MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
NLC Series
Solventproof
•105℃ 10,000Hrs assured.
•Low impedance.
•Long Life.
•For SMPS, IP-Board, Adaptor.
•RoHS compliant.
•Halogen-free capacitors are also available.
WV ≦ 50VDC
NLA
NLC
Ø8↓
Long Life
SPECIFICATIONS
ltem
Characteristics
Rated Voltage Range
6.3 ~ 100 VDC
Operating Temperature Range
-40 ~ +105℃
Capacitance Tolerance
±20%(M)
Leakage Current
(at 20℃, 120Hz)
I=0.01CV(㎂) or 3㎂, whichever is greater.
Where, I: Max.Leakage current(㎂) C: Nominal capacitance (㎌) V: Rated voltage (VDC)
(at 20℃, 2 minutes)
Dissipation Factor
(Tanδ)
Temperature Characteristics
(Max. Impedance ratio)
Load Life
Shelf Life
Rated Voltage(VDC)
Tan δ(Max.)
DIMENSIONS OF NLC Series
10
0.19
16
0.16
25
0.14
35
0.12
50
0.10
63
0.17
100
0.15
(at 20℃, 120Hz)
Rated voltage(VDC)
Z(-25℃)/Z(+20℃)
Z(-40℃)/Z(+20℃)
6.3
10
16
4
3
2
25~35 50~100
2
2
8
6
4
3
4
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃
after the rated voltage with the rated ripple current is applied (the peak voltage shall not
exceed the rated voltage) for 10,000 hours at 105℃.
Capacitance change ≦ ±25% of the initial value
Tan δ
≦ 200% of the initial specified value
Leakage current
≦ The initial specified value
after exposing them for 1,000 hours at 105℃ without voltage applied.
The rated voltage shall be applied to the capacitors for a minimum of 30 minutes,
at least 24 hours and not more than 48 hours before the measurements.
Capacitance change
Tan δ
Leakage current
Others
6.3
0.22
≦ 200% of the initial specified value(where, 300% for ≥WV63VDC)
Satisfied characteristics KS C IEC 60384-4
Unit(mm)
Marking : DARK BROWN SLEEVE, SILVER INK
ØD
8
6.3
5
Ød 0.5 0.5 0.6
F
2.0 2.5 3.5
ØD′ ØD+0.5 max.
L′
L+2.0 max.
172
RATINGS OF NLC Series
6.3
V DC
10
16
IMP.
Ripple
47
0.70
175
250
100
0.50
252
400
330
0.24
400
ØD×L(mm)
IMP.
Ripple
IMP.
Ripple
5×11
150
0.70
175
100
0.70
175
6.3×11
330
0.50
252
220
0.50
8×11.5
680
0.24
400
470
0.24
25
V DC
35
50
IMP.
Ripple
5×11
1
4.0
32
5×11
2.2
3.0
43
5×11
3.3
2.5
84
5×11
4.7
2.5
100
ØD×L(mm)
5×11
IMP.
Ripple
47
0.70
175
100
0.50
252
6.3×11
6.3×11
8×11.5
220
0.24
400
8×15
IMP.
Ripple
33
0.70
175
10
2.0
110
47
0.60
252
22
1.6
228
56
0.50
252
33
1.6
228
150
0.24
400
47
0.80
330
220
0.18
520
100
0.50
400
Impedance (Ωmax./20℃, 100kHz)
63
V DC
100
ØD×L(mm)
Ripple
Ripple
8×11.5
47
270
33
240
Rated Ripple Current (mArms/105℃, 100kHz)
NLC
Nominal Capacitance(㎌)
Freq.(Hz)
Cap.(㎌)
1~150
220~470
680
Series
RATED RIPPLE CURRENT MULTIPLIERS
Frequency Multipliers
120
1k
10k
50k
100k
0.40
0.50
0.60
0.75
0.85
0.87
0.90
0.94
0.95
0.93
0.96
0.97
1.00
1.00
1.00
173
很抱歉,暂时无法提供与“NLC 35V47 6.3*11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.79175
- 50+0.66215
- 200+0.52100
- 400+0.47240
- 2000+0.43352
- 4000+0.41397
