O2224576153350
O2224576153350
    JGHC(晶光华)
    SMD2520_4P
    有源晶振 24.576MHz 3.3V -40℃~+85℃ CMOS
O2224576153350 数据手册
www.jghcorp.com 【深圳市晶光华电子有限公司】  Extremely small SMD seam sealed clock oscillator unit;  Tri-State function available;  Low current consumption;  Small supply voltage shift;  Main application :Application for smart phone, sip module, variety of compact portable consumer products;  RoHS Compliant / Pb Free。 Crystals specifications ITEMS(项目) PARAMETER(规格说明) O22 Output Type(输出模式) CMOS Output Load(输出负载条件) 15 pF , or specify Oscillation Mode(振荡模式) Fundamental Supply Voltage(电源电压) Frequency Range(输出频率范围) 1.8±10%V ; 2.5±10%V ; 3.3±10%V 4 ~ 54MHz Frequency Stability ± 25 ppm ,± 50 ppm Operating Temperature Range(工作温度) - 10 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range(储存温度) - 55 ~ + 125 ℃ Oscillating voltage(振荡电压) Voltage Vol ( Max. ) 10 % VCC Max. Voltage Voh ( Min. ) 90 % VCC Min Rise ( Tr ) / Fall ( Tf ) Time:上升/下降时间 5 ns Max. Current Consumption(功耗) 5 mA Max. Symmetry(占空比) 40 ~ 60 % Start-up Time(振荡启动时间) 5 ms Max. Phase Jitter ( 12 KHz ~ 20 MHz ) Dimensions 1 ps Max. Aging ( at 25 ℃ )频率老化 ± 3 ppm / year Max. Packing Unit(包装单位) 3,000pcs/Reel
O2224576153350 价格&库存
很抱歉,暂时无法提供与“O2224576153350”相匹配的价格&库存,您可以联系我们找货
O2224576153350
  • 1+2.37816
  • 10+1.93104
  • 30+1.70424
  • 100+1.48392
  • 500+1.34784
  • 1000+1.28304
库存:1
