SLW4030S3R3MST
SLW4030S3R3MST
    SUNLTECH(顺磁)
    SMD,4x4mm
    功率电感 SMD
SLW4030S3R3MST 数据手册
SLW4030S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW 4030 (1) (2) (1) (2) (3) (4) S 100 M S T (3) (4) (5) (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10μH;101=100μH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. SLW4030S 4.0±0.2 4.0±0.2 3.0Max. 3.3±0.2 0.95±0.2 2.10±0.2 1.9 1.1 3.7 Rev.03 Page 1 of 4 www. sunltech.com SLW4030S Series ◆ Electrical Characteristics ℃ ℃ 1) Operating temperature range(Including self-heating):-40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ℃ ℃ ◆ Construction and material ◆ REFLOW-PROFILE Rev.03 Page 2 of 4 www. sunltech.com SLW4030S Series ◆ Specification Inductance Part Number @100KHz,1V (μH) Frequency(MHz) Saturation Current(A) Heat Rating Current (A) DCR S.R.F Isat Irms DC Resistance ±30% (Ω) Min.Self-resonant CMLW4030S Series SLW4030SR68NST 0.68±30% 0.010 130 6.80 4.56 SLW4030S1R0NST 1.0±30% 0.014 70 5.26 4.15 SLW4030S1R5MST 1.5±20% 0.020 62 5.14 3.34 SLW4030S2R2MST 2.2±20% 0.030 52 4.90 2.95 SLW4030S3R3MST 3.3±20% 0.040 38 3.30 2.40 SLW4030S4R7MST 4.7±20% 0.060 31 2.90 2.00 SLW4030S5R6MST 5.6±20% 0.065 30 2.60 1.95 SLW4030S6R8MST 6.8±20% 0.090 24 2.75 1.60 SLW4030S100MST 10±20% 0.100 21 1.95 1.50 SLW4030S120MST 12±20% 0.135 18 1.70 1.30 SLW4030S150MST 15±20% 0.190 16 1.65 1.11 SLW4030S180MST 18±20% 0.200 10 1.40 1.10 SLW4030S220MST 22±20% 0.225 10 1.30 1.00 SLW4030S330MST 33±20% 0.330 10 1.10 0.84 SLW4030S470MST 47±20% 0.445 8.4 0.95 0.72 SLW4030S560MST 56±20% 0.555 8.4 0.85 0.65 SLW4030S680MST 68±20% 0.868 7 0.72 0.52 SLW4030S750MST 75±20% 1.020 6.3 0.70 0.48 SLW4030S820MST 82±20% 1.060 5.6 0.66 0.47 SLW4030S101MST 100±20% 1.150 5.6 0.60 0.45 SLW4030S121MST 120±20% 1.350 5.4 0.55 0.42 SLW4030S151MST 150±20% 1.800 4 0.50 0.30 SLW4030S471MST 470±20% 7.200 2 0.30 0.20 SLW4030S681MST 680±20% 7.580 1.2 0.19 0.14 ◆ Note 1:All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ◆ Standard Packing Quantity: :2000 pcs/reel Rev.03 Page 3 of 4 www. sunltech.com SLW4030S Series ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW4030 Series Rev.03 Page 4 of 4 www. sunltech.com
SLW4030S3R3MST
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流、最大反向电压等。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有隔离作用,可保护电路。
6. 应用信息:广泛应用于数字通信、测量设备等领域。
7. 封装信息:EL817采用DIP-6封装。
