PMLT25201B-1R0MS
PMLT25201B-1R0MS
    CYNTEC(乾坤)
    固定电感器
PMLT25201B-1R0MS 数据手册
CYNTEC CO., LTD. 乾坤科技股份有限公司 DOCUMENT : CYNC-127-017 (Preliminary specification) REVISION : A4 PAGE : 1 OF 4 Sealed Choke Coil PMLT25201B type  Features : Low profile 2.5mm x 2.0mm x 1.2mm Low coil resistance with large currents. High magnetic shield construction should actualize high resolution for EMC protection. 100% lead (Pb) free meet RoHS standard  Application Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..  Outline Dimensions W L P P Code L W T P Dimensions (mm) 2.0 ± 0.2 2.5 ± 0.2 1.2 Max. 0.4 ± 0.2 T Note  :This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product. Recommend Land Pattern Dimensions The customer shall determine the land dimensions shown above after confirming and safety. B A 2.1 B 0.8 C 2.6 A C Unit : mm CYNTEC CO., LTD. 乾坤科技股份有限公司  DOCUMENT : CYNC-127-017 (Preliminary specification) REVISION : A4 PAGE : 2 OF 4 Specifications Part Number PMLT25201B-R24MS PMLT25201B-R47MS PMLT25201B-R68MS PMLT25201B-1R0MS PMLT25201B-1R5MS PMLT25201B-2R2MS PMLT25201B-3R3MS PMLT25201B-4R7MS PMLT25201B-6R8MS PMLT25201B-100MS L0 Inductance ( µH ) @ (0A) 0.24 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10.0 Heat Rating Current DC Amps. Idc ( A ) Saturation Current DC Amps. Isat ( A ) Maximum Typical Maximum Typical Maximum 29 41 51 60 87 116 168 252 487 540 3.90 3.70 3.30 2.60 2.20 1.85 1.45 1.20 1.00 0.75 3.51 3.33 2.97 2.34 1.98 1.76 1.30 1.08 0.90 0.67 4.28 3.20 2.75 2.55 1.95 1.83 1.45 1.28 0.85 0.72 3.85 2.90 2.48 2.30 1.75 1.80 1.30 1.15 0.76 0.65 Rdc ( mΩ) Typical 24 34 42 50 72 96 140 210 406 450 :If you require another part number please contact with us. **:Inductance Tolerance ± 20% Note 1.: All test data is referenced to 25℃ ambient. Note 2.: Test Condition:1MHz, 1.0Vrms Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃ Note 4.: Isat : DC current (A) that will cause Lo to drop approximately 30% Note 5.: Operating Temperature Range -55℃ to + 125℃ Note 6.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case operating. * Circuit design, component placement, PWB trace size and thickness, airflow and other cooling Note 7. : provision all affect the part temperature. Part temperature should be verified in the end application. The rated current as listed is either the saturation current or the heating current depending on which value is lower. CYNTEC CO., LTD. 乾坤科技股份有限公司  : A4 PAGE : 3 OF 4 0.15 40 INDUCTANCE(µH) ℃) 20 0.05 2.0 3.0 4.0 5.0 DC BIAS(Amps) 6.0 PMLT25201B-R68MS 0.84 0.70 80 0.56 60 0.42 INDUCTANCE(µH) 0.28 TEMP RISE( ℃) 40 0.00 ℃ 1.0 1.5 2.0 2.5 3.0 3.5 4.0 20 0 0.5 1.0 1.5 2.0 2.5 3.0 DC BIAS(Amps) 80 0.6 TEMP.RISE( 0.0 INDUCTANCE(µH) ℃ 20 0.4 0.8 1.2 1.6 3.5 3.6 4.0 ℃) 0.7 0.0 1.5 1.8 2.1 100 INDUCTANCE(µH) TEMP.RISE( 0.90 ℃) 40 4.5 ℃ 0 0.4 0.8 1.2 1.6 DC BIAS(Amps) 2.0 2.4 2.8 PMLT25201B-4R7MS 100 80 3.6 60 2.7 INDUCTANCE(µH) TEMP.RISE( 1.8 20 0.9 0 0.0 ℃ 20 0.00 80 40 INDUCTANCE(µH) 0.9 1.2 DC BIAS(Amps) 3.2 80 1.35 5.4 2.1 0.6 2.8 60 100 60 0.3 2.4 PMLT25201B-2R2MS 0.0 2.8 0.0 2.0 1.80 3.2 INDUCTANCE(µH) 2.8 TEMP RISE( ) 2.4 PMLT25201B-3R3MS TEMP.RISE( 20 0.45 0 1.4 ℃) 0 2.25 TEMP RISE( ) ℃) 0.3 4.2 40 INDUCTANCE(µH) 0.4 80 40 INDUCTANCE(µH) 1.2 1.6 2.0 DC BIAS(Amp ℃ 60 2.70 0.9 0.8 100 0.8 100 60 0.4 5.0 1.0 0.0 1.2 0.0 4.5 DC BIAS(Amps) 1.5 TEMP.RISE( 4.0 0.0 4.5 PMLT25201B-1R5MS 0.6 3.5 PMLT25201B-1R0MS DC BIAS(Amps) 1.8 40 0.2 0 0.5 ℃) 0.1 1.2 20 0.14 0.0 TEMP.RISE( 0.2 0.0 100 ℃ 60 INDUCTANCE(µH) 0.3 7.0 INDUCTANCE(µH) 1.0 80 0.4 0.0 0 0.0 0.5 TEMP RISE( ) TEMP.RISE( 100 ℃) 40 20 0 0.0 0.3 0.6 0.9 1.2 DC BIAS(Amps) 1.5 1.8 ℃ TEMP RISE( ) 0.10 ℃ INDUCTANCE(µH) 60 P MLT25201B-R47MS 0.6 TEMP RISE( ) 80 0.20 0.00 INDUCTANCE(µH) REVISION TEMP RISE( ) 100 TEMP RISE( ) INDUCTANCE(µH) (Preliminary specification) TEMP RISE( ) PMLT25201B-R24MS 0.25 INDUCTANCE(µH) : CYNC-127-017 Current Characteristic 0.30 INDUCTANCE(µH) DOCUMENT CYNTEC CO., LTD. 乾坤科技股份有限公司 80 10.0 5.6 60 INDUCTANCE(µH) 4.2 TEMP.RISE( ℃) 40 2.8 20 1.4 0.0 0 0.0 0.2 0.4 0.6 0.8 DC BIAS(Amps) 1.0 1.2 1.4 ℃ REVISION : A4 PAGE : 4 OF 4 PMLT25201B-100MS 100 80 8.0 60 6.0 4.0 INDUCTANCE(µH) TEMP.RISE( ℃) 40 20 2.0 0.0 0 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 DC BIAS(Amps) ℃ TEMP RISE( ) 12.0 INDUCTANCE(µH) INDUCTANCE(µH) 7.0 : CYNC-127-017 (Preliminary specification) 100 TEMP RISE( ) PMLT25201B-6R8MS 8.4 DOCUMENT
PMLT25201B-1R0MS 价格&库存
很抱歉,暂时无法提供与“PMLT25201B-1R0MS”相匹配的价格&库存,您可以联系我们找货
