Thick Film Chip Resistor — CR Series
Application
— Entertainment: Stereo, TV tuners, Tape recorder
─ Appliance: Air conditioner, Refrigerator
─ Computer & relative products: Main board, PDA
─ Communication equipment: Cell phone, Fax machine
─ Power equipment: Power supply, Illumination equipment
─ Measuring instrument: Electric meter, Navigation equipment
Features
— Small size and light weight
— Reduction of assembly costs and matching with placement machines
— Reliability, high quality and fast delivery
TEL: 886-7-8116611
FAX: 886-7-8115533
E-mail: service@everohms.com
http://www.everohms.com
Type Dimension
CR0402 / CR0603 / CR0805 / CR1206
CR1210 / CR2010 / CR2512
CR1218
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
CR0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.15 ± 0.10
0.20 ± 0.10
CR0603
1.60 ± 0.20
0.80 ± 0.15
0.40 ± 0.10
0.30 ± 0.20
0.30 ± 0.10
CR0805
2.00 ± 0.20
1.25 ± 0.15
0.50 ± 0.15
0.30 ± 0.15
0.40 ± 0.15
CR1206
3.05 ± 0.10
1.60 ± 0.20
0.55 ± 0.15
0.40 ± 0.20
0.50 ± 0.20
CR1210
3.05 ± 0.10
2.50 ± 0.20
0.55 ± 0.15
0.50 ± 0.20
0.50 ± 0.20
CR2010
5.00 ± 0.20
2.50 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
CR1218
3.10 ± 0.10
4.60 ± 0.10
0.55 ± 0.05
0.40 ± 0.20
0.50 ± 0.20
CR2512
6.30 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
TEL: 886-7-8116611
FAX: 886-7-8115533
High Ohm Chip Resistor
Standard & High Power Electrical Specifications
Item
Resistance Range
Rated Power
at 70℃
Max
Working
High Power Voltage
Standard
Max
Overload
Voltage
T.C.R.
(PPM/℃
Operating
Temperature
Range
F(±
±1%)
J(±
±5%)
10.1 MΩ
10.1 MΩ
-55℃
54 MΩ
100 MΩ
+155℃
Type
CR0402
0.063 W
50V
100V
CR0603
0.1 W
0.125 W
50V
100V
CR0805
0.125 W
0.25 W
150V
300V
CR1206
0.25 W
0.5 W
200V
400V
CR1210
0.5W
0.66 W
200V
400V
CR2010
0.75 W
1W
200V
400V
CR1218
1W
200V
400V
CR2512
1W
2W
200V
400V
±200
●For non-standard parts, please contact our sales dept.
Parts Number Explanation
■ Example:
CR
0603
J
10R
P
05
Product Type
Size
(Inch)
Resistor
Tolerance
Resistors
Value
Package
Quantity
Optional
0201
0402
0603
0805
1206
1210
1812
2010
1218
2512
2030
B:±0.1%
C:±0.25%
D:±0.5%
F:±1%
G:±2%
J:±5%
K:±10%
L:±15%
M:±20%
N:±30%
01:1000PCS
02:2000PCS
04:4000PCS
05:5000PCS
10:10000PCS
20:20000PCS
40:40000PCS
50:50000PCS
0.125W
0.25W
0.5W
0.66W
1W
2W
CR: Thick Film
TCR: Trimmable
TEL: 886-7-8116611
FAX: 886-7-8115533
P、Q:Paper Taping
E:Embossed Taping
D:Packed in a Bag
Appendix For SMD Chip Resistor
● Packaging Information
■ Dimension
Unit: mm
TYPE
SIZE
A
ψB
ψC
ψD
W
ψM
7”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
13”
40K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
13”
50K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
7”
5K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
10”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
254±2.0
13”
20K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
1210
7”
5K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
