CMCW2012F220KTT
CMCW2012F220KTT
    CYBERMAX(思博)
    固定电感器
CMCW2012F220KTT 数据手册
CMCW2012F220KTT 承 认 书 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N: Cybermax P/N: CMCW2012F220KTT DRAWN NO.: CM190705001 DATE: REVISION NO. A 19.07.05 Signature: APPROVED BY Rev.01 CHECKED BY DRAWN BY 黄 谢 申 19.07.05 19.07.05 19.07.05 大燕 焕飞 双凤 Page 1 of 11 www.cybermaxtech.com CMCW2012F220KTT Chang Item DATE Rev.01 Page 2 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F220KTT CM190705001 PAGE: REVISION: DATE: 1/10 19.07.05 SHAPE & DIMENSION (UNIT:mm) Marking Code: PAD LAYOUT(MM): Size: Color: typeface: ELECREICAL SCHEMATIC: ELECREICAL SPECIFICATION MEAS. SPEC. ITEM CONDITIONS TEST FREQ. L 22 µH ± 10% DCR 1.76 Ω ± 30% 2.5MHz/0.1V Ta=25℃,Idc=0A Ta=25℃ Isat 0.24AMAX(0.3ATYP) 2.5MHz/0.1V △L/L≤30% Irms 0.34AMAX(0.45ATYP) 2.5MHz/0.1V △T≤40℃ GENERAL SPECIFICATION Electrical specifications : Operation Temperature: Storage Temperature: at 25℃ -40~+125℃ -40~+125℃ (1)WIRE TYPE:¢0.05mm (2)WINDING:61.5Ts(Ref.) Rev.01 Page 3 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F220KTT CM190705001 PAGE: REVISION: DATE: 2/10 19.07.05 Reliability Test No. 1 2 3 4 Item Temperature Shock. Humidity Resistance. High Temperature Resistance. Low Temperature Resistance. Specification Appearance: No damage. Temperature: -25±2℃~+105±2℃ Kept for 30 minutes. Inductance: within ±10% of Transition time : 5 minutes. initial. 100 Cycles. Appearance: No damage. Temperature: 40±2℃. Inductance: within ±10% of Relative Humidity: 90%. initial. Duration: 500 +4/-0 hours. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. Inductance: within ±10% of initial. Appearance: No damage. 5 Vibration test. Inductance: within ±10% of initial. Solderability Heat test. Inductance: within ±10% of initial. 7 Solderability test. Temperature: 105±2℃. Duration: 1000 +4/-0 hours. Temperature: -25±2℃. Duration: 1000 +4/-0 hours. Oscillation Frequency: 10Hz to 55Hz to 10Hz in 60 seconds as a period. Total amplitude: 1.5mm. Testing Time: a period of 2 hours in each 3 mutually perpendicular directions (total of 6 hours). Appearance: No damage. 6 Test Method 90% or more of electrode area shall be coated by new solder. Solder temperature: 260 +0/-5℃. Duration: 5 sec. Allowed reflow time: 2 times. Preheating: 160℃,60sec. Solder temperature: 245±5℃. Duration : 5 sec. Flexure: 2mm. 8 Flexure Strength. No visible mechanical damage. Pressurizing Speed: 0.5mm/sec. Keep time: 30±1sec. Force: 0.45Kg for 0603 series. Force: 0.9Kg for 0805 9 Terminal Strength. No visible mechanical damage. series. Force: 1.8Kg for 1008 series above. Keep time: 5 sec,X,Y directs. Rev.01 Page 4 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: Rev.01 CMCW2012F220KTT CM190705001 Page 5 of 11 PAGE: REVISION: DATE: 4/10 19.07.05 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F220KTT