X3S026000B71HZ-NHPZ
X3S026000B71HZ-NHPZ
    HELE(加高电子)
    SMD3225_4P
    无源晶振 SMD3225_4P
X3S026000B71HZ-NHPZ 数据手册
PRELIMINARY SPECIFICATIONS GP Customer Part No.: HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: Sample Order No: Date: X3S026000B71HZ-NHPZ CRYSTAL HSX321S / 26.000MHz 2008/09/23 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號 2 樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN (R.O.C.) TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄縣大寮鄉大發工業區華東路 39 號 NO. 39, HWA DONG RD., TA FA IND. DIST., TA LIAO KAOHSIUNG HSIEN 831, TAIWAN, R.O.C. TEL: (07)787-1555-6 FAX: (07)787-1557 SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-7309272 / 7309262 FAX: 0755-7309755 Remark Tittle HSX321S Date THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 QUARTZ CRYSTAL SPECIFICATION Confirm Check Prepare 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 1 HSX321S SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION........... 3 2. MARKING & DIMENSIONS................... 4 3. INSIDE STRUCTURE...................... 5 4. EMBOSS CARRIER TAPE&REEL................ 6 a. DIMENSIONS OF CARRIER TAPE............... 6 b. DIMENSIONS OF REEL................... 6-7 c. STORAGE CONDITION................... 7 d. STANDARD PACKING QUANTITY................... 7 e. MATERIAL OF TAPE..................... 7 f. LABEL CONTENTS...................... 7 g. TAPING DIMENSION..................... 8 h. JOINT OF TAPE....................... 8 i. RELEASE STRENGHT OF COVER TAPE............ 8 5. MECHANICAL PERFORMANOE................. 9 6. ENVIRONMENTAL PERFORMANOE............... 9-10 7. SUPPLRMENT........................ 10-11 8. FLOW CHARD......................... 12 9. Environmental Workload Chemical Substance Components List. 13 10. TEST DATA.......................... Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 26.000000MHz 2. Holder type : HSX321S 3. Frequency tolerance: +/- 10 ppm at 25deg.C +/-3deg.C 4. Equivalent resistance: 40 ohms Max. / SERIES 5. Storage temperature range: -45 deg.C To +95 deg.C 6. Operable temperature range: -20 deg.C To +85 deg.C 7. Temperature drift: +/-10 ppm 8. Loading capacitance (CL) : -20 deg.C To +85deg.C 10.9 pF +/-0.2 pF 9. Drive level: 100 uW +/- 10 uW 10. Shunt Capacitance: 2.0 pF Max 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 50 cm height 3 times on firm wood Variation : Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/- 1 ppm/Year 16. Holder HSX321S Seam type 17.Dimensions and marking Refer to page.4 18.Emboss carrier tape & reel Refer to page.6 and page.7 19.Note: TS: 12.5 ppm/pF Typ (@CL=10.9pF) Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 3 2. HSX321S MARKING & DIMENSIONS *Marking should be printed as following: Logo, Nominal Frequency, Manufactured year & month *Nominal frequency = integer only ( ex. 14.31818 MHz Æ 14 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (The last digit of the year) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-1). Marking : Laser marking. (Table-1) Jan. A Feb. B Mar. C Apr. D May. E Jun. F Aug. H Sep. J Oct. K Nov. L Dec. M Remark Tittle HSX321S Date Jul. G QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 4 3. INSIDE STRUCTURE ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metallized Pad: W Ni Plating Au Plating (2) Cap: Fe-Ni (3) Crystal Enclosure Seal: Seal Seam (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin Adhesive bonding: upper & lower bonding/lower bonding only (6) Electrode Au (7)PAD Alumina Ceramic (W. Ni. Au) Remark Tittle HSX321S Date The use prohibition chemistry substance of