ITEM
P/N
Page
COMMON MODE ESD FILTER
ICMEF062P900MFR
1
Data Sheet
- ITEM
- PART NO
ICMEF062P900MFR
- CONDITION : 1.
2.
3.
4.
ITEM
P/N
Page
ICMEF062P900MFR
2
1. Generals
This specification covers the engineering requirements for the ICMEF062P900MFR
(Common Mode ESD Filter)
2. Features
Effective for suppressing common mode noise and almost no effect for high speed differential
data line
One common mode filters and two ESD suppression devices integrated
Ultra low profile (0.87ⅹ0.67ⅹ0.50mm)
Ceramic multilayer type SMD component
Non-polarized product
It is a product conforming to RoHS directive.
3. Applications
LVDS lines in notebook computers
USB2.0, IEEE1394, DVI, HDMI lines in PDP, LCD TV, DVD Player, PC, Audio player, DSC
MDDI, MIPI in mobile phone
4. Product specifications
4. 1 PART NUMBER CODE
ICMEF
①
06
②
2P
③
900
④
M
⑤
F
⑥
R
⑦
① Series name of ICT’s Common Mode ESD Filter
② Dimensions, 0.87mm (L) ⅹ 0.67mm (W)
③ Number of lines, 2P= 2 lines
④ Common Mode Impedance (at 100MHz), 900= 90Ω
⑤ Tolerance of common mode impedance, M= ±25%
⑥ Type of electrode plating: F= Lead Free
⑦ Packing Type, R= Reel
ITEM
P/N
Page
ICMEF062P900MFR
3
Rated
Voltage
Rated
Current
4. 2 Specification of electrical characteristics
Resistance
Leakage
Current
Capacitance
Insulation
Resistance
(Max)
ZCM
RDC
IL
C
IRCR
VR
IR
Units
Ω
Ω
pF
MΩ
Volt
mA
Test
Condition
@100MHz
25℃±2℃
5V
0.5Vrms
@1MHz
5V
Value
90(±25%)
Max 6.0
Max 1.0
Max 1.7
Min 10
Characteristics
Common Mode
Impedance
symbol
25℃±2℃ 25℃±2℃
5
Max100
-Transmission characteristics
(S-parameter)
- Impedance Curves
10k
Differential Mode S21
-3
-6
Insertion Loss(dB)
Impedance ()
1k
100
-9
-12
-15
-18
-21
-24
10
-27
-30
1
1M
10M
100M
Frequency (Hz)
1G
10G
-33
1M
10M
100M
Frequency(Hz)
1G
10G
ITEM
P/N
Page
ICMEF062P900MFR
4
4. 3 Operating Temperature
DESCRIPTION
REQUIREMENTS
-40℃ ∼ + 85℃
5. Equivalent Circuit & Recommended Land pattern & Stencil mask
PIN NUMBER
DESCRIPTION
①~④
DATA LINE
⑤, ⑥
GROUND
Land pattern
0.05
Stencil
0.21
0.2
⑤
③
④
0.05
0.18
0.4
0.61
⑥
15
0.05
②
0.05
①
0.
0.05
0.2
0.05
0.2
0.6
[ Equivalent circuit ]
[Land pattern & Stencil mask ]
6. Mechanical Property
6. 1 Appearance and Dimension
Unit : mm
ITEM
P/N
Page
ICMEF062P900MFR
5
7. TEST METHOD OF ELECTRICAL PROPERTY
- PIN INDEX
Pin1
Pin2
Pin5
Pin6
Pin3
Pin4
ITEM
DESCRIPTION
SOURCE
EQUIPMENT
Rdc
Pin 1-3, 2-4
10mA DC Source
Source Meter
CM
Impedance
Pin 1-2(Short) to Pin 3-4(Short)
500mV
LCR Meter
(3GHz)
IL
Pin 5 or 6 to Pin 1, 2, 3, 4
5V DC Source
Source Meter
IRCR
Pin1 -2 or Pin3-4
5V DC Source
Source Meter
ITEM
P/N
Page
ICMEF062P900MFR
6
8. REFLOW CONDITION
8. 1 RECOMMENDED SOLDERING PROFILE (Lead-free condition)
Dwell: max 260℃-10sec
185℃
160℃
Δ T≤
220℃
130
250℃
ΔT ≤130℃
30~50 sec
30~50 sec
Soldering Soldering
Pre-heating
110 ±10 sec
Gradual Cooling
25℃
60 sec
Time (sec)
8. 2 RECOMMENDED LEAD-FREE SOLDER PASTE
- Supplier : Tamura Donghwa
- Main composition : Sn-Ag-Cu
- Ratio of composition : 96.5%-3.0%-0.5%
8. 3 RECOMMENDED HAND SOLDER
- Max Temperature: Max 380 ℃(Max 5sec)
ITEM
P/N
Page
ICMEF062P900MFR
7
9. PACKING SPECIFICATION
9. 1 TAPING FIGURE
9. 2 CARRIER TAPE DIMENSIONS
Unit : mm
SYMBOL
A
B
E
F
D0
P1
P2
P0
10P0
W
T
T’
DIMENSION
0.80
1.02
1.75
3.50
1.55
2.00
2.00
4.00
40.00
8.00
0.60
0.63
TOLERANCE
0.03
0.03
0.05
0.05
0.03
0.05
0.05
0.05
0.10
0.10
0.04
0.03
ITEM
P/N
Page
ICMEF062P900MFR
8
9. 3 REEL DIMENSIONS
(1) Reel Materials: Polystyrene
(2) Label
(3) Taping
- Standard Packing Quantity per Reel (178)
- PE Tape: 10,000pcs
Unit : mm
CODE
A
DIMENSION
1782
B
C
Min. 50 130.5
D
E
W
t
R
200.8
3.00.5
101.5
1.30.2
1.00.2
9. 4 LABEL CODE
ICMEF062P900MFR
J01218LA B
001
QTY 10,000 PCS
- P/N : Part Number
- L/N : Lot Number
- C/N : Customer Number
- SPEC : Size, Line numbers & CM Impedance
- DATE : Date code
- Q’TY : Quantity
ITEM
P/N
Page
ICMEF062P900MFR
9
9. 5 REEL PACKING
Part Number / Company Name
MADE IN KOREA (Country of region )
(1)
(2)
Product box material : Card board
5 Reels in each SPQ Box
(3)
PQ Box contains 10 SPQ Boxes (50 Reels)
Packing box + Product weight
Product
CMF
CMEF
Size
S-box + 5reel
M-box + 5S-box
L-box + 10S-box
L x W x H(mm)
185 x 70 x 185
370 x 190 x 200
380 x 370 x 200
Size
weight(g)
/1 unit
Total(g)
Chip(g)
Total(g)
Chip(g)
Total(g)
Chip(g)
0806
0.00124
643
62
3215
310
6147
620
1210
0.00480
750
96
3758
480
7503
960
2012
0.00750
804
150
4028
750
8043
1500
0806
0.00128
646
65
3230
325
6177
650
1210
0.00490
752
98
3768
490
7523
980
2012
0.00760
806
152
4038
760
8063
1520
很抱歉,暂时无法提供与“ICMEF062P900MFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40770
- 100+0.31958
- 300+0.27551
- 1000+0.24246
- 5000+0.20790
- 10000+0.19462
