CRW1218F100RE04Z
CRW1218F100RE04Z
    EVEROHMS(天二)
    贴片电阻 1218
CRW1218F100RE04Z 数据手册
CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ‘ ■Thick ■ Film Wide Terminal Chip Resistor— CRW Series Application — Navigation equipment ─ Power equipment: Power supply, Illumination equipment ─ Indoor lighting, Central door locking ■ 文件編號/版本 S-10-12-19-02 製作日期 2019/01/14 頁次 1/1 Features — Small size and light weight — Reliability, high quality — Chip resistor of the wide terminal type. CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■ Document No. S-10-12-19-02 Released Date 2019/01/14 1/10 Page No. Type Dimension CRW0612/ CRW1020/ CRW1218/ CRW2030/ CRW1225 ■ Dimension Unit: mm ■ TYPE L W H l1 l2 CRW0612 1.60 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.30 ± 0.20 0.50 ± 0.20 CRW1020 2.50 ± 0.20 5.00 ± 0.20 0.55 ± 0.10 0.40 ± 0.20 0.75 ± 0.20 CRW1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.05 0.40 ± 0.20 0.50 ± 0.20 CRW1225 3.20 ± 0.20 6.50 ± 0.20 0.55 ± 0.20 0.40 ± 0.20 0.75 ± 0.20 CRW2030 5.10 ± 0.10 7.60 ± 0.10 1.20 ± 0.10 0.80 ± 0.20 0.80 ± 0.20 Standard Electrical Specifications Item Type Resistance Range Rated Power at 70℃ Max Working Voltage Max Overload Voltage T.C.R. (PPM/℃) F(±1%) ±400 CRW0612 0.75 W 1Ω~9.9Ω ±200 - 10Ω~10MΩ ±100 10Ω~10MΩ - ±400 CRW1020 1W 200V CRW1218 1W 400V 1Ω~9.9Ω ±200 - 10Ω~10MΩ ±100 10Ω~10MΩ - ±400 1Ω~9.9Ω ±200 - 10Ω~10MΩ ±100 10Ω~10MΩ - ±400 CRW1225 CRW2030 2W 3W J(±5%) 1Ω~9.9Ω ±200 - 10Ω~10MΩ ±100 10Ω~10MΩ - ±100 1Ω~1KΩ CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■ Document No. S-10-12-19-02 Released Date 2019/01/14 2/10 Page No. Low Ohm Chip Resistor Electrical Specifications Item Type Rated Power at 70℃ Rated Voltage Range Max Overload Voltage T.C.R. (PPM/℃) ±1800 CRW0612 CRW1020 CRW1218 CRW1225 CRW2030 ■ 0.75W 0.15~0.86V 1W 0.1~0.99V 1W 0.1~0.99V 2W 0.14~1.41V 3W 0.17~1.72V 2.154V 2.475V 2.475V 3.518 V 4.308V Resistance Range (mΩ) F(±1%)、J±(5%) 30~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 Parts Number Explanation ■ Example: CRW 0612 J 10K0 P 05 Z Product Type Size(Inch) Resistor Tolerance Resistors Value Package Quantity Optional CRW 0612 1020 1218 2030 1225 F:±1% J:±5% P、Q:Paper Taping E:Embossed Taping D:Packed in a Bag 01:1000PCS 04:4000PCS 05:5000PCS CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■ Document No. S-10-12-19-02 Released Date 2019/01/14 3/10 Page No. Appendix For SMD Chip Resistor ● Packaging Information ■ Dimension Unit: mm TYPE ■ SIZE A ψB ψC ψD W ψM 0612 7” 5K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 1020/1218/1225 7” 4K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 16.0±2.0 178±2.0 2030 7” 1K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 19.0±2.0 178±2.0 Tapping Specification ■ Dimension Unit: mm Packaging Type A B W E F G H T Paper Type 0612 1.90±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 ψD P 4.0±0.1 CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications Document No. S-10-12-19-02 Released Date 2019/01/14 4/10 Page No. ■ Dimension Unit: mm Packaging Embossed Type ■ Type E F ■ W 1020 2.80±0.2 5.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 1225 3.40±0.2 6.70±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 1218 3.30±0.2 4.