RPL121M2WBKF1840
RPL121M2WBKF1840
    LELON(立隆电子)
    插件,D18xL40mm
    直插铝电解电容 AEC_D18X40MM_TM
RPL121M2WBKF1840 数据手册
Aluminum Electrolytic Capacitors RPL Features ‧ 105℃, 5,000 hours assured ‧ φ10 ~ φ18 with large permissible ripple current ‧ Pen type included ‧ RoHS Compliance Sleeve & Marking Color: Black & Golden SPECIFICATIONS Items Category Temperature Range Performance 400V -40℃ ~ +105℃ 420 ~ 450V -25℃ ~ +105℃ (at 120Hz, 20℃) ±20% Capacitance Tolerance Time Leakage Current (at 20℃) Dissipation Factor (Tanδat 120Hz, 20℃) Low Temperature Characteristics (at 120Hz) Endurance Shelf Life Test Ripple Current & Frequency Multipliers 2011 Version after 5 minutes CV > 1,000 CV ≦ 1,000 Leakage Current I = 0.03CV + 15(µA) I = 0.02CV + 25(µA) Where, C = rated capacitance in µF V = rated DC working voltage in V Rated Voltage Tanδ(max) 400 0.24 420 0.24 450 0.24 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 400 420 450 Z(-25)/Z(+20℃) Impedance 5 6 6 Z(-40)/Z(+20℃) Ratio 6 - Test Time 5,000 Hrs Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20°C after the rated voltage applied with rated ripple current for 5,000 hours at 105°C. Test Time 1,000 Hrs Capacitance Change With in ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Frequency (Hz) Multipliers 60 0.80 120 1.00 500 1.25 1k 1.40 10k up 1.50 Aluminum Electrolytic Capacitors RPL DIAGRAM OF DIMENSIONS φD P 15 min PET Sleeve Unit: mm LEAD SPACING AND DIAMETER φD+βMax φd L+α Max 4 min 10φ 400V (2G) 12.5φ Cap. (μF) φD×L 33 10× 35 320 480 39 10× 40 380 570 47 10× 45 425 638 56 10× 50 490 735 Ripple Current φD×L 120 Hz 100k Hz 16φ Ripple Current φD×L 120 Hz 100k Hz 12.5× 30 380 570 12.5× 35 475 713 68 12.5× 40 550 82 12.5× 45 615 100 12.5× 50 690 φD×L 120 Hz 100k Hz Ripple Current 120 Hz 100k Hz 400 600 825 16× 31.5 530 795 923 16× 35.5 605 908 1,035 16× 40 740 1,110 18× 31.5 625 938 16× 45 795 1,193 18× 35.5 730 1,095 18× 45 910 1,365 33 10× 40 350 525 39 10× 45 390 585 12.5× 30 380 570 47 10× 50 445 668 12.5× 35 410 615 16× 25 370 555 56 12.5× 40 490 735 16× 31.5 475 713 68 12.5× 45 560 840 16× 35.5 550 825 82 12.5× 50 625 938 16× 40 630 945 18× 31.5 570 855 100 16× 45 750 1,125 18× 35.5 675 1,013 120 16× 50 865 1,298 150 450V (2W) 18× 45 825 1,238 18× 50 950 1,425 825 33 10× 40 350 525 12.5× 30 350 525 39 10× 45 390 585 12.5× 35 400 600 16× 25 370 555 47 10× 50 445 668 12.5× 40 425 683 16× 31.5 455 683 12.5× 45 500 750 16× 35.5 560 750 16× 40 590 885 18× 31.5 550 16× 45 675 1,013 18× 35.5 645 968 16× 50 785 1,178 18× 40 740 1,110 18× 45 825 1,238 18× 50 950 1,425 56 68 82 12.5× 50 625 938 100 120 150 Remark: Other sizes and specification are available, please contact us for detail. 18 7.5 0.8 18φ Ripple Current 150 420V (2P) 16 2.5 0.5 16× 25 120 12.5 5.0 0.6 Dimension: φD × L(mm) Ripple Current: mA/rms at 105°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 10 φd α β P±0.5 Vent≧10φ 2011 Verison
RPL121M2WBKF1840 价格&库存
很抱歉,暂时无法提供与“RPL121M2WBKF1840”相匹配的价格&库存,您可以联系我们找货
RPL121M2WBKF1840
  • 1+15.22800
  • 10+12.88440
  • 30+11.41560
  • 150+9.91440
  • 450+9.24480
库存:454
