O7050221184MGDA4SC
O7050221184MGDA4SC
    YXC(扬兴科技)
    SMD7050_4P
    有源晶振 SMD7050_4P
O7050221184MGDA4SC 数据手册
YSO751SR Features 000 . X XX 1 2 5 X C Y X . External dimensions: 7.0 x 5.0 x 1.3 mm. . Frequency range: 1MHz ~ 200MHz. . Small SMD seam sealed clock crystal oscillator units. .High precision characteristic covering up to wide frequency range. .Designed for automatic mounting and reflow soldering. .Tri-State function available .High stability, low jitter, low power consumption. . Applications: wireless communication, PC, and LCDM. Electrical Specifications Item / Type YSO751SR Output Frequency Range 1 ~ 200 MHz Output Type CMOS Supply Voltage 1.8V/2.5V/3.3V/5V, or specify Oscillation Mode Fundamental / 3rd Overtone Frequency Tolerance ± 20ppm, ± 25ppm, or specify Output Load 15 pF, or specify Operating Temperature Range - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature Range - 40 ~ + 85 ℃ , - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Vol ( Min. ) 90%Vdd min./10%Vdd max Symmetry 40 ~ 60 % Standard Rise ( Tr ) / Fall ( Tf ) Time 8 ns Max. Start-up Time 10 ms Max. Supply Current See Below Frequency Aging ( at 25 ℃ ) ± 3 ppm / year Max. Dimensions 引脚功能定义 引脚 125.000 1 .YXC XXXX 功能 E/D 定义 三态/无三态 2 GND 接地 3 OUTPUT 输出 4 Vdd 电源电压 Units: mm 1/2 YSO751SR ★ PART NUMBER GUIDE 部件号示例 Quartz Crystal Oscillator Dimensions Frequency Supply voltage (Hz) (V) O 125M 7050 Supply voltage YSO 7 51SR =7 .0×5.0 SMD SEAM TYPE e.g. O 7 050125MEEA4 SC Frequency Stability output Overall (ppm) E Frequency tolerance Pin Range 4 A E A 1.8V D ±20PPM C E 3.3V E ±25PPM I -40 to 85 ℃ F 5.0V H ±50PPM C S Output Operating temperature -20 to 70 ℃ Material Operating Temp. A CMOS ★ INPUT CURRENT 工作电流 Vdc=1.8 ~ 3.3V Vdc=5.0V 15pF only 15pF only 25 mA max 1.0 ~ 35.999 MHz 20mA max 36.0 ~ 69.999 MHz 60mA max 36.0 ~ 69.999 MHz 40mA max 70.0 ~ 150 MHz 80mA max 70.0 ~ 150 MHz 60mA max 1.0 ~ 35.999 MHz ★ TAPING SPECIFICATION (Unit: mm) φ1.31 4.0 编带规格 1.02 12 0° φ13 2.0 C B D OSC-SMD7050 G A F E A B 178±2.0 16.0±0.3 C 8.40±0.15 D 5.80±0.15 E F G 7.88±0.1 1.90±0.1 58.0±1.0 1000 pcs per reel ★ REFLOW SOLDERING PROFILE ★ Test Circuit 回流焊特性 2/2
O7050221184MGDA4SC 价格&库存
很抱歉,暂时无法提供与“O7050221184MGDA4SC”相匹配的价格&库存,您可以联系我们找货