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 2030 5.50±0.2 7.90±0.2 16±0.1 1.75±0.1 7.5±0.05 4.0±0.1 2.0±0.05 0.25±0.1 1.50±0.1 Top Adhesive Peel Off Strength:10~70g H T ψD1 B Packing Material Data/Storage Data ■ Front & Back Lead Dimension G ψD A T1 1.30±0.1 P 4.0±0.1 8.0±0.2 CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■ Document No. S-10-12-19-02 Released Date 2019/01/14 5/10 Page No. Package Inner Box Size Reel Size H(mm) External Box Size 1 13 Contain (Kpcs) Length (mm) Width (mm) Height (mm) 2 24 25K 180 180 60 3 36 50K 180 180 110 5 60 150K 430 200 200 10 113 300K 400 400 200 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. ● Reliability Test and Requirement Test Item Test Method Procedure Requirements Temperature Coefficient of Resistance (T.C.R) JIS C 5201-1 clause 4.8 -55℃ or +155℃, 25℃ is the reference temperature Refer to Ratings Short Time Overload JIS C 5201-1 clause 4.13 General:2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.1Ω) IR Reflow Sony SS-00254 Leaching Sony SS-00254-9 260±5℃ for 30 seconds. >95% Coverage Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.05Ω) Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃,5 cycles 1%: ±(0.5%+0.05Ω) 5%: ±(1.0%+0.10Ω) 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications Document No. S-10-12-19-02 Released Date 2019/01/14 6/10 Page No. Electric Iron Sony SS-00254-5 Preheating temperature:350±10℃ Electric iron preheating time:3+1/-0 sec Resistance to Solvent JIS C 5201-1 clause 4.29 The tested resistor be immersed into isopropyl alcohol of 1%:±(0.5%+0.05Ω) 20~25℃ for 60 secs. 5%:±(0.5%+0.05Ω) Then the resistor is left in the room for 48 hrs. Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. RCWV or Max. working voltage whichever is less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, RCWV or Max. working voltage whichever is less 1%: ±(1.0%+0.05Ω) for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 5%:±(3.0%+0.10Ω) Insulation Resistance JIS C 5201-1 clause 4.6 100V for 1 minute. ≧10GΩ Terminal Bending Strength JIS C 5201-1 clause 4.33 Bending once for 5 seconds D: 0612、1218、1020、1225、2030=2mm 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) ● 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.05Ω) General Information ■ Recommend Land Pattern Design ■ Dimension Type Unit: mm 0201 0402 0603 0805 1206 A 0.60 0.75 2.04 0.85 3.50 B 2.90 3.40 4.24 3.70 7.50 C 3.20 5.00 4.80 6.40 7.80 Item CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■Performance ■ Document No. S-10-12-19-02 Released Date 2019/01/14 7/10 Page No. Characteristics Power Derating Curve DERATING CURVE 100 80 Power Ratio(%) 60 40 155℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Ambient Temperature (℃) Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. ■ Voltage Rating or Current Rating Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: E(RCWV)=√P×R ■ E=Rated voltage(V) P=Power rating(W) R=Nominal resistance(Ω) Product Testing Method: Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and customized-made production is available. Document No. S-10-12-19-02 Released Date 2019/01/14 8/10 Page No. CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■ 0603 E-96 Multiplier Code Code A B C D E F G H X Y Z Multiplier 100 101 102 103 104 105 106 107 10-1 10-2 10-3 CODING FORMULA XX X 2 Example: 10.2KΩ = 102 x 10 Ω =02C Multiplier Code 02 33.2Ω = 332 x 10 Ω =51X Resistance Code 51 ■ C -1 X 0603 Standard E-96 Values and 0603 Resistance Codes R-Value 100 102 105 107 110 Code 01 02 03 04 05 