Table 1 of DHE-0204-1 (QA-QM-08) is not included in this item. QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 5 4. HSX321S EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ178+1/-1 Inner Width W1 8.0+/-1.5 Outer Width W2 Out Line diameter B 11.5+/-0.2 ψ60+1.0/-0.0 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13+/-0.5 E 2.5+/-0.5/-0 ITEM FLANCE HUB Center Core slit Width Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40deg.C Max. Relative Humidity: 80% Max. d.) Standard packing quantity 3,000PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material A – PET Polyester f.) Label contents .The type of product .Our specification No. .Your Part No. .Lot No. .Nominal Frequency .Quantity .Our Company Name Sticks label for every reel. Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 8 5. Mechanical Performance 5.1.Natural Drop Drop 3 times from the height of 50cm onto min. 30mm thickness hard wooden board The component shall satisfy requirement of the electrical characteristics. 5.2.Vibration Frequency 10-55Hz, Sine Wave full amplitude of 1.5mm to X,Y and Z 3 axes, Duration of 2 hours to each axis. The component shall satisfy requirement of the electrical characteristics. 5.3.Sealing Tightness 3 Leak Rate 1.0x10-8 Pa-m /sec. Max. measured by Helium leak detector. 5.4.Solderability After applying ROSIN Flux, dipping in solder bath at 230℃+/-5℃ for 5 sec. Over 90% of terminal shall be covered by solder. 6. Environment Performance 6.1.Humidity Temperature 60℃+/-2℃,RH 90~95%, Duration of 240 hours Back to room temperature first, then in 1~2 hours, the component shall be checked. The component shall satisfy requirement of the electrical characteristics. No physical damage 6.2.Storage in Low Temperature -30℃+/-2℃,Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. The component shall satisfy requirement of the electrical characteristics. No physical damage 6.3.Storage in High Temperature +85℃+/-2℃,Duration of 240 hours. Back to the room temperature first, then in 1~2 hours, the component shall be checked. The component shall satisfy requirement of the electrical characteristics. No physical damage Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 9 6.4.Temperature cycles -30℃+/-2℃(30min)↔+85℃+/-2℃(30min) 20 cycles Back to the room temperature first, then in 1~2 hours, the component shall be checked. The component shall satisfy requirement of the electrical characteristics. No physical damage 6.5.VPS FC-70(the boiling point:+215℃)Vapor for 30 sec Back to the room temperature first, then in 1~2 hours, the component shall be checked. The component shall satisfy requirement of the electrical characteristics. No physical damage 7. Supplement 7.1.Soldering 7.2.Please stay with our proposed reflow condition and do then soldering 2 times max. Available for Lead Free Soldering Temperature 260 deg.C 220 deg.C (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 10 7.3.Land pattern layout(Example) 7.4.Solder iron (Example) Bit temp.:350℃max.,Time:3sec max. ,Each terminal solder a 1 time max. 7.5.Mounting This component is designed for automatic insertion. However, you are requested to do the trial with your insertion machine in order to be sure of proper operation and no damage of component. Please pay attention to board warp which may damage the component and cause Soldering Process. 7.6.Cleaning Cleaning liquid which corrodes Nickel shall not be used It may cause the problem on the surface, color, marking etc. Ultra-sonic cleaning is possible, however, you are requested to check on your board. Because we only checked as single unit. 7.7.Storage Please keep away from high temperature and high humidity ,which may cause put solderbility. No direct Sunlight, No dew as well. Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 11 8. Flow Chard BASE INCOMING 2 CAP BLANK A 3 INCOMING 4 CLEAN BEFORE ETCHING 5 ETCHING 6 SORTING OF FREQ. 1 7 CLEANING OF BLANK 8 FLASH ETCHING 9 BASE PLATING 19 MARKING 10 BLANK ASS’Y 20 LEAK CHECK Ⅰ (AIR LEAK) 11 ADHESIVE CURING 21 LEAK CHECK Ⅱ (He LEAK) 12 BONDING CHECK 22 FINAL CHECK ($) + TAPING 13 PARTIAL PLATING 23 APPEARANCE CHECK 14 MIDDLE CHECK ($) 15 ANNEALING IN HIGH 24 25 OUTGOING INSPECTION OUTGOING PACKING 16 INCOMING SEAM 17 REFLOW 18 AGING SHIPPING ($):SPECIAL CHARACTERISTICS A Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 12 9. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX321S PERCENTAGE Chemical Substance Components 19(mg) ppm Si 0.0437 2,300 Au 0.1463 7,700 Co & Co Compound 1.1286 59,400 Mo & Mo Compound 0.0380 2,000 Ag 0.3952 20,800 Cu 0.1102 5,800 Cr & Cr Compound 0.0380 2,000 Al 4.7234 248,600 Mn & Mn Compound 0.0228 1,200 W & W Compound 0.1843 9,700 Ni & Ni Compound 2.8424 149,600 Fe 3.8437 202,300 Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 13 REV. No. DATE REASON 0 2008/09/23 New CONTENTS Remark Tittle HSX321S Date QUARTZ CRYSTAL SPECIFICATION Prepare Confirm Check 2008/09/23 F. S. TSAI C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY TAIWAN FACTORY Spec. No. Rev. X3S026000B71HZ-NHPZ ELECTRONICS CORP. 0 Page 14 EXCEL EXPORT PRINTOUT FORMAT Run Date : 12-09-2008 9:08 am S&A 250B: 9.40 Report: 4.60 Description: 26,000,000.00 Reference Fr: (Using Measured FL) Power: 100.00 uW Into 20.0 ohms PL: No Load Crystal CL: 10.90 pF First FailureFR FL FL RR C0 C1 Hz Hz ppm Ohms pF fF 40.0 2.00 15.2 1.05 High Limit C0/C1 L Q TS RLD2 DLD2 FDLD DLDH2 FDLDH mH k ppm/pF Ohms Ohms ppm Ohms ppm 40.0 3.0 2.0 3.0 2.0 Low Limit 1 PASS 25996184.5 26000000.8 0.0 3.47 303.6 2 PASS 25995973.5 25999995.4 -0.2 13.5 1.12 3.68 304.7 3 PASS 25996193.8 26000021.4 0.8 19.2 1.05 3.48 302.1 4 PASS 25995941.1 26000022.4 0.9 13.1 1.09 3.72 292.8 5 PASS 25996031.5 26000015.9 0.6 14.1 1.11 3.64 6 PASS 25995883.8 25999750.2 -9.6 13.8 1.11 3.53 7 PASS 25995913.6 25999773.9 -8.7 13.2 1.08 8 PASS 25995920.0 25999798.2 -7.8 13.9 1.12 9 PASS 25995934.3 25999782.6 -8.4 14.2 10 PASS 25995916.5 25999792.9 -8.0 11 PASS 25996196.0 26000267.6 10.3 12 PASS 25996310.1 26000258.6 9.9 13 PASS 25996189.3 26000276.2 14 PASS 25996276.0 26000275.3 15 PASS 25996283.1 26000271.2 10.8 116.3 12.1 15.1 0.3 0.6 0.2 0.0 10.2 123.8 12.7 13.4 0.3 1.0 0.2 0.0 10.8 91.8 12.2 20.4 1.8 0.9 1.4 0.2 10.1 125.5 12.9 12.9 0.4 0.7 0.2 0.2 305.0 10.3 119.4 12.6 14.0 0.3 1.1 0.2 0.0 315.1 10.6 126.0 12.2 13.7 0.3 1.4 0.2 0.0 3.52 307.0 10.7 131.5 12.3 13.2 0.3 1.0 0.2 0.0 3.55 315.5 10.6 124.6 12.3 14.0 0.7 1.6 0.4 0.1 1.12 3.52 318.0 10.7 122.5 12.2 14.5 0.7 1.7 0.3 0.1 16.0 1.06 3.52 301.9 10.6 108.9 12.3 17.6 2.0 0.6 1.3 0.1 9.4 1.16 3.74 311.3 10.0 174.7 12.8 9.3 0.3 1.4 0.2 0.0 8.3 1.11 3.61 307.4 10.4 203.8 12.5 8.3 0.4 1.5 0.4 0.1 10.6 9.2 1.13 3.74 301.1 10.0 177.8 12.9 9.2 0.3 1.2 0.3 0.0 10.6 8.7 1.11 3.66 304.3 10.3 191.8 12.7 8.6 0.3 1.5 0.3 0.0 10.4 12.2 1.11 3.64 303.7 10.3 137.8 12.6 12.1 0.2 1.1 0.2 0.0 MAX 25996310 26000276 10.6 19.2 1.16 3.74 318.0 10.8 203.8 12.9 20.4 2.0 1.7 1.4 0.2 MIN 25995884 25999750 -9.6 8.3 1.05 3.47 292.8 10.0 91.8 12.1 8.3 0.2 0.6 0.2 0.0 X-bar 25996076 26000020 0.8 12.9 1.10 3.60 306.2 10.4 138.4 12.5 13.1 0.6 1.2 0.4 0.1 3S 477.4 622.9 24.0 8.9 0.1 0.3 19.6 0.8 97.9 0.9 10.0 1.7 1.1 1.2 0.2 TEMP -FREQ.