OP25207425MEDA4SI-u
OP25207425MEDA4SI-u
    YXC(扬兴科技)
    SMD2520_4P
    可编程晶振 SMD2520_4P
OP25207425MEDA4SI-u 数据手册
【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSO680PR Features C 00 Y X00 .0 2 XX XX . Quartz Crystal Programmable Oscillator . Any frequency between 1MHz~200MHz accurate to 6 decimal places   . Operating temperature from -40℃ to +85℃ . Period 40pSec at 12KHz to 20MHz Jitter, Typical: . CMOS compatible output . Industry-standard packages: 2.5 x 2.0 , 3.2 x 2.5 , 5.0 x 3.2 , 7.0 x 5.0 mm x mm Applications: . Ideal for DSC, DVC, DVR, IP CAM, Tablets, e-Books, SSD, GPON, EPON, etc . Ideal for high-speed serial protocols such as : USB, SATA, SAS, Electrical Specifications Type Item All Min /and Max limits are specified over temperature and rated operating voltageYSO680PR with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. 1.8 V Parameter 3.3 V 2.5 V Frequency Range 1MHz~110MHz 1MHz~166MHz 1MHz~200MHz SupplyVoltage 1.62 V~1.98 V 2.25 V~2.75 V 2.97 V~3.63 V Standby Variation(Vdd)10% Current 15μF Frequency Tolerance ± 20ppm, ± 25ppm,± 50ppm, or specify Output Load 15 pF , or specify Operating Temperature Range - 40 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Vol ( Min. ) 90%Vdd Min./10%Vdd Max Duty 45~55% Period Cycle Jitter(@12K-20Mhz) 40pSec Typical Start-up Time 5msMax. Supply Current See Below Frequency Aging ( at 25 ℃ ) ± 3 ppm / year Max. Pin Description Pin Symbol Pin Symbol Functionality Functionality Output Enable 1 OE/ST/NC Standby No Connect H : specified frequency output L : output is high impedance. Only output driver is disabled. H : specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. Any voltage between 0 and Vdd or Open : Specified frequency output. Pin 1 has no function. 1 2 GND OE/ST/NC OUT VDD 2 GND Power Electrical ground 4 3 OUT Output Oscillator output Pin Assignments 4 VDD Power Power supply voltage Notes: 1.A capacitor of value 0.1 (jF or higher bet ween Vdd and GND is required.Notes: come visit our site http://www.yxc.hk 1/4 3 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSO680PR Dimensions and Patterns Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) 2.5 x 2.0 mm 3.2 x 2.5 mm 5.0 x 3.2 mm 7.0 x 5.0 mm Notes: 1. A capacitor of value 0.01µF~0.1µF or higher between Vdd and GND is required. Quartz Crystal Oscillator Dimensions Frequency Supply voltage (V) (Hz) Frequency Stability Output Overall (ppm) come visit our site http://www.yxc.hk 2/4 Pin Material Operating Temp. Range 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSO680PR Performance Plots Figure 1. Idd vs Frequency Figure 2. Frequency vs Temperature Figure 3. 20%-80% Rise Time vs Temperature Figure 4. Duty Cycle vs Frequency Figure 5. 20%-80% Fall Time vs Temperature ) s p ( J P I Frequency (MHz) Notes: 1. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 2. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is up to 5 MHz for carrier frequencies below 40 MHz. come visit our site http://www.yxc.hk 3/4 【晶振全系列独立与授权型供应商-深圳扬兴科技有限公司】 www.yxc.hk YSO680PR ★ PART NUMBER GUIDE 部件号示例 e.g. O P7 050200MEDA4 SI - u Quartz Crystal Oscillator Dimensions Frequency Supply voltage (V) (Hz) OP 7050 200M E YSO 68 0PR =7 .0 ×5.0 SMD SEAM TYPE Frequency Stability output Overall (ppm) D Pin 4 A Material Operating Temp. 一 Range I S ★ INPUT CURRENT 工作电流 Supply Voltage Power Dissipation 1.000 ~ 30.000 MHz 30.000 ~ 75.000 MHz 75.000 ~ 110.000 MHz 133.000 ~ 166.000 MHz — 1.8 V 6 mA max 8 mA max 12 mA max 2.5 V 8 mA max 10 mA max 15 mA max 15 mA max 3.3 V 10 mA max 15 mA max 20 mA max 22 mA max ★ REFLOW SOLDERING PROFILE 回流焊特性 ★ Test Circuit come visit our site http://www.yxc.hk 4/4 166.000 ~ 200.000 MHz — — 25 mA max - Remark u
OP25207425MEDA4SI-u 价格&库存
很抱歉,暂时无法提供与“OP25207425MEDA4SI-u”相匹配的价格&库存,您可以联系我们找货
