CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNC-127-017
(Preliminary specification)
REVISION
: A4
PAGE
: 1 OF 4
Sealed Choke Coil PMLT25201B type
Features
Low profile 2.5mm x 2.0mm x 1.2mm
Low coil resistance with large currents.
High magnetic shield construction should actualize high resolution for EMC protection.
100% lead (Pb) free meet RoHS standard
Application
Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..
Outline Dimensions
W
L
P
P
Code
L
W
T
P
Dimensions (mm)
2.0 ± 0.2
2.5 ± 0.2
1.2 Max.
0.4 ± 0.2
T
Note
:This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product.
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown above after confirming and safety.
B
A
2.1
B
0.8
C
2.6
A
C
Unit : mm
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: CYNC-127-017
REVISION
: A4
PAGE
: 2 OF 4
Specifications
Part Number
PMLT25201B-R24MS
PMLT25201B-R47MS
PMLT25201B-R68MS
PMLT25201B-1R0MS
PMLT25201B-1R5MS
PMLT25201B-2R2MS
PMLT25201B-3R3MS
PMLT25201B-4R7MS
PMLT25201B-6R8MS
PMLT25201B-100MS
L0
Inductance
( µH )
@ (0A)
0.24
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
10.0
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
29
41
51
60
87
116
168
252
487
540
3.90
3.70
3.30
2.60
2.20
1.85
1.45
1.20
1.00
0.75
3.51
3.33
2.97
2.34
1.98
1.76
1.30
1.08
0.90
0.67
4.28
3.20
2.75
2.55
1.95
1.83
1.45
1.28
0.85
0.72
3.85
2.90
2.48
2.30
1.75
1.80
1.30
1.15
0.76
0.65
Rdc ( mΩ)
Typical
24
34
42
50
72
96
140
210
406
450
:If you require another part number please contact with us.
**:Inductance Tolerance ± 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:1MHz, 1.0Vrms
Note 3.: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause Lo to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to + 125℃
Note 6.: The part temperature (ambient + temp rise ) should not exceed 125℃ under worse case operating.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling
Note 7.
provision all affect the part temperature. Part temperature should be verified in the end application.
The rated current as listed is either the saturation current or the heating current depending on which
value is lower.
CYNTEC CO., LTD.
乾坤科技股份有限公司
: A4
PAGE
: 3 OF 4
0.15
40
INDUCTANCE(µH)
2.0
3.0
4.0
5.0
DC BIAS(Amps)
6.0
PMLT25201B-R68MS
0.84
0.70
80
0.56
60
0.42
INDUCTANCE(µH)
0.28
TEMP RISE(
40
0.00
1.0
1.5
2.0
2.5
3.0
3.5
4.0
1.0
1.5
2.0 2.5 3.0
DC BIAS(Amps)
80
0.6
TEMP.RISE(
0.0
INDUCTANCE(µH)
0.8
1.2
1.6
3.5
3.6
4.0
0.7
0.0
1.5
1.8
2.1
100
INDUCTANCE(µH)
TEMP.RISE(
0.90
40
4.5
0.8
1.2
1.6
DC BIAS(Amps)
2.0
2.4
2.8
PMLT25201B-4R7MS
100
80
3.6
60
2.7
INDUCTANCE(µH)
TEMP.RISE(
1.8
80
40
INDUCTANCE(µH)
0.9
1.2
DC BIAS(Amps)
3.2
80
1.35
5.4
2.1
0.6
2.8
60
100
60
0.3
2.4
PMLT25201B-2R2MS
0.0
2.8
0.0
2.0
1.80
3.2
INDUCTANCE(µH)
2.8
TEMP RISE( )
2.4
PMLT25201B-3R3MS
TEMP.RISE(
TEMP RISE( )
0.3
4.2
40
INDUCTANCE(µH)
0.4
80
40
INDUCTANCE(µH)
1.2
1.6
2.0
DC BIAS(Amp
60
2.70
0.9
0.8
100
0.8
100
60
0.4
5.0
1.0
0.0
1.2
0.0
4.5
DC BIAS(Amps)
1.5
TEMP.RISE(
4.0
0.0
4.5
PMLT25201B-1R5MS
0.6
3.5
PMLT25201B-1R0MS
DC BIAS(Amps)
1.8
40
0.2
0.1
1.2
0.0
TEMP.RISE(
0.2
0.0
100
60
INDUCTANCE(µH)
0.3
7.0
INDUCTANCE(µH)
1.0
80
0.4
0.0
0.5
TEMP RISE( )
TEMP.RISE(
100
40
0.3
0.6
0.9
1.2
DC BIAS(Amps)
1.5
1.8
TEMP RISE( )
0.10
INDUCTANCE(µH)
60
P MLT25201B-R47MS
0.6
TEMP RISE( )
80
0.20
0.00
INDUCTANCE(µH)
REVISION
TEMP RISE( )
100
TEMP RISE( )
INDUCTANCE(µH)
TEMP RISE( )
PMLT25201B-R24MS
0.25
INDUCTANCE(µH)
: CYNC-127-017
Current Characteristic
0.30
INDUCTANCE(µH)
DOCUMENT
CYNTEC CO., LTD.
乾坤科技股份有限公司
80
10.0
5.6
60
INDUCTANCE(µH)
4.2
TEMP.RISE(
40
2.8
0.0
0.2
0.4
0.6
0.8
DC BIAS(Amps)
1.0
1.2
1.4
REVISION
: A4
PAGE
: 4 OF 4
PMLT25201B-100MS
100
80
8.0
60
6.0
4.0
INDUCTANCE(µH)
TEMP.RISE(
40
0.0
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3
DC BIAS(Amps)
TEMP RISE( )
12.0
INDUCTANCE(µH)
INDUCTANCE(µH)
7.0
: CYNC-127-017
100
TEMP RISE( )
PMLT25201B-6R8MS
8.4
DOCUMENT
很抱歉,暂时无法提供与“PMLT25201B-2R2MS”相匹配的价格&库存,您可以联系我们找货
