MCW-0630-5R6-N2
MCW-0630-5R6-N2
    HOTLAND(合泰盟方)
    SMD,7x6.6mm
    5.6UH ±20%
MCW-0630-5R6-N2 数据手册
    方         合 Low profile:Thickness max.3.0mm Low loss and low resistance     泰 盟 方   合   盟 方 泰 合   方 盟 泰 合     方 泰 盟 盟 ⑥ Material Type; 方 ⑤ The Material Code; 泰 方 6 ④ Inductance Value:2R2=2.2µH; 合       ⑤ ⑥ 合 N 2   -   2R2 盟 泰 3,5 方 盟 泰 泰 合   合 盟 方 ③ Dimensions(unit:mm):6.0x6.0x3.0; 泰 -   ④     0630   ③ 合 盟 泰 合   -           方 Suggested pad layout Dimensions are in mm The rated current as listed is either the saturation current or the   3,7 8,4 盟 方 should be verified in the end application.     盟 方 泰 合 合       cooling provision all affect the part temperature.Part temperature           MC W    ① ② (E)0~0.15 盟 泰 合       方 盟 泰 泰 合     125℃ under the worst case operating conditions.Circuit design, component.PWB trace size and thickness, airflow and other (C)3.0±0.3 (D)3.0Max (B)6,6±0.2   方 泰 盟 合     方   盟 (F)1,6±0.3 The part temperature (ambient + temp rise ) should not exceed heating current depending on which value is lower. 方   (A)6.95±0.35       方 盟 泰 合         合 合 泰 合   ※ Dimensions in inches (unit:mm) Operat between temperature range -55℃ to +125℃ ※ Regulation of Part number 泰 盟 泰 Thin type of on-board power supply module for Isat :DC current (A) that will cause L0 to drop approximately 30%     盟 方   盟 DC/DC converters for laptop motherboards/CPU Idc: DC current (A) that will cause an approximate △T of 40℃   方     方     方 ※ Application Voltage regulator VRM for server Test Condition:100KHz,1.0Vrms ② Mold Categories:W;       Capable of corresponding high frequency (1MHz) All test data is reference to 25℃ ambient. ① Molding Choke; 合 泰 盟   合 High performance (Isat) realizde by metal dust core. 100% lead (Pb) free meet RoHS standards 盟 合 泰         泰 盟 泰 合     方   盟 方 ※Note: 方 ※ Features 方   泰 盟 方 盟 方           方 盟 www.sz-hotland.com     MCW-0630-XXX-N2 Series
MCW-0630-5R6-N2 价格&库存
很抱歉,暂时无法提供与“MCW-0630-5R6-N2”相匹配的价格&库存,您可以联系我们找货
