100B0R7BCA500X
100B0R7BCA500X
    ATC
    CAP_2.79X2.79MM_SM
    贴片电容(MLCC) CAP_2.79X2.79MM_SM
100B0R7BCA500X 数据手册
ATC 100 B Series Porcelain Superchip ® Multilayer Capacitors • Case B Size • Capacitance Range (.110" x .110") 0.1 pF to 1000 pF • High Q • Ultra-Stable Performance • Low ESR/ESL • High Self-Resonance • Low Noise • Established Reliability (QPL) • Extended WVDC up to 1500 VDC ELECTRICAL AND MECHANICAL SPECIFICATIONS QUALITY FACTOR (Q): greater than 10,000 at 1 MHz. ATC, the industry leader, offers new improved ESR/ESL performance for the 100 B Series RF/Microwave Capacitors. This Series is now available with extended operating temperatures up to 175°C. High Density porcelain construction provides a rugged, hermetic package. Typical functional applications: Bypass, Coupling, Tuning, Feedback, Impedance Matching and DC Blocking. Typical circuit applications: UHF/Microwave RF Power Amplifiers, Mixers, Oscillators, Low Noise Amplifiers, Filter Networks, Timing Circuits and Delay Lines. TEMPERATURE COEFFICIENT OF CAPACITANCE (TCC): +90 ±20 PPM/°C (-55°C to +125°C) +90 ±30 PPM/°C (+125°C to +175°C) INSULATION RESISTANCE (IR): 0.1 pF to 470 pF: 106 Megohms min. @ +25°C at rated WVDC. 105 Megohms min. @ +125°C at rated WVDC. 510 pF to 1000 pF: 105 Megohms min. @ +25°C at rated WVDC. 104 Megohms min. @ +125°C at rated WVDC. IR above +125°C is derated by one order of magnitude. WORKING VOLTAGE (WVDC): See Capacitance Values Table, page 2. DIELECTRIC WITHSTANDING VOLTAGE (DWV): ENVIRONMENTAL TESTS ATC 100 B Series Capacitors are designed and manufactured to meet and exceed the requirements of EIA-198, MIL-PRF-55681 and MIL-PRF-123. 250% of WVDC for capacitors rated at 500 volts DC or less for 5 seconds. 150% of WVDC for capacitors rated at 1250 volts DC or less for 5 seconds. 120% of WVDC for capacitors rated above 1250 Volts DC for 5 seconds. Test voltage is applied for 5 secs. RETRACE: Less than ±(0.02% or 0.02 pF), whichever is greater. THERMAL SHOCK: MIL-STD-202, Method 107, Condition A. AGING EFFECTS: None MOISTURE RESISTANCE: MIL-STD-202, Method 106. PIEZOELECTRIC EFFECTS: None LOW VOLTAGE HUMIDITY: MIL-STD-202, Method 103, Condition A, with 1.5 Volts DC applied while subjected to an environment of 85°C with 85% relative humidity for 240 hours min. LIFE TEST: MIL-STD-202, Method 108, for 2000 hours, at 125°C. Voltage Applied: 200% of WVDC for capacitors rated at 500 volts DC or less. 120% of WVDC for capacitors rated at 1250 volts DC or less. 100% of WVDC for capacitors rated above 1250 volts DC. (No capacitance variation with voltage or pressure). CAPACITANCE DRIFT: ±(0.02% or 0.02 pF), whichever is greater. OPERATING TEMPERATURE RANGE: Standard WVDC: 0.1 to 330 pF: from -55°C to +175°C 360 to 1000 pF: from -55°C to +125°C Extended WVDC: 0.1 to 1000 pF: from -55°C to +125°C (No derating of working voltage). TERMINATION STYLES: Available in various surface mount and leaded styles. See Mechanical Configurations, page 3. TERMINAL STRENGTH: Terminations for chips and pellets withstand a pull of 5 lbs. min., 15 lbs. typical, for 5 seconds in direction perpendicular to the termination surface of the capacitor. Test per MIL-STD-202, method 211. THE ENGINEERS’ CHOICE ® www. a