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 R-Value 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 Code 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 R-Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 Code 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 R-Value 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Code 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 CRW-Series Thick Film Wide Terminal Chip Resistor Product Specifications ■     Document No. S-10-12-19-02 Released Date 2019/01/14 9/10 Page No. Standard Resistance Values in a Decade Marking code: 1%: marking code, please refer to E96 and E24 data form as below Ex: 120K, The marking code is 1203 in E24 121K, The marking code is 1213 in E96 5%: marking code, please refer to E24 data form as below Ex: 120K, The marking code is 124 in E24 Note: 0402 series resistor has no marking code. Type: 0603 1% marking code, please refer to E-96 multiplier code. Note: jumper zero ohm resistor marking code is one 「0」 (except type below 0402). E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 100 101 102 104 105 106 107 109 110 111 113 114 115 117 118 120 121 123 124 126 127 129 130 132 133 135 137 138 140 142 143 145 147 149 150 152 154 156 158 160 162 164 165 167 100 100 102 105 105 107 110 110 113 115 115 118 121 121 124 127 127 130 133 133 137 140 140 143 147 147 150 154 154 158 162 165 162 169 172 174 176 178 180 182 184 187 189 191 193 196 198 200 203 205 208 210 213 215 218 221 223 226 229 232 234 237 240 243 246 249 252 255 258 261 264 267 271 274 277 280 284 169 169 174 178 178 182 187 187 191 196 196 200 205 205 210 215 215 221 226 226 232 237 237 243 249 249 255 261 261 267 274 280 274 287 291 294 298 301 305 309 312 316 320 324 328 332 336 340 344 348 352 357 361 365 370 374 379 383 388 392 397 402 407 412 417 422 427 432 437 442 448 453 459 464 470 475 481 287 287 294 301 301 309 316 316 324 332 332 340 348 348 357 365 365 374 383 383 392 402 402 412 422 422 432 442 442 453 464 475 464 487 493 499 505 511 517 523 530 536 542 549 556 562 569 576 583 590 597 604 612 619 626 634 642 649 657 665 673 681 690 698 706 715 723 732 741 750 759 768 777 787 796 806 816 487 487 499 511 511 523 536 536 549 562 562 576 590 619 649 665 681 681 698 715 715 732 750 750 768 787 806 825 845 866 866 887 909 909 931 953 953 976 E24 E12 E6 E3 634 649 825 590 604 619 825 835 845 856 866 876 887 898 909 920 931 942 953 965 976 988 787 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 10 10 10 12 15 15 18 22 22 22 27 33 33 39 47 47 47 56 68 68 82 According to IEC publication 63
CRW1218F100RE04Z
1. 物料型号:文档中列出了多种型号,包括CRW0612、CRW1020、CRW1218、CRW1225和CRW2030。
2. 器件简介:CRW系列是厚膜宽端芯片电阻,适用于导航设备、电源设备、照明设备、室内照明和中央门锁系统等。
3. 引脚分配:文档提供了不同型号的尺寸和引脚分配,例如CRW0612型号的尺寸为1.60mm x 0.20mm,宽度为3.20mm x 0.20mm。
4. 参数特性:包括额定功率、最大工作电压、最大过载电压、温度系数(T.C.R.)、电阻范围等。
5. 功能详解:文档详细描述了电阻的特性,如额定功率、额定电压范围、最大过载电压、温度系数等。
6. 应用信息:适用于小型化和轻量化的应用,强调了可靠性和高质量。
7. 封装信息:提供了不同型号的封装尺寸和包装信息,如7英寸卷装的尺寸和每卷的数量。
8. 可靠性测试和要求:包括温度系数、短时间过载、IR回流、浸出、焊接热、温度循环等测试。
9. 一般信息:推荐焊盘图案设计和性能特性,如功率降额曲线和电压额定值。
10. 产品测试方法:使用四脚探针测试设备进行测试,并提供了测试点或方法的定制选项。
11. 0603 E-96 乘数代码:提供了0603标准E-96值和0603电阻代码表。
12. 标准电阻值:提供了1%和5%的标记代码,以及0402系列电阻没有标记代码的信息。
CRW1218F100RE04Z 价格&库存
很抱歉,暂时无法提供与“CRW1218F100RE04Z”相匹配的价格&库存,您可以联系我们找货
CRW1218F100RE04Z
    • 10+0.26101
    • 100+0.18165
    • 300+0.13258
    • 1000+0.12053
    • 4000+0.11091
    • 8000+0.10610
    库存:335
