400ME10FH
400ME10FH
    SUNCON
    插件,D10xL20mm
    直插铝电解电容 AEC_D10X20MM_TM
400ME10FH 数据手册
Aluminum Electrolytic Type / Radial Lead Type Aluminum Electrolytic Capacitors Radial Lead Type ME-SWB ME-FH ● ● 105℃, Small, Long Life 105℃ 10,000 to 12,000hours Non solvent proof ME-FH Items Condition Rated voltage (V) − 160 200 250 350 400 Surge voltage (V) Room temperature 200 250 300 400 450 − Capacitance tolerance (%) 120Hz/20℃ ME-SWG Dissipation Factor(tan δ) tanδ (max.)120Hz/20℃ ME-CA ME-WX 500 M : ±20 0.20 0.20 0.20 0.25 0.25 0.25 3 3 3 4 6 6 6 6 6 8 10 − 0.02CV +25 Impedance ratio at Iow temperature Based on the value at −25℃ Z/Z20℃ 120Hz, +20℃ −40℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) ME-WA 450 −25 to +105 −40 to +105 μA/after 2minutes (max.) Leakage current (LC) ME-CX ME-AX (P.97) ME-FC・FD Specifications ME-UAX・SAX ME-CZ Long Life ■ Specifications Category temperature range (℃) ME-LS High Voltage Series ME-UZ・SZ ME-HC RoHS compliance Test φ10 : 10,000hours, φ12.5 to φ18 : 12,000hours △C/C Within ±20% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value ME-WL ME-FX ■ Dimensions ME-PX (Unit : mm) sleeve φd±0.05 φD±0.5 ME-HPC・HPD ME-FC・FD ME-FH ME-SWN ME-HWN F±0.5 ME-WG 15min. pressure relief vent 10 12.5 16 18 F 5.0 5.0 7.5 7.5 φd 0.6 0.6 0.8 0.8 5min. 20min. L+αmax. φD α : L
400ME10FH 价格&库存
很抱歉,暂时无法提供与“400ME10FH”相匹配的价格&库存,您可以联系我们找货