tc e ra mi c s . c o m ATC # 001-807 Rev. T, 2/20 ATC 100 B Capacitance Values 500 B, C, D 1500 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 B, C, D 500 1500 B, C, J, K, M F, G, J, K, M 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 101 111 121 131 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 100 110 120 130 RATED WVDC CAP. CAP. STD. EXT. CODE (pF) VOLTAGE EXTENDED VOLTAGE B, C 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 TOL. 500 F, G, J, K, M 1500 EXTENDED B RATED WVDC CAP. CAP. STD. EXT. CODE (pF) TOL. EXTENDED VOLTAGE 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 RATED WVDC CAP. CAP. CODE (pF) STD. EXT. EXTENDED VOLTAGE 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 TOL. EXTENDED VOLTAGE CAP. CAP. CODE (pF) 300 1000 151 161 181 201 221 241 271 301 331 361 391 431 471 511 561 621 681 751 821 911 102 150 160 180 200 220 240 270 300 330 360 390 430 470 510 560 620 680 750 820 910 1000 TOL. RATED WVDC STD. EXT. EXT. 300 1000 VOLT. EXT. 200 F, G, J, K, M 600 VOLT. 100 EXT. 300 50 VOLT. VRMS = 0.707 X WVDC • SPECIAL VALUES, TOLERANCES, HIGHER WVDC AND MATCHING AVAILABLE. • ENCAPSULATION OPTION AVAILABLE. PLEASE CONSULT FACTORY. NOTE: EXTENDED WVDC DOES NOT APPLY TO CDR PRODUCTS. ATC PART NUMBER CODE ATC100 B 91 0 J W 500 X T Series Case Size Capacitance Code: First 2 significant digits for capacitance. R=Decimal Point Indicates number of zeros following digits of capacitance in picofarads except for decimal values. Packaging T - Tape and Reel, 1000 pc. qty.* TV - Vertical Orientation of Product, Tape and Reel, 1000 pc. qty.* I - Special Packaging. Consult Factory. *Consult ATC for other quantities ATC Cap-Pac® packaging (100pc. qty. std.) is also available. For this option, leave last field blank. Capacitance Tolerance Code Tol. Laser Marking CAPACITANCE TOLERANCE B C D F ±0.1 pF ±0.25 pF ±0.5 pF ±1% G J K ±2% ±5% ±10% WVDC Termination Code M ±20% The above part number refers to a 100 B Series (case size B) 91 pF capacitor, J tolerance (±5%), 500 WVDC, with W termination (Tin /Lead, Solder Plated over Nickel Barrier), laser marking and Tape and Reel packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. A M E R I C A N 2 ATC North America sales@atceramics.com For additional information and catalogs contact your ATC representative or call direct at (631) 622-4700. Consult factory for additional performance data. T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om ATC 100 B Capacitors: Mechanical Configurations ATC ATC SERIES MIL-PRFTERM. & CASE 55681 CODE SIZE CASE SIZE & TYPE BODY DIMENSIONS INCHES (mm) OUTLINE W/T IS A TERMINATION SURFACE 100B W P CDR14BG CDR14BG B Solder Plate 100B T N/A B Solderable Nickel Barrier L Heavy Tin/Lead Coated, over Nickel Barrier Termination T T .110 + .035 - .010 .110 ±.015 (2.79 + 0.51 (2.79 ±0.38) -0.25) T .110 +.020 - .010 .110 ±.015 (2.79 + 0.51 (2.79 ±0.38) -0.25) Y W L Y 100B CA CDR13BG B Gold Chip W L TL LL WL WL RoHS Compliant Gold Plated over Nickel Barrier Termination Length (LL) LL .135 ±.015 (3.43 ±0.38) W T L B RR LL CDR24BG W Radial Ribbon LL L T WL RW W L .102 (2.59) max. T T L W LL W T B .500 (12.7) LL CDR25BG Axial Wire .145 ±.020 (3.68 ±0.51) WL L AW N/A LL CDR23BG Radial Wire 100B .110 ±.015 (2.79 ±0.38) WL TL B 100B Thickness (TL) .250 (6.35) .093 ±. 