O32253579545MHEA4SI-1
    YXC(扬兴科技)
    SMD3225_4P
    有源晶振 SMD3225_4P
O32253579545MHEA4SI-1 数据手册
YSO322ST Features 0 .00 X 125 XX X C YX . External dimensions: 3.2 x 2.5 x 0.9 mm. . Frequency range: 1MHz ~ 150MHz. . Ultra Small SMD seam sealed clock crystal oscillator units. .Applications: WLAN, Bluetooth, DSC, DSL, IP CAM, SSD,e-books and other IT product. . Tri-state function available. Electrical Specifications Item / Type YSO322ST Output Frequency Range 1~90MHz 90~150MHz Supply Voltage 1.8V 2.25~5.5V 1.6~3.6V 5.0V Current Consumption ( Max. ) 8mA 60mA 35mA 80mA Output Type CMOS Oscillation Mode Fundamental / 3rd Overtone Frequency Tolerance ± 20ppm, ± 25ppm, or specify Output Load 15 pF, or specify Operating Temperature Range - 40 ~ + 85 ℃, or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Vol ( Min. ) 90%Vdd min./10%Vdd max Symmetry 45~55%DT,40/60~60/40%Svm Rise ( Tr ) / Fall ( Tf ) Time 10Max./8 ns Max. Start-up Time 10 ms Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. Phase Noise(Pn) Three State Function -125 Max. dBc/Hz @1khz Enable Voltage 70%Vdd Min. By Low Pressure 30%Vdd Max. Dimensions 引脚功能定义 引脚 125.000 定义 1 E/D 三态/无三态 2 GND 接地 3 OUTPUT 输出 4 Vdd 电源电压 9 9 .YXC XXXX 功能 Units: mm 1/2 YSO322ST ★ PART NUMBER GUIDE 部件号示例 Frequency Stability output Overall (ppm) Quartz Crystal Oscillator Dimensions Frequency Supply voltage (Hz) (V) O 125M 3225 Supply voltage H Frequency tolerance 1.8V D ±20PPM C -20 to 70 ℃ 3.3V E ±25PPM I -40 to 85 ℃ F G 5.0V 3.3Vto5V H ±50PPM F -40 to 105 ℃ A -40 to 125℃ H 2.25Vto5.5V φ1.60 Material Operating Temp. Range 4 I S Output Operating temperature E ★ TAPING SPECIFICATION (Unit: mm) Pin A E A 3.9 0 YSO 322ST=3.2×2.5 SMD SEAM TYPE e.g. O 3225125MH EA4 SI A CMOS 编带规格 1.26 12 0° φ13 5.4 C B D OSC-SMD3225 G A F E A B 180±2.0 12.1±0.3 C 4.03±0.15 D 3.11±0.15 E F G 3.85±0.1 1.38±0.1 61.6±1.0 3000 pcs per reel ★ REFLOW SOLDERING PROFILE ★ Test Circuit 回流焊特性 2/2
物料型号为YSO322ST,这是一款超小型SMD贴片封装的时钟晶体振荡器。
器件简介包括其外部尺寸为3.2x2.5x0.9mm,频率范围在1MHz至150MHz之间,适用于WLAN、蓝牙、DSC、DSL等IT产品,以及IP摄像头、SSD、电子书等。
它还具备三态功能。
引脚分配如下: - 引脚1:E/D,用于三态/非三态控制。
- 引脚2:GND,接地。
- 引脚3:OUTPUT,输出。
- 引脚4:Vdd,电源电压。
参数特性包括: - 供电电压:1.8V、2.25-5.5V、1.6~3.6V、5.0V。
- 最大电流消耗:8mA、60mA、35mA、80mA。
- 输出类型:CMOS。
- 振荡模式:基频/三倍频。
- 频率容差:±20ppm、±25ppm,或指定。
- 输出负载:15pF,或指定。
- 工作温度范围:-40至+85°C,或指定。
- 存储温度范围:-55至+125°C。
- 电压变化:90%Vdd最小/10%Vdd最大。
- 对称性:45-55%DT,40/60-60/40%5Vm。
- 上升/下降时间:10ns最大/8ns最大。
- 启动时间:10ms最大。
- 老化(25°C):±3ppm/年最大。
- 相位噪声:-125dBc/Hz@1kHz最大。
封装信息为YSO322ST,尺寸为3.2x2.5mm,高度0.9mm。
应用信息包括回流焊特性,测试电路和测试仪表的电源、输出测试图以及测试时间。
O32253579545MHEA4SI-1 价格&库存
很抱歉,暂时无法提供与“O32253579545MHEA4SI-1”相匹配的价格&库存,您可以联系我们找货