(-40 ~ 125 ℃)100uW - NO-1 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-2 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-3 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-4 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-5 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -RR.(-40 ~ 125 ℃)100uW-N0-1 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-2 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-3 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-4 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-5 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-6 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-7 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-8 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-9 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-10 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-6 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-7 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-8 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-9 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-11 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-12 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-11 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-12 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-13 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-14 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -FREQ.(-40 ~ 125 ℃)100uW-NO-15 PPM 10 8 6 4 2 0 -2 -4 -6 -8 -10 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 Ω 50 45 40 35 30 25 20 15 10 5 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-13 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-14 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 TEMP -RR.(-40 ~ 125 ℃)100uW-NO-15 -4 -3 -2 -1 0 10 20 30 40 50 60 70 80 90 10 11 12 0 0 0 ℃ 0 0 0 0 For Question Please Contact with SGS www.tw.sgs.com Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 Page : 1 of 8 *KA-2008-70987* The following sample(s) was/were submitted and identified by/on behalf of the client as : Sample Description Style/Item No. Sample Receiving Date Testing Period : : : : CRYSTAL OSCILLATOKS HSX321S,DSX321S(Au) 2008/07/10 2008/07/10 TO 2008/7/16 ========================================================================================== Test Result(s) : - Please see the next page(s) - Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 Page : 2 of 8 *KA-2008-70987* Test Result(s) PART NAME NO.1 Test Item (s) Cadmium (Cd) Hexavalent Chromium Cr(VI) by alkaline extraction Mercury (Hg) Lead (Pb) PERFLUOROOCTANE SULFONATES (PFOS) Sum of PBBs Monobromobiphenyl Dibromobiphenyl Tribromobiphenyl Tetrabromobiphenyl Pentabromobiphenyl Hexabromobiphenyl Heptabromobiphenyl Octabromobiphenyl Nonabromobiphenyl Decabromobiphenyl MIX TEST:BROWN+GOLD+SILVER CRYSTAL OSCILLATOKS Unit Method mg/kg With reference to IEC 62321/2nd CDV (111/95/CDV). Determination of Cadmium by ICP-AES. mg/kg With reference to IEC 62321/2nd CDV (111/95/CDV). Determination of Hexavalent Chromium for non-metallic samples by UV/Vis Spectrometry. mg/kg With reference to IEC 62321/2nd CDV (111/95/CDV). Determination of Mercury by ICP-AES. mg/kg With reference to IEC 62321/2nd CDV (111/95/CDV). Determination of Lead by ICP-AES. mg/kg With reference to US EPA 3540C : 1996 method for PFOS Content. Analysis was performed by LC/MS. mg/kg With reference to IEC 62321/2nd CDV (111/95/CDV). Determination of PBBs and PBDEs by GC/MS. 2 Result No. 1 n.d. 2 n.d. 2 n.d. 2 n.d. 10 n.d. 5 5 5 5 5 5 