005 .004 ± .001 min. (2.36 ± 0.13) (.102 ± .025) Axial Ribbon 100B Width (WL) TL WL CDR22BG Tin Plated over Nickel Barrier Termination T L B AR RoHS Compliant .120 (3.05) max. W Microstrip 100B TL LL CDR21BG .015 (0.38) ±.010 (0.25) T B MS .102 (2.59) max.. W L 100B MATERIALS .110 + .035 - .010 .110 ±.015 (2.79 + 0.89 (2.79 ±0.38) -0.25) W Pellet OVERLAP (Y) T Y B THICKNESS (T) Tin /Lead, Solder Plated over Nickel Barrier Termination W L WIDTH (W) .110 + .020 - .010 .110 ±.015 (2.79 + 0.51 (2.79 ±0.38) -0.25) Y 100B LENGTH (L) LEAD AND TERMINATION DIMENSIONS AND MATERIALS W LL L •• • T T L #26 AWG., .016 (.406) dia. nominal W Additional lead styles available: Narrow Microstrip (NM), Narrow Axial Ribbon (NA) and Vertical Narrow Microstrip (H). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. For a complete military catalog, request American Technical Ceramics document ATC 001-818. •• L A M E R I C A N 3 ATC North America sales@atceramics.com LL W • T T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om ATC 100 B Non-Magnetic Capacitors: Mechanical Configurations ATC ATC SERIES MIL-PRFTERM. & CASE 55681 CODE SIZE CASE SIZE & TYPE Meets Requirements B Non-Mag Solder Plate Meets Requirements B Non-Mag Pellet Meets Requirements B Non-Mag Solderable Barrier B 100B 100B 100B 100B 100B 100B WN PN TN MN AN FN Meets Requirements RN L T .110 + .035 - .010 .110 ± .015 .102 (2.59) (2.79 + 0.89 (2.79 ±0.38) max.. -0.25) T 110 + .025 - .010 .110 ± .015 (2.79 + 0.64 (2.79 ±0.38) -0.25) W Y W L TL LL WL W TL LL WL LL WL RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination Length (LL) .135 ±.015 (3.43 ±0.38) W Width (WL) Thickness (TL) .250 (6.35) .093 ± .005 .004 ± . 001 (6.35) min. (2.36 ± 0.13) (.102 ± .025) T L LL W .110 ±.015 (2.79 ±0.38) WL L T N/A .102 (2.59) max. TL LL WL W T LL B Non-Mag Axial Wire Meets Requirements Heavy Tin /Lead, Coated over Non-Magnetic Barrier Termination T T L W .145 ±.020 (3.68 ±0.51) LL BN .102 (2.59) ±.010 (0.25) TL B Non-Mag Radial Ribbon Meets Requirements MATERIALS Tin /Lead, Solder Plated over Non-Magnetic Barrier Termination .120 (3.05) max. W L Meets Require- B ments Non-Mag Axial Ribbon Meets Requirements OVERLAP (Y) T L Non-Mag Microstrip THICKNESS (T) T Y L WIDTH (W) LEAD AND TERMINATION DIMENSIONS AND MATERIALS .110 + .025 - .010 .110 ± .015 (2.79 + 0.64 (2.79 ±0.38) -0.25) W W 100B LENGTH (L) Y L 100B BODY DIMENSIONS INCHES (mm OUTLINES W/T IS A TERMINATION SURFACE WL L LT L B W Non-Mag RadialWire L #26 AWG., .016 (.406) dia. nominal • T LL •• .500 (12.7) min. T L W Additional lead styles available: Narrow Microstrip (DN), Narrow Axial Ribbon (GN) and Vertical Narrow Microstrip (HN). Other lead lengths are available; consult factory. All leads are high purity silver attached with high temperature solder and are RoHS compliant. Suggested Mounting Pad Dimensions •• LL L W 0J 91 T 910J Horizontal Electrode Orientation Vertical Electrode Orientation B A B Case B Vertical Mount 0.1 pF 0.2 pF 0.3 to 510 pF > 510 pF Pad Size Normal High Density Normal High Density Normal High Density Normal High Density C D A M E R I C A N 4 • T Cap Value T L W L W