GF471M025F115ETA
GF471M025F115ETA
    CAPXON(台湾丰宾)
    插件,D8xL11.5mm
    直插铝电解电容 AEC_D8X11.5MM_TM
GF471M025F115ETA 数据手册
GF Series GF Series Low Impedance Features ◆ Used in mother board, computer peripheral, etc. ◆ Endurance 3000 ~ 5000 Hrs at 105 ℃ ◆ Safety vent construction design. ◆ RoHS Compliant Specifications Item Performance Characteristics Operating Temperature Range -55 to +105℃ Rated Voltage Range 6.3 to 100 VDC Capacitance Range 4.7 to 6800 μF Capacitance Tolerance Leakage Current (+20℃,max.) Dissipation Factor (tanδ,at 20℃,120Hz) ±20% (120Hz, +20℃) I≦0.01 CV or 3 (μA) After 2 minutes whichever is greater measured with rated working voltage applied. Working Voltage (VDC) D.F. (%)max 6.3 16 10 14 16 12 25 10 35 9 50 8 63 8 100 8 63 2 3 100 2 3 For capacitance >1000 μF, add 2% per another 1000μF. Impedance ratio max Working Voltage Z(-25℃) / Z(20℃) Z(-40℃) / Z(20℃) Low Temperature Characteristics (at 120Hz) 6.3 4 8 10 3 6 16 3 4 25 3 3 35 3 3 50 3 3 Endurance Shelf Life Test conditions Duration time Ambient temperature Applied voltage Dφ 5 - 6.3 φ 8φ ≧ 10 φ :as right :+105℃ :Rated DC working voltage After test requirement at +20℃ Capacitance change :≦ ±20% of the initial measured value Dissipation factor :≦ 200% of the initial specified value Leakage current :≦ The initial specified value Test conditions Duration time :1000Hrs Ambient temperature :+105℃ Applied voltage :None Life hours 3000 4000 5000 After test requirement at +20℃:Same limits as Endurance. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. Multiplier for Ripple Current vs. Frequency CAP(μF) Frequency(Hz) 50(60) CAP≦10 0.47 10<CAP≦100 0.52 100<CAP≦1000 0.58 1000<CAP 0.63 120 0.59 0.62 0.72 0.78 400 0.76 0.80 0.84 0.87 1K 0.85 0.89 0.90 0.91 10K 50K-100K 0.97 1.0 0.97 1.0 0.98 1.0 0.98 1.0 Diagram of Dimensions:(unit:mm) Dφ F dφ α 5 2.0 6.3 2.5 0.5 D<18 1.5 8 3.5 L<20 0.5 L≧20 0.6 10 5.0 D=18 L<35.5 L≧35.5 1.5 2.0 13 5.0 0.6 D>18 2.0 16 7.5 18 7.5 0.8 Radial For Capacitance >1000 μF, add 0.5 per another 1000μF for -25℃ +20℃ add 1 per another 1000μF for -40℃ +20℃ GF Series Case Size φDxL(mm) WV Cap(μF) 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 6.3 Size Ripple 10 Impedance +20℃ -10℃ 5x11 5x11 5x11 6.3x11 6.3x11 6.3x11 6.3x11 8x11.5 8x11.5 8x16 8x16 10x16 8x20 10x12.5 200 210 225 300 360 377 395 576 600 720 800 814 970 1000 0.40 0.38 0.35 0.32 0.25 0.24 0.20 0.14 0.095 0.087 0.080 0.084 0.070 0.055 1.240 1.178 1.085 0.992 0.775 0.744 0.465 0.434 0.294 0.270 0.248 0.260 0.217 0.168 8x20 10x16 10x20 10x25 10x20 10x25 13x20 13x20 13x20 10x30 13x25 13x30 13x35 16x31.5 1150 1180 1400 1560 1500 1720 1890 2080 2290 2450 2670 3200 3270 3490 0.048 0.050 