5 5 5 5 n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. MDL Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Test Item (s) Sum of PBDEs Monobromodiphenyl ether Dibromodiphenyl ether Tribromodiphenyl ether Tetrabromodiphenyl ether Pentabromodiphenyl ether Hexabromodiphenyl ether Heptabromodiphenyl ether Octabromodiphenyl ether Nonabromodiphenyl ether Decabromodiphenyl ether Halogen Halogen-Chlorine (Cl) (CAS No.: 022537-15-1) Unit mg/kg --mg/kg Halogen-Fluorine (F) (CAS No.: 014762-94-8) mg/kg Halogen-Bromine (Br) (CAS No.: 010097-32-2) mg/kg Halogen-Iodine (I) (CAS No.: 014362-44-8) mg/kg Note Report No. : KA/2008/70987 Date : 2008/07/16 Page : 3 of 8 *KA-2008-70987* Result Method MDL No. 1 n.d. 5 n.d. 5 n.d. 5 n.d. With reference to IEC 62321/2nd CDV 5 n.d. (111/95/CDV). Determination of PBBs 5 n.d. and PBDEs by GC/MS. 5 n.d. 5 n.d. 5 n.d. 5 n.d. 5 n.d. ------With reference to BS EN 14582 . 50 n.d. Analysis was performed by IC method for Chlorine content. With reference to BS EN 14582 . 50 n.d. Analysis was performed by IC method for Fluorine content. With reference to BS EN 14582 50 n.d. .Analysis was performed by IC method for Bromine content. With reference to BS EN 14582 . 50 n.d. Analysis was performed by IC method for Iodine content. 1. mg/kg = ppm 2. n.d. = Not Detected 3. MDL = Method Detection Limit 4. The exemption of DecaBDE in polymeric application according 2005/717/EC was overruled by the European Court of Justice by its decision of 01.04.2008. Subsequently DecaBDE will be included in the sum of PBDE after 01.07.2008 5. " - " = Not Regulated 6. " --- " = Not Conducted 15. This report supersedes all pervious documents bearing the test report number KA/200X/XXXXX. 16. This is the additional test report of KA/200X/XXXXX which was issued on yyyy/mm/dd. Please refer to KA/200X/XXXXX for original information. Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 Page : 4 of 8 *KA-2008-70987* 13. This test report replaces the original one KA/200x/xxxxx. The original test report ka/200x/xxxxx was invalid. Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 Page : 5 of 8 *KA-2008-70987* Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 : 6 of 8 Page *KA-2008-70987* Analytical flow chart of halogen content 1) Name of the person who made measurement: Hungming Li 2) Name of the person in charge of measurement: Ray Chang Sample picture and report number Sample pretreatment/separation Weighting and putting sample in cell Oxygen Bomb/Absorption Dilution to fixed volume Analysis was performed by IC Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 : 7 of 8 Page *KA-2008-70987* Analytical flow chart of PFOS content 1) Name of the person who made measurement: Anson Tsao 2) Name of the person in charge of measurement: Ray Chang Sample pretreatment Sample extraction by ultrasonic method (Reference method US EPA 3540) Concentrate/Dilute Extracted solution Analysis was performed by LC/MS Data Test Report DAISHINKU CORP.(KDS)/HARMONY ELECTRONICS CORPORATION. NO.39, HUADONG RD., DALIAO TOWNSHIP, KAOHSIUNG COUNTY 831, TAIWAN (R.O.C.) Report No. : KA/2008/70987 Date : 2008/07/16 Page : 8 of 8 *KA-2008-70987* ** End of Report **
X3S026000B71HZ-NHPZ
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,包括输入侧的发光二极管引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过输入侧的发光二极管控制输出侧的晶体管开关,实现电隔离。
6. 应用信息:适用于需要电隔离的开关控制场合,如家用电器、工业控制等。
7. 封装信息:EL817采用DIP-6封装,便于PCB布局和焊接。
X3S026000B71HZ-NHPZ 价格&库存
很抱歉,暂时无法提供与“X3S026000B71HZ-NHPZ”相匹配的价格&库存,您可以联系我们找货
X3S026000B71HZ-NHPZ
    • 1+0.63029
    • 10+0.61474
    • 30+0.60437
    库存:8
