SPECIFICATION FOR APPROVAL
产品规格承认书
SMD POWER INDUCTOR
功率电感
CUSTOMER.
MODEL NO.
MPA5040S6R8M
CUSTOMER'S PART NO.
LILE NO.
DATE.
2019.7.1
REVISION.
A/0
CUSTOMER APPROVE
DATE:
DRAWING
DRAWN BY
CHECK BY
APPROVAL BY
DATE:
深圳市迈翔科技有限公司
SHENZHEN MOTTO TECHNOLOGY Co., Ltd
香港瑞德科技有限公司
黄冈市迈翔电子有限公司
Motto Technology park, niu e ling village no#214 xintian,nghua Town,
Guanlan Street, Longhua District,Shenzhen
TEL: +86 0755-8948751~2 89487610 Fax: +86 0755-61624574
IATF16949 / ISO9001 / ISO14000
Http://www.coilmx.com
E-mail: sales@mottotech.com
1/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
REVISIONS
REW
PROJECT CHANGE
DESCRIPTION
Date
2/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
1.PRODUCT DIMENSION
UNIT:mm
A
5.00±0.20
B
5.00±0.20
C
4.10MAX
D
2.0±0.3
E
1.50±0.3
2.ELECTRICAL REQUIREMENTS
PARAMETER
SPECIFICATION
CONDITION
TEST INSTRUMENTS
L( uH)
6.8±20%
100KHz/1.0V
MICROTEST 6377
DCR(mΩ)
55.9MAX
At 25℃
TH2512A
I sat(A)
2.9A TYP L0A* 70%
100KHz/1.0V
MICROTEST 6377+6220
Irms(A)
2.5A TYP ΔT≦40℃
100KHz/1.0V
MICROTEST 6377+6220
3.CHARACTERISTICS
(1). All test data is based on 25℃ ambient.
(2). DC current(A)that will cause an approximate △T40℃
(3). DC current(A)that will cause L0 to drop approximately 10%Typ
(4). Operating temperature range: -55℃~+125℃
(5).The part temperature (ambient + temp rise)should not exceed 125℃ under worst case operating
conditions. circuit design, component.PWB trace size and thickness,airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the den application
4.SPECIAL REQUEST
(1)Lettering 331 on top of the body.
3/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
5.PRODUCT IDENTIFICATION
XX
XXXX
①
①、 Product Symbol
②
S
XXX
X
③
④
⑤
②、 Dimensions
③、 material class number
④、 Inductance ⑤ 、Tolerance: M±20%, N±30%.
6.ELECTRICAL SCHEMATICS
7.APPLICATION
(1)Low profile,high current power supplies.
(2)Battery powered devices.
(3)DC/DC converters in distributed power systems.
(5)DC/DC converters for field programmable gate array.
8.FEATURES
(1)ROHS compliant.
(2)Super low resistance,ultra high current rating.
(3)high performance(I sat)realized by metal dust core.
(4)Frequency Range:up to 1MHZ.
9.RECOMMENDED PCB LAYOUT
4/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
SORT
PRODUCT&
DIMENSION
ELECTRICAL
& REQUIREME
NTS
MPA5040S6R8M
ITEM
A
B
C
D
SPEC
5.00±0.20
5.00±0.20
4.10MAX
2.0±0.3
1
5.01
4.97
3.89
2.02
2
4.99
4.95
3.83
2.01
3
5.01
5.01
3.85
2.00
4
4.99
4.99
3.83
2.01
5
5.03
4.99
3.94
2.06
X
5.01
4.98
3.87
2.02
R
0.04
0.06
0.11
0.06
ITEM
L(uH)
DCR
( mΩ)
I sat(A)
Irms(A)
SPEC
6.8±20%
55.9MAX
1
5.68
43.21
94.00
OK
2
5.85
44.41
94.00
OK
3
5.91
43.99
94.00
OK
4
5.71
42.76
94.00
OK
5
5.71
44.15
93.00
OK
X
5.77
43.70
93.80
R
0.23
1.65
1.00
REVISION
A/0
DATE
2019.7.1
