QUARTZ CRYSTAL UNIT SPECIFCATION
Customer:
Customer P/N:
1. Frequency :
2. Holder Type :
3. Frequency Tolerance :
4. Equivalent Resistance:
5. Storage temperature range:
6. Operation Temperature Range
7. Temperature Drift :
8. Loading Capacitance (CL) :
9. Drive Level :
10. Shunt Capacitance :
11. Insulation Resistance :
12. Mode Of Oscillation :
13. Circuit :
14. Shocking :
Variation :
15. Aging :
16. Sealing Test :
Date : 2014/10/09
4.000000 MHz
SMD-49
+/- 20 ppm At 25 ℃ +/- 3 ℃
100 ohms Max./Series
-40 ℃ To +85 ℃
-40 ℃ To +85 ℃
-40 ℃ To +85 ℃
+/-50 ppm
20.0 pF
50 uW (300 uW Max)
7.0 pF Max.
More Than 500M Ohms at DC 100V
Fundamental
Measured in S&A 250B,HP/E5100A
Dropping from 50cm height 3 times on firm wood
Frequency less than +/- 5 × 10-6
Resistance less than +/- 15 ﹪ or 2 ohms max.
Less than +/-5 ppm / Year
No air bubble are appeared with in 1 atm alcohol for
Three minutes.
17. Note:
18. Marking :
Under our method
MARK : H FREQ XY
X: Alphabet For Month e.g. A: JAN. B: FEB.
Y : Digit For Year e.g. 4 : 2004 5 : 2005
DIMENSION(mm) :
A: 10.15mm Max
B: 11.00+/-0.2mm
C: 12.10mm-0.1/+0.3mm D: 4.8mm. Max
H: 4.9mm+/-0.2mm
F: 0.8mm+/-0.1mm
G: 3.75mm Max
K: 3.8mm Max
t :0.25+/-0.02mm
E: 4.5 Max
HARMONY ELECTRONICS CORP.
很抱歉,暂时无法提供与“XSA004000DK1HA-OX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.60435
- 50+0.50917
- 150+0.42070
- 500+0.41441