CM190705001 PAGE: REVISION: DATE: 5/10 19.07.05 B.O.M 项目名称 磁芯(DRUM CORE) 线材(WIRE) 胶水(GLUE) Rev.01 型号及规格 MF401 SWI2012C075-LS P180G1-0.05mm UW-523 Page 6 of 11 制造商 台湾佳叶/台湾光绅 益利素勒 贺盛 环保要求 RoHS RoHS RoHS 备注 主选 主选 灌封 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F220KTT CM190705001 PAGE: REVISION: DATE: 6/10 19.07.05 Isat(飽和電流):電感瞬間的突波電流 CMCW2012F220KTT Rev.01 TME(秒) Lsat(A) L(UH) △L/L(%) 1 0.000 22.60 0.00% 1 0.034 22.60 0.00% 1 0.068 22.60 0.00% 1 0.102 22.50 -0.44% 1 0.136 22.40 -0.88% 1 0.170 22.10 -2.21% 1 0.204 21.50 -4.87% 1 0.238 20.50 -9.29% 1 0.272 19.40 -14.16% 1 0.306 16.90 -25.22% 1 0.340 12.80 -43.36% Page 7 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F220KTT CM190705001 7/10 19.07.05 單點溫昇 CMCW2012F220KTT TIME(S) Irms(A) L(uH) ΔL/L(%) Temp(℃) 30 0.000 22.80 0.00% 31.0 0.0 30 0.049 22.60 -0.88% 31.0 0.0 30 0.098 22.30 -2.19% 31.0 0.0 30 0.147 21.90 -3.95% 33.0 2.0 30 0.196 21.50 -5.70% 35.0 4.0 30 0.245 19.80 -13.16% 39.0 8.0 30 0.294 15.70 -31.14% 43.0 12.0 30 0.343 9.05 -60.31% 49.0 18.0 30 0.392 4.96 -78.25% 57.0 26.0 30 0.441 3.54 -84.47% 68.0 37.0 30 0.490 3.13 -86.27% 83.0 52.0 ※DC bias current characteristics in the Rev.01 ΔT(℃) ambient temperature 25℃ Frequency 2.5MHz/0.1V Page 8 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F220KTT CM190705001 8/10 19.07.05 TEST DATA FOR PREPRODUCTION SAMPLE TEST RESOLUTION DIMENSION (Unit:mm) MEAS. L D.C.R 长 宽 高 ITEM µH Ω mm mm mm 22 1.76 ± ± Max.2.4 Max.1.73 1.3±0.1 10% 30% SPEC. TEST FREQ. Isat 2.5MHz/0.1V 0.24A △L/L≦30% 1 22.6 1.98 20.5 -9.3% 2.22 1.63 1.28 2 23.2 1.98 21.2 -8.6% 2.23 1.69 1.29 3 22.9 1.98 20.5 -10.5% 2.27 1.68 1.31 4 22.8 1.97 20.3 -11.0% 2.24 1.64 1.29 5 23.3 1.98 21.5 -7.7% 2.28 1.62 1.24 6 22.8 1.98 21.0 -7.9% 7 22.7 2.00 20.5 -9.7% 8 22.6 1.99 20.3 -10.2% 9 21.8 1.98 20.0 -8.3% 10 22.0 2.00 20.3 -7.7% AVG. 22.670 2.0 20.610 -9.08% R 1.5 0.03 1.60 -4.20% APPROVED BY CHECKED BY 黄 19.07.05 大燕 Rev.01 Page 9 of 11 DRAWN BY 谢 申 19.07.05 19.07.05 焕飞 双凤 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: CMCW2012F220KTT CM190705001 PAGE: REVISION: DATE: 9/10 19.07.05 PACKAGING 热封包装 Rev.01 Page 10 of 11 www.cybermaxtech.com CMCW2012F220KTT CUSTOMER: CUSTOMER P/N: Cybermax P/N: DRAWN NO.: PAGE: REVISION: DATE: CMCW2012F220KTT CM190705001 10/10 19.07.05 PACKAGING 1.1 外箱: 39*38*18.5 cm 一箱裝 8 內箱 1.2 內箱: 18.7*18.4*8.3 cm 一箱装 5 卷制品 1.3 外箱材質: A 三 A 1.4 內箱材質: A=A 1.5 每 5 卷制品用一只静电袋包裝 1.6 每一静电袋內放一只袋干燥剂 1.7 每一卷上面依标签样式的要求贴上标签明细 1.8 出货內外箱贴上该箱內实际內容明细 1.9 出货标签规格如下: 尺寸=长度:39mm 宽度:29mm (如: 客戶有特殊要求時, 則依客戶要求實施.) 备注:如果捆包数量小于内箱捆包数量时就用内箱包装 Rev.01 Page 11 of 11 www.cybermaxtech.com
CMCW2012F220KTT 价格&库存
很抱歉,暂时无法提供与“CMCW2012F220KTT”相匹配的价格&库存,您可以联系我们找货
CMCW2012F220KTT
    • 10+0.40803
    • 100+0.32768
    • 300+0.28750
    • 2000+0.23296
    • 4000+0.20877
    • 10000+0.19678
    库存:1013