SHAPE:
2.9A TYP 2.5A TYP Δ
L0A* 70%
T≦40℃
5/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
项目Item
规格与需求
Specification and Requirement
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
3
沾锡面积不得小于95%上锡面
可焊性
Solder a bility test
振动测试
Vibration test
冲击测试
Shock test
冷热冲击
Thermal shock
Terminals area must have 95% min solder
coverage
感值变化:不超过±5%
且无破裂等机械损伤产生
Inductance change: Within±5% Without
mechanical damage such as break
感值变化:不超过±5%
且无破裂等机械损伤产生
感值变化:不超过±5%
且无破裂等机械损伤产生
测试方法Test Method
上锡升温曲线Solder heat proof:
(1) 预热:160±10℃持续90s
Preheating: 160±10℃ for 90 seconds
(2) 恒温时段:245±5℃持续2±0.5s
Retention time: 245±5℃ for 2±0.5 seconds
(1) 振动频率(10Hz 55Hz 10Hz)60s为一个周期 Vibration
frequency: (10Hz to 55Hz to 10Hz) in 60 seconds as a period
(2) 振动时间 Vibration time:
三维正交坐标系每个方向振动(周期) 循环2小时 Period cycled
for 2 hours in each of 3 mutual
perpendicular directions
(3) 振幅 Amplitude: 1.5 mm Max
(1) 最大振幅 Peak value: 100G
(2) 脉冲波长 Duration of pulse: 11ms
(3) 三维正交坐标系每个方向正负方向冲击3次 Times in each
positive and negative direction of 3 mutual perpendicular directions
(1)重复以上100个循环Repeat 100 cycle as follow
(-55±2℃,30±3分钟)
室温5分钟
(-55±2℃,30±3 minutes)
Room temperature,5 minutes
(+125±2℃,30±3分钟) 室温5分钟
(+125±2℃,30±3 minutes)
(2)恢复:测试于标准条件下恢复48+4/-0小时 (参考注释1)
Recovery:48+4/-0 hours of recovery under the standard condition
after the test. (see Note1)
感值变化:不超过±5%
耐高温测试
且无破裂等机械损伤产生
High temperature life
test
(1)环境条件:85±2℃
Environment condition : 85±2℃
应用电流:额定电流
Applied current: Rated current
(2)持续时间:1000+4/-0 小时(参考注释1)
Duration:1000+4/-0 hours (see Note1)
感值变化:不超过±5%
耐湿测试
且无破裂等机械损伤产生
Humidity Resistance Inductance change: Within±5% Without
(1)环境条件:60±2℃
Environment condition : 60±2℃
湿度:90~95%
Humidity:90~95%
应用电流:额定电流
感值变化:不超过±5%
低温存放测试Low 且无破裂等机械损伤产生
temperature life test Inductance change: Within±5% Without
(1)存储温度 Store temperature
-55±2℃下存放 1000+4/-0 小时
-55±2℃for total 1000+4/-0 hours
感值变化:不超过±5%
高温存放测试High 且无破裂等机械损伤产生
+125±2℃下存放 1000+4/-0 小时
+125±2℃for total 1000+4/-0 hours
6/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
12、包装 Packaging
12.1、尺寸 Dimensions
12.1.1 包装料带尺寸 Tape packaging dimensions
W
A0
B0
K0
E
F
P
D0
P0
T
12.0
±0.30
15.4
±0.10
5.4
±0.10
4.4
±0.10
1.75
±0.10
5.5
±0.1
8.0
±0.10
1.5
±0.10
4.0
±0.10
0.40
±0.05
12.1.2 卷轴尺寸 Reel dimensions
项目
尺寸(mm)
A
330± 1.0
B
100± 1.0
C
13.0 ±0.5
G
13.0± 0.5
项目
数量(PCS)
1卷轴
1500
12.1.3 外箱尺寸Carton dimensions
1内箱
1外箱
7/8
深圳市迈翔科技有限公司
CUSTOMER
MODEL NO.
FILE NO.
PART NO.
MPA5040S6R8M
REVISION
A/0
DATE
2019.7.1
Reflow curve
※ Reflow Profile
1. Reflow Soldering Method
2. Soldering iron method :350±5℃ Max.3 seconds.
8/8
很抱歉,暂时无法提供与“MPA5040S6R8M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.80433
- 50+0.63958
- 150+0.55725
- 1500+0.47735
- 3000+0.42788
- 4500+0.40319
