1
Crystal Units
RoHS compliance
Crystal Units
XY
2.5x2.0x0.55mm typ
12MHz up to 60MHz
Type
Feature
A small surface mount type crystal unit,especially suited for
small-sizing requirements.
Ultra compact and thin.(2.5×2.0×0.55mm typ.)
Tight Tolerance 10 ppm available.
RoHS Compliant
Application:Bluetooth ;Mobile phone;W-LAN;Office
Automation;Audio & Video.
Meets the requirements for re-flow profiling using lead-free solder.
Specifications
Type
Item
Frequency Range
Oscillator Mode
Load Capacitance
Drive Level
Frequency Tolerance
Series Resistance
Operating Temperature Range
Storage Temperature Range
Packing Unit
XY-Type
12~13MHz
13~16MHz
16~20MHz 20~30MHz 30~60MHz
Fundamental
Series,8pF,10pF,12pF
10μW(100μW max.)
-6
±10×10 ,±20×10-6,±30×10-6,±50×10 -6 (at 25°C)
200 Ω max. 100 Ω max. 80 Ω max.
60 Ω max.
40 Ω max.
-10~+60°C, -20~+70°C, -40~+85°C
-40~+85°C
3000pcs./reel(Ø180)
Outline Drawing
2.5
Internal connections (TOP VIEW)
#3
#1
#2
2.0
#4
0.55max
*#2 and #4 are connected with
metal cap. Of top.
Reference land pattern
#1
Q.C
#2
PASS
1.4
1.0
0.55
1.25
1.15
1.6
1.75
Frequency Stability Vs. Temperature Range
±15
Available(case by case)
Contact:www.chinatact.com
Standard
±10
-10 ~ +60
-20 ~ +70
-40 ~ +85
±5
PPm
Temp.(°C)
T1106A
#3
#4 0.73
Sales@chinatact.com
Not Available
Oscillation Circuit of Fundamental Mode
RF
R
C1
Crys tal
C2
CL=
C1*C2
C1+C2
+3~5pf
15
很抱歉,暂时无法提供与“XYDEELNANF-24M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.11662
- 50+0.98950
- 150+0.93507
- 500+0.86714
