3225-32M-20PF-20PPM
3225-32M-20PF-20PPM
    TKD(泰晶)
    SMD3225_4P
    无源晶振 SMD3225_4P
3225-32M-20PF-20PPM 数据手册
HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 1 of 7 CRYSTAL SEPECIFICATION Customer : Customer P/N : Part Name : 3225 32M 20PF 20PPM Product Description : 3225-32MHz-20PF- 20PPM Issue Date : 2017.03.01 CUSTOMER’S APPROVAL (PLEASE RETURN A COPY WITH APPOVAL Hubei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 APPROVED SALE:TEL :0722-3309660 FAX :0722-3309768 QCD:TEL :0722-3308231 FAX :0722-3309768 FAE:TEL :0755-27328651 FAX :0755-27328001 DESIGNER HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 2 of 7 REV. Description of Revision History Date Designer Checked By A New revision 2014 年 10 月 30 日 Feng Huang xm liu HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 3 of 7 CRYSTAL SEPECIFICATION 1. 2. 3. 4. 5. 6. Description: Quartz Crystal Nominal Frequency: 32.000000MHz Oscillation Mode: Fundamental Cutting Mode: AT cut Measurement Instrument: S&A 250B(Measured FL) Electrical Characteristics: [1]Operation Conditions: Item Symbol MIN. Operating Temperature Range Topt Storage Temperature Range Tstg Load Capacitance CL Drive Level DL TYP. MAX. Unit -20 75 ℃ -40 85 ℃ 20 Condition pF 100 uW MAX. Unit Condition [2]Frequency Stability: Item Symbol MIN. TYP. Tolerance dF/Fo -20 20 ppm Refer to Center Frequency@25±3℃ Stability Over Temperature dF/F25 -20 20 ppm Refer to Operating Temperature Aging dF/F25 -3 3 ppm Per Year MAX. Unit ESR 40 Ω Shunt Capacitance C0 5 pF Insulation Resistance IR dF/Fo:Frequency Deviation Refer to Center Frequency dF/F25:Frequency Deviation Refer to 25℃ Frequency [3]Electrical Performance: Item Equivalent Series Resistance 7. Symbol MIN. TYP. 500 Marking:Laser 一般频率(MHz) Eg32.=32.000000MHz 32.000 T YM Y: Year code M:Month code TKD Year : 1 2 3 4 5 6 7 8 9 0 Month : 1 2 3 4 5 6 7 8 9 10 11 12 Code: A B C D E F G H J K L M MΩ Condition @Series @DC 100 Volt HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 4 of 7 8. Outline drawing (unit:mm)       9.内部结构以及材料清单  No. NAME 材料/規格 1 LID 锌白铜(表面镀镍) 2 BASE 陶瓷 6 BLANK SiO2(二氧化硅) 7 Adhesive XA-819A(树脂+银粉) 8 BLANK BP MASK Ag(纯银) HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 5 of 7 10.Reliability Specification Test Item Condition of test Performance Requirements Endurance condition by a frequency sweep shall be made. The entire frequency range from 10HZ to 55HZ and return to 10HZ,shall be transverseb in 1min. Amplitude(total excursion):1.5mm this motion shall be applied for a period of 2h each of 3 mutually perpendicular axes(a total of 6h) (1).Frequency Change:±5ppm (2).Resistance:±15% Form 75cm height 3 times on 3cm hard wooden floor (1).Frequency Change:±5ppm (2).Resistance:±15% Salt mist Concentration:5%,Temperature:25℃,TIME:36h No rust Damp heat The unit shall be stored at a temperature of 60±2℃with relative humidity of 90%to95% for 240h, then it shall be subjected to standard atmospheric conditions for 1 ~ 2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Dry heat The unit shall be stored at a temperature of 85℃±5℃ for 240h, then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Cold The unit shall be stored at a temperature of-40℃±5℃ for 240h, then it shall be subjected to standard atmospheric conditions for 1~2h after which measurement shall be made. (1).Frequency Change:±5ppm (2).Resistance:±15% Aging Voltage:5V,Temperature:25℃,TIME:1000h (1).Frequency Change:±5ppm (2).Resistance:±15% The unit shall be subjected to 25 successive change of temperature cycles, each as show in table below,then it shall be subjected to standard atmospheric conditions for 1 ~ 2h after which measurement shall be made (1).Frequency Change:±5ppm (2).Resistance:±15% Vibration Drop Temperature cycling Temperature Duration 1 -40℃±3℃ 30min 2 Standard atmospheric conditions Within 30s 3 85℃±3℃ 30min 4 Standard atmospheric conditions Within 30s HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 6 of 7 Test Item Sealing Condition of test He:5±0.5Kg/cm2,TIME:120min Resistance to soldering heat Performance Requirements Leakage rate< 1*10-9Pa.m3/s (1).Frequency Change:±5ppm (2).Resistance:±15% Reflow soldering cure see the chart. HuBei TKD Electronic Technology Co.,LTD 湖北泰晶电子科技股份有限公司 page 7 of 7 11.Packing Desrciption
3225-32M-20PF-20PPM 价格&库存
很抱歉,暂时无法提供与“3225-32M-20PF-20PPM”相匹配的价格&库存,您可以联系我们找货
