CN035M220LO5*11L-1A4T
    BERYL(绿宝石)
    插件,D5xL11mm
    贴片铝电解电容 AEC_D5X11MM_TM
CN035M220LO5*11L-1A4T 数据手册
CN ● Series Low impedance, high ripple current, high voltage, high temperature resistant ● Load life of 2000 hours at 125℃ ● RoHS Compliant ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperture Range -55 ~ +125℃ 额定工作电压范围 Rated Voltage Range 35 ~ 250 V 静电容量允许偏差 Capacitance tolerance ±20%(M) (at 20℃,120Hz) 漏电流 Leakage Current 施加额定工作电压2分钟后读数,小于或等于规格值 (20℃) I≤0.15CV 或120μA(取大值)(The bigger) After 2 minutes applied for rated voltage at 20℃, less than or equal to the specified value. 损耗角正切值tanδ Dissipation Factor 小于或等于规格 Less than or equal to the specified 温度特性 Low Temperture Characteristics (Max.Impedance Ratio) 耐久性 Endurence Damp Heat (Steady State) 耐湿负荷特性 浪涌电压特性 (Surge Voltage) (at 20℃,120Hz) Z(-25℃)/Z(+20℃) ≤1.25 Z(-55℃)/Z(+20℃) ≤1.25 (100KHz) 125℃施加额定工作电压 2000小时,恢复到 20℃后,产品性能应满足以下要求 The specifications listed below shall be met when thecapacitors are restored to 20°C after the rated voltage is applied for 2000 hours at 125℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be met when the capacitors are restored to 20°C after the rated voltage is applied for 1000 hours at 60℃, 90%~ 95% RH. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 浪涌电压=额定电压* 1.15(V) Surge Voltage=Rated voltage * 1.15(V) 在125℃环境中,按充电30秒,放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求 The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 125℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value ◆ 外形图Dimensions (mm) t ΦD 5 6.3 8 10 P 2 2.5 3.5 5 Φd 0.5 0.5 0.6 0.6 ɑ L
CN035M220LO5*11L-1A4T 价格&库存
很抱歉,暂时无法提供与“CN035M220LO5*11L-1A4T”相匹配的价格&库存,您可以联系我们找货
  • 5+1.48025
  • 50+1.22881
  • 150+1.12100
  • 1000+0.98651
  • 2000+0.92663
  • 5000+0.89072
库存:2719