0.045 0.043 0.041 0.037 0.039 0.034 0.026 0.024 0.022 0.021 0.020 0.018 0.146 0.152 0.137 0.131 0.125 0.113 0.119 0.095 0.073 0.067 0.062 0.059 0.056 0.050 Size Ripple 5x11 5x11 5x11 5x11 6.3x11 6.3x11 6.3x11 6.3x15 8x11.5 8x11.5 8x11.5 8x16 8x20 190 210 242 261 300 350 390 460 540 620 750 870 1010 Impedance +20℃ -10℃ 0.70 2.065 0.50 1.475 0.31 0.915 0.28 0.826 0.26 0.767 0.22 0.649 0.18 0.531 0.16 0.472 0.11 0.325 0.095 0.280 0.075 0.221 0.072 0.212 0.068 0.201 8x20 8x20 10x16 10x20 1030 1220 1400 1560 0.065 0.050 0.042 0.035 0.192 0.148 0.124 0.095 10x20 1670 0.032 0.086 10x25 13x20 2000 2370 0.028 0.025 0.076 0.065 13x20 13x25 13x30 2400 2720 3000 0.023 0.021 0.020 0.060 0.055 0.052 13x35 16x31.5 16x31.5 3450 3460 3630 0.019 0.018 0.016 0.049 0.047 0.042 Ripple Current ( mA, rms ) at 105℃ 100KHz Max Impedance (Ω) at 20℃ 100KHz GF Series φpDxL(mm) WV Cap(μF) 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 3300 3900 4700 16 25 Impedance +20℃ -10℃ Size Ripple 5x11 5x11 5x11 5x11 6.3x11 6.3x11 6.3x11 8x11.5 8x11.5 8x11.5 8x11.5 200 220 230 260 360 365 385 520 575 600 740 0.40 0.38 0.35 0.31 0.25 0.23 0.21 0.19 0.14 0.12 0.08 1.16 1.10 1.02 0.90 0.73 0.67 0.61 0.55 0.41 0.35 0.23 8x16 8x16 10x12.5 8x20 8x20 10x16 10x20 10x20 10x25 10x25 13x20 13x20 13x25 13x25 13x35 16x25 16x31.5 790 990 1000 1070 1120 1280 1400 1840 1920 2050 2200 2380 2750 3000 3490 3520 3770 0.075 0.062 0.058 0.057 0.055 0.052 0.048 0.035 0.032 0.030 0.029 0.026 0.022 0.022 0.018 0.018 0.017 0.22 0.18 0.17 0.17 0.16 0.15 0.14 0.09 0.08 0.08 0.07 0.07 0.06 0.06 0.05 0.05 0.04 Size Ripple 5x11 5x11 5x11 6.3x11 6.3x11 6.3x11 6.3x15 8x11.5 8x11.5 8x11.5 8x16 8x16 10x12.5 10x12.5 8x20 10x16 10x20 10x20 210 240 256 300 350 410 490 540 620 750 850 990 1010 1050 1260 1415 1450 1570 Impedance +20℃ -10℃ 0.42 1.218 0.35 1.015 0.31 0.899 0.28 0.812 0.24 0.696 0.15 0.435 0.13 0.377 0.11 0.319 0.098 0.2842 0.075 0.218 0.063 0.183 0.056 0.1624 0.054 0.1566 0.051 0.1479 0.045 0.1305 0.042 0.1218 0.040 0.116 0.035 0.1015 10x25 13x20 13x20 13x25 1910 2340 2390 2710 0.032 0.025 0.025 0.023 0.093 0.055 0.055 0.0506 13x30 13x35 16x31.5 16x31.5 3150 3420 3480 3600 0.021 0.018 0.018 0.018 0.0462 0.0396 0.0396 0.0396 Ripple Current ( mA, rms ) at 105℃ 100KHz Max Impedance (Ω) at 20℃ 100KHz GF Series φDxL(mm) WV Cap(μF) 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 35 Size Ripple 50 Impedance +20℃ -10℃ 5x11 6.3x11 6.3x11 6.3x11 6.3x11 8x11.5 8x11.5 8x11.5 230 277 340 375 400 480 560 585 0.32 0.31 0.20 0.20 0.19 0.17 0.15 0.13 0.934 0.905 0.584 0.584 0.555 0.496 0.438 0.38 8x11.5 8x16 680 810 0.11 0.098 0.321 0.286 8x16 10x12.5 10x16 8x20 10x16 10x20 10x20 10x25 13x20 13x25 