION (UNIT:mm) Marking Code: PAD LAYOUT(MM): Size: Color: typeface: ELECREICAL SCHEMATIC: ELECREICAL SPECIFICATION MEAS. TEST SPEC. ITEM CONDITIONS FREQ. L 10 µH ± DCR 850 mΩ 30%. 10% 2.5MHz/0.1V Ta=25℃,Idc=0A Ta=25℃ Isat 0.36A MAX (0.43A TYP) 2.5MHz/0.1V △L/L≤30% Irms 0.60AMAX (0.68A TYP) 2.5MHz/0.1V △≦40℃ GENERAL SPECIFICATION Electrical specifications : Operation Temperature: Storage Temperature: at 25℃ -40~+125℃ -40~+125℃ (1)WIRE TYPE:¢0.06mm (2)WINDING:41.5Ts(Ref.) Rev.01 Page 3 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F100KTT CM18102701 PAGE: REVISION: DATE: 2/10 18.10.27 Reliability Test No. 1 2 3 4 Item Temperature Shock. Humidity Resistance. High Temperature Resistance. Low Temperature Resistance. Specification Appearance: No damage. Temperature: -25±2℃~+105±2℃ Kept for 30 minutes. Inductance: within ±10% of Transition time : 5 minutes. initial. 100 Cycles. Appearance: No damage. Temperature: 40±2℃. Inductance: within ±10% of Relative Humidity: 90%. initial. Duration: 500 +4/-0 hours. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. 5 Vibration test. Inductance: within ±10% of initial. Solderability Heat test. Inductance: within ±10% of initial. 7 Solderability test. Temperature: 105±2℃. Duration: 1000 +4/-0 hours. Temperature: -25±2℃. Duration: 1000 +4/-0 hours. Oscillation Frequency: 10Hz to 55Hz to 10Hz in 60 seconds as a period. Total amplitude: 1.5mm. Testing Time: a period of 2 hours in each 3 mutually perpendicular directions (total of 6 hours). Appearance: No damage. 6 Test Method 90% or more of electrode area shall be coated by new solder. Solder temperature: 260 +0/-5℃. Duration: 5 sec. Allowed reflow time: 2 times. Preheating: 160℃,60sec. Solder temperature: 245±5℃. Duration : 5 sec. Flexure: 2mm. 8 Flexure Strength. No visible mechanical damage. Pressurizing Speed: 0.5mm/sec. Keep time: 30±1sec. Force: 0.45Kg for 0603 series. Force: 0.9Kg for 0805 9 Terminal Strength. No visible mechanical damage. series. Force: 1.8Kg for 1008 series above. Keep time: 5 sec,X,Y directs. Rev.01 Page 4 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: Rev.01 CMCW2012F100KTT CM18102701 Page 5 of 11 PAGE: REVISION: DATE: 4/10 18.10.27 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F100KTT CM18102701 PAGE: REVISION: DATE: 5/10 18.10.27 B.O.M 项目名称 磁芯(DRUM CORE) 线材(WIRE) 胶水(GLUE) Rev.01 型号及规格 MF401 SWI2012C075-LS P180G1-0.06mm UW-523 Page 6 of 11 制造商 台湾佳叶/台湾光绅 益利素勒 贺盛 环保要求 RoHS RoHS RoHS 备注 主选 主选 灌封 