2010
2512
1218
7”
4K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
16.0±2.0
178±2.0
0402
0603
0805
1206
TEL: 886-7-8116611
FAX: 886-7-8115533
Tapping Specification
■ Dimension
Packaging
Unit: mm
Type
A
B
W
E
F
G
H
ψD
T
0402
0.70±0.10 1.20±0.10 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.45±0.10
0603
1.05±0.20 1.80±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.60±0.10
0805
1.55±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
1206
1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10 1.50
-0
2.0±0.05 0.75±0.10
1210
2.85±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10
P
2.0±0.1
+0.10
Paper Type
4.0±0.1
■ Dimension
Packaging
Type
2010
Embossed
Type
Unit: mm
A
B
2.80±0.20 5.60±0.20
W
12±0.10
E
F
1.75±0.10 5.5±0.05
G
4.0±0.10
H
T
ψD
ΨD1
2.0±0.05 0.23±0.10
T1
P
1.50±0.10 0.85±0.15
+0.10
2512
3.40±0.20 6.70±0.20
12±0.10
1.75±0.10 5.5±0.05
4.0±0.10
2.0±0.05 0.23±0.10 1.50
1.50±0.10 0.85±0.15
4.0±0.1
-0
1218
3.30±0.20 4.60±0.20
TEL: 886-7-8116611
12±0.10
1.75±0.10 5.5±0.05
FAX: 886-7-8115533
4.0±0.10
2.0±0.05 0.23±0.10
1.50±0.10 0.85±0.15
Packing Material Data/Storage Data
■ Front & Back Lead Dimension
Top Adhesive Peel Off Strength:
:10~70g
Package
Inner Box Size
Reel Size H(mm)
External Box Size
Contain Length Width Height
(Kpcs)
(mm)
(mm) (mm)
1
13
2
24
25K
180
180
60
3
36
50K
180
180
110
5
60
150K
430
200
200
10
113
300K
400
400
200
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
TEL: 886-7-8116611
FAX: 886-7-8115533
Reliability Test and Requirement
Test Item
Test Method
Temperature
JIS C 5201-1
Coefficient of
clause 4.8
Resistance (T.C.R)
Procedure
Requirements
-55℃ or +155℃, 25℃ is the reference temperature
Refer to Ratings
General:2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
High Power:2.5 times RCWV or Max. Overload
voltage whichever is less for 2 seconds.
±1:±(1.0%+0.05Ω)
±5:±(2.0%+0.10Ω)
Short Time
Overload
JIS C 5201-1
clause 4.13
IR Reflow
Sony SS-00254
±1:±(1.0%+0.05Ω)
±5:±(1.0%+0.05Ω)
Leaching
Sony SS-00254-9 260±5℃ for 30 seconds.
>95% Coverage
Soldering
Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
±1:±(0.5%+0.05Ω)
±5:±(1.0%+0.05Ω)
Temperature
Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃,5 cycles
0.1%、0.5%、1%: ±(0.5%+0.05Ω)
2%、5%:±(1.0%+0.10Ω)
Electric Iron
Sony SS-00254-5
Preheating temperature:350±10℃
Electric iron preheating time:3+1/-0 sec
±1:±(1.0%+0.05Ω)
±5:±(1.0%+0.05Ω)
Resistance to
Solvent
JIS C 5201-1
clause 4.29
The tested resistor be immersed into isopropyl alcohol
of 20~25℃ for 60 secs. Then the resistor is left in the
room for 48 hrs.
±1:±(0.5%+0.05Ω)
±5:±(0.5%+0.05Ω)
Load Life in
Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. RCWV or Max. working voltage
whichever is less for 1000 hrs with 1.5 hrs〝ON〞and
0.5 hr〝OFF〞.
0.1%、0.5%、1%:±(1.0%+0.05Ω)
2%、5%:±(2.0%+0.05Ω)
Value
很抱歉,暂时无法提供与“CR2512J3R90E04S”相匹配的价格&库存,您可以联系我们找货