1000 1060 1190 1210 1400 1550 1850 2040 2260 2630 0.056 0.052 0.050 0.041 0.038 0.035 0.034 0.031 0.029 0.021 0.164 0.152 0.146 0.12 0.111 0.102 0.064 0.064 0.061 0.053 13x25 13x30 16x25 13x35 16x31.5 16x31.5 16x35.5 18x31.5 2780 2950 3150 3350 3600 3670 3750 3850 0.019 0.019 0.018 0.018 0.017 0.016 0.015 0.014 0.048 0.048 0.045 0.045 0.043 0.04 0.038 0.035 Size Ripple 5x11 6.3x11 6.3x11 6.3x11 8x11.5 8x11.5 8x11.5 8x11.5 8x11.5 8x16 10x12.5 10x12.5 8x20 10x16 10x16 220 265 280 300 360 385 400 550 730 770 790 870 1060 1090 1385 Impedance +20℃ -10℃ 0.35 1.015 0.34 0.986 0.32 0.928 0.28 0.812 0.20 0.580 0.19 0.551 0.17 0.493 0.12 0.348 0.075 0.2175 0.073 0.2117 0.072 0.2088 0.068 0.1972 0.055 0.1595 0.055 0.1595 0.045 0.1305 10x20 10x25 1500 1850 0.043 0.032 0.1247 0.0928 13x20 13x20 13x20 13x25 13x30 16x25 16x25 1910 2000 2150 2490 2770 2960 3000 0.031 0.030 0.028 0.026 0.025 0.024 0.020 0.0899 0.0870 0.0812 0.0754 0.0725 0.0696 0.0580 Ripple Current ( mA, rms ) at 105℃ 100KHz Max Impedance (Ω) at 20℃ 100KHz GF Series φDxL(mm) WV Cap(μF) 4.7 5.6 6.8 10 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 63 Size Ripple 100 Impedance +20℃ -10℃ 5x11 6.3x11 6.3x11 6.3x11 6.3x11 6.3x11 8x11.5 135 168 170 250 260 270 320 0.95 0.85 0.82 0.75 0.55 0.38 0.35 2.755 2.465 2.378 2.175 1.595 1.102 1.015 8x11.5 8x11.5 10x12.5 8x16 10x12.5 10x12.5 8x20 10x16 10x16 10x20 10x25 400 420 500 540 570 720 790 835 900 1200 1315 0.22 0.22 0.20 0.17 0.16 0.14 0.14 0.13 0.11 0.095 0.075 0.638 0.638 0.58 0.493 0.464 0.406 0.406 0.377 0.319 0.276 0.218 13x20 1400 0.071 0.206 10x30 13x25 13x25 13x30 16x21 16x25 1750 1870 1920 2225 1970 2350 0.047 0.045 0.044 0.041 0.043 0.039 0.136 0.131 0.128 0.119 0.125 0.098 16x31.5 16x31.5 16x35.5 18x31.5 2600 2650 2780 3230 0.035 0.031 0.026 0.028 0.088 0.078 0.065 0.070 Size Ripple 5x11 5x11 5x11 6.3x11 8x11.5 8x11.5 8x11.5 8x11.5 8x16 8x16 10x12.5 10x12.5 10x16 10x20 10x20 105 116 120 170 255 270 320 340 400 425 440 450 540 630 720 Impedance +20℃ -10℃ 1.60 4.64 1.49 4.321 1.45 4.205 0.70 2.03 0.61 1.769 0.56 1.624 0.48 1.392 0.39 1.131 0.31 0.899 0.29 0.841 0.27 0.783 0.25 0.725 0.21 0.609 0.18 0.522 0.15 0.435 10x25 10x25 13x20 13x20 13x25 13x30 16x21 13x35 16x25 13x40 890 900 980 1100 1250 1420 1270 1630 1570 1650 0.12 0.12 0.11 0.095 0.078 0.065 0.075 0.057 0.058 0.045 0.348 0.348 0.319 0.276 0.226 0.189 0.218 0.165 0.168 0.131 16x31.5 16x35.5 18x31.5 16x41 18x31.5 18x35.5 1850 1900 1700 2170 2100 2400 0.043 0.032 0.038 0.032 0.031 0.029 0.125 0.093 0.095 0.08 0.078 0.073 Ripple Current ( mA, rms ) at 105℃ 100KHz Max Impedance (Ω) at 20℃ 100KHz
GF471M025F115ETA 价格&库存
很抱歉,暂时无法提供与“GF471M025F115ETA”相匹配的价格&库存,您可以联系我们找货