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F100KTT CM18102701 PAGE: REVISION: DATE: 6/10 18.10.27 Isat(飽和電流):電感瞬間的突波電流 TME(秒) Rev.01 CMCW2012F100KTT Lsat(A) L(UH) △L/L(%) 1 0.000 10.00 0.00% 1 0.0485 10.00 0.00% 1 0.0970 10.00 0.00% 1 0.1455 9.93 -0.70% 1 0.1940 9.93 -0.70% 1 0.2425 9.75 -2.50% 1 0.2910 9.53 -4.70% 1 0.3395 9.10 -9.00% 1 0.3880 8.65 -13.50% 1 0.4365 7.95 -20.50% 1 0.4850 5.84 -41.60% Page 7 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F100KTT CM18102701 7/10 18.10.27 單點溫昇 TIME(S) Irms(A) 30 0.000 9.99 0.00% 30.0 0.0 30 0.0485 9.98 -0.10% 30.0 0.0 30 0.0970 9.98 -0.10% 30.0 0.0 30 0.1455 9.97 -0.20% 31.0 1.0 30 0.1940 9.96 -0.30% 32.0 2.0 30 0.2425 9.96 -0.30% 33.0 3.0 30 0.2910 9.93 -0.60% 34.0 4.0 30 0.3395 9.86 -1.30% 36.0 6.0 30 0.3880 8.96 -10.31% 38.0 8.0 30 0.4365 8.03 -19.62% 42.0 12.0 30 0.4850 5.68 -43.14% 46.0 16.0 ※DC bias current characteristics in the Rev.01 CMCW2012F100KTT L(uH) ΔL/L(%) Temp(℃) ΔT(℃) ambient temperature 25℃ Frequency 2.5MHz/0.1V Page 8 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F100KTT CM18102701 8/10 18.10.27 TEST DATA FOR PREPRODUCTION SAMPLE TEST RESOLUTION MEAS. L D.C.R ITEM µH mΩ 10 850 ± ± 10% 30% SPEC. TEST FREQ. Isat 2.5MHz/0.1V 0.36A DIMENSION (Unit:mm) 长 宽 高 Max.2.4 Max.1.73 1.3±0.1 △L/L≦30% 1 10.0 966 9.23 -7.7% 2.25 1.63 1.27 2 9.94 962 9.25 -6.9% 2.26 1.64 1.27 3 10.2 954 9.45 -7.4% 2.22 1.65 1.26 4 10.1 962 9.40 -6.9% 2.26 1.64 1.29 5 9.96 958 9.30 -6.6% 2.24 1.62 1.24 6 10.1 961 9.48 -6.1% 7 10.0 958 9.35 -6.5% 8 10.1 962 9.42 -6.7% 9 10.1 965 9.46 -6.3% 10 10.3 963 9.38 -8.9% AVG. 10.080 961.1 9.372 -7.02% R 0.36 12 1.60 -4.20% APPROVED BY CHECKED BY 黄 17.07.10 大燕 Rev.01 Page 9 of 11 DRAWN BY 谢 申 17.01.10 17.07.10 焕飞 双凤 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F100KTT CM18102701 PAGE: REVISION: DATE: 9/10 18.10.27 PACKAGING 热封包装 Rev.01 Page 10 of 11 www.cybermaxtech.com CMCW2012F100KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F100KTT CM18102701 10/10 18.10.27 PACKAGING 1.1 外箱: 36*36*23 cm 一箱裝 2 內箱 1.2 內箱: 33.5*33.5*9 cm 一箱装 4 卷制品 1.3 外箱材質: A 三 A 1.4 內箱材質: A=A 1.5 每一卷制品用一只静电袋包裝 1.6 每一静电袋內放一只袋干燥剂 1.7 每一卷上面依标签样式的要求贴上标签明细 1.8 出货內外箱贴上该箱內实际內容明细 1.9 出货标签规格如下: 尺寸=长度:39mm 宽度:29mm (如: 客戶有特殊要求時, 則依客戶要求實施.) 备注:如果捆包数量小于内箱捆包数量时就用内箱包装 Rev.01 Page 11 of 11 www.cybermaxtech.com
CMCW2012F100KTT 价格&库存
很抱歉,暂时无法提供与“CMCW2012F100KTT”相匹配的价格&库存,您可以联系我们找货
CMCW2012F100KTT
    • 10+0.40392
    • 100+0.32357
    • 300+0.28340
    • 2000+0.23296
    • 4000+0.20877
    • 10000+0.19678
    库存:39