ATC North America sales@atceramics.com All values Normal A Min. B Min. C Min. D Min. .065 .050 .075 .175 .030 .075 .135 .050 .075 .075 .175 .030 .050 .075 .075 .175 .030 .050 .075 .175 .045 .090 .070 .110 .090 .120 .100 .030 Horizontal Mount High Density .075 .135 .135 .135 .130 .050 .075 .175 .110 .030 .075 .135 T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com www.at c er am ic s .c om ESR VS CAPACITANCE ATC SERIES 100, CASE B ESR VS CAPACITANCE ATC 100 B Performance Data ESR VS. CAPACITANCE ATC SERIES 100, CASE B Q VS. CAPACITANCE ATC SERIES 100, CASE B 100000 1 150 MHz 1000 MHz 0.1 Q ESR (Ohms) 10000 1000 500 MHz 500 MHz 100 150 MHz (Typical) 0.01 1 1000 MHz 10 (Typical) 10 100 1 10 CAPACITANCE (pF) ESR VS CAPACITANCE (1.0 pF to 51 pF) 100 CAPACITANCE (pF) (1.0 pF to 51 pF) ATC SERIES 100, CASE B Q VS CAPACITANCE ATC SERIES 100, CASE B CAPACITANCE Q VS. CAPACITANCE ATC SERIES 100, CASE B (1.0 pF to 51 pF) ESR VS. CAPACITANCE ATC SERIES 100, CASE B 1 1000 Q ESR (Ohms) 150 MHz 100 Q 1000 MHz 0.1 500 MHz 500 MHz 1000 MHz 150 MHz Q 0.01 10 (Typical) 10 100 (Typical) 10 100 1000 CAPACITANCE (pF) (56 pF to 1000 pF) 1000 CAPACITANCE (pF) (56 pF to 1000 pF) SERIES RESONANCE VS CAPACITANCE ATC SERIES 100, CASE B CAPACITANCE (56 pF to 1000 pF) SERIES RESONANCE VS. CAPACITANCE ATC SERIES 100, CASE B % CHANGE IN CAPACITANCE 2 FREQUENCY (GHz) FREQUENCY (GHz) 100 10 1 0.1 1 10 CAPACITANCE (pF) A M E R I C A N 5 ATC North America sales@atceramics.com 100 TC= +90 ± 20 PPM/°C (-55°C to +125°C) TC= +90 ± 30 PPM/°C (+125°C to +175°C) 1 0.5 0 -0.5 -1 (Typical) 0.1 1.5 CAPACITANCE CHANGE VS. TEMPERATURE CAPACITANCE (pF) ATC SERIES 100, CASE (56 pF to 1000 pF) B -55 -35 1000 -15 5 25 45 65 85 105 TEMPERATURE (Degrees C) T E C H N I C A L C E R A M I C S ATC Europe saleseur@atceramics.com ATC Asia sales@atceramics-asia.com w w w.at c er am ic s .c om 125 145 165 ATC 100 B Performance Data CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE B 100 RMS CURRENT (Amps) RMS CURRENT (Amps) 100 10 1000 MHz 1 0.1 500 MHz 150 MHz 30 MHz Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 0.1 1 CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE B 10 The current rating is based on a 65°C mounting surface and a device thermal resistance of 20°C/W. A power dissipation of 3W will result in a case temperature of 125°C. 10 500 MHz 1000 MHz 30 MHz 1 100 150 MHz Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 10 100 CAPACITANCE (pF) (0.1 pF to 51 pF) 1000 CAPACITANCE (pF) (56 pF to 1000 pF) CURRENT RATING VS. CAPACITANCE ATC SERIES 100, CASE B, EXTENDED VOLTAGE 100 RMS CURRENT (Amps) 10 1000 MHz 1 500 MHz 150 MHz 30 MHz RMS Current (Amps) 0.1 0.01 Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) 0.1 1 10 CAPACITANCE (pF) (56 pF to 200 pF) 100 1000 Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. B; 12/05). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC's website at www.atceramics. com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product without prior notice. © 1996 American Technical Ceramics Corp. All Rights Reserved THE ENGINEERS’ CHOICE ® ATC # 001-807 Rev. T, 2/20 www. a tc e ra mi c s . c o m
100B0R7BCA500X 价格&库存
很抱歉,暂时无法提供与“100B0R7BCA500X”相匹配的价格&库存,您可以联系我们找货
