OCR221M1CBK-1010
OCR221M1CBK-1010
    LELON(立隆电子)
    插件,D10xL10mm
    贴片铝电解电容 AEC_D10X10MM_TM
OCR221M1CBK-1010 数据手册
Organic Conductive Polymer Capacitors OCR Features ‧ 105℃, 2,000 hours assured ‧ Ultra low ESR with large permissible ripple current ‧ RoHS Compliance Marking color: Blue SPECIFICATIONS Items Category Temperature Range Capacitance Tolerance Performance -55℃ ~ +105℃ ±20% (at 120Hz, 20℃) Rated voltage applied, after 2 minutes at 20℃. See Standard Ratings Leakage Current (at 20℃ )* Dissipation Factor (Tanδ at 120Hz, 20℃ ) ESR (at 100k ~ 300k Hz, 20℃ ) See Standard Ratings See Standard Ratings Test Time 2,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000 hours at 105℃. Endurance Test Time 1,000 Hrs Within ±20% of initial value Capacitance Change Dissipation Factor Less than 150% of specified value ESR Less than 150% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them at 60℃, 90 to 95% RH for 1,000 hours. Leakage current should be tested after voltage treatment*. Moisture Resistance Resistance to Soldering Heat * (Please refer to page 10 for soldering conditions) Within ±10% of initial value Less than 130% of specified value Less than 130% of specified value Within specified value Capacitance Change Dissipation Factor ESR Leakage Current Ripple Current & Frequency Multipliers 120 ≦ f < 1k 0.05 Frequency (Hz) Multiplier 1k ≦ f < 10k 0.3 10k ≦ f < 100k 100k ≦ f < 500k 0.7 1.0 * For any doubt about measured values, measure the leakage current again after the following voltage treatment. Voltage treatment: Applying DC rated voltage to the capacitors for 2 hours at 105 oC. DIAGRAM OF DIMENSIONS LEAD SPACING AND DIAMETER φD+βmax φD L P φd α β P±0.5 φd L+α max 15 min 6.3 6.5 2.5 5.5 8 11.5 3.5 11 0.45 Unit: mm 10 10 12.5 5.0 0.6 1.0 1.5 0.5 4 min MARKING φD = 6.3 Negative polarity φD = 8 ~ 10 a1 10 16V Date code Rated cap. Rated voltage Negative polarity a1 OCR 470 6.3V Date code Series name Rated cap. Rated voltage 2011 Verison Organic Conductive Polymer Capacitors Dimension: φD× L(mm) Ripple Current: mA/rms at 100k Hz, 105℃ STANDARD RATINGS W. V. (V) 2.5V (0E) 4V (0G) 6.3V (0J) 10V (1A) 16V (1C) 20V (1D) 25V (1E) 35V (1V) 50V (1H) 2011 Version OCR Tanδ (120Hz, 20℃ ) 0.12 LC (µA) ESR (mΩ/at 100k ~ 300k Hz, 20℃ Max) Rated R. C. (mA/rms at 100k Hz, 105℃ ) 220 Size φD×L(mm) 6.3×5.5 110 28 2,390 390 6.3×11 0.12 195 18 3,160 680 8×11.5 0.18 340 10 5,230 1,000 10×10 0.18 500 14 4,700 1,500 10×12.5 0.18 750 8 5,500 150 6.3×5.5 0.12 120 40 1,810 270 6.3×11 0.12 216 15 3,200 560 8×11.5 0.18 448 10 5,230 1,200 10×12.5 0.18 960 8 5,500 100 6.3×5.5 0.12 126 40 1,810 Capacitance (µF) 220 6.3×11 0.12 277 18 3,160 330 6.3×6.5 0.12 416 28 2,390 390 8×11.5 0.15 491 12 4,770 470 8×11.5 0.15 592 12 4,770 820 10×12.5 0.15 1,033 10 5,500 100 6.3×6.5 0.12 200 45 1,700 220 10×10 0.15 440 17 3,950 330 8×11.5 0.12 660 14 4,420 560 10×12.5 0.12 1,360 12 5,300 47 6.3×5.5 0.10 150 50 1,650 100 6.3×11 0.10 320 22 2,820 180 8×11.5 0.12 576 16 4,360 330 10×10 0.12 1,056 16 4,360 330 10×12.5 0.12 1,056 14 5,050 22 6.3×5.5 0.10 88 60 1,450 56 6.3×11 0.10 224 25 2,650 100 8×11.5 0.15 400 24 3,320 100 10×10 0.15 400 24 3,320 150 10×12.5 0.15 600 20 4,320 6.8 6.3×5.5 0.10 170 80 1,200 33 8×11.5 0.12 165 24 3,320 8x11.5 0.12 280 24 3,320 4,320 56 10×12.5 0.12 280 20 68 8×11.5 0.12 340 24 3,320 100 10×12.5 0.12 500 20 4,320 22 8×11.5 0.12 154 50 2,300 39 8×11.5 0.12 273 31 2,100 47 10×12.5 0.12 329 30 3,650 68 10×12.5 0.12 476 28 2,700 27 8×11.5 0.12 270 36 2,000 47 10×12.5 0.12 470 31 2,500
OCR221M1CBK-1010 价格&库存
很抱歉,暂时无法提供与“OCR221M1CBK-1010”相匹配的价格&库存,您可以联系我们找货
