RXC100M2GBK-1020
RXC100M2GBK-1020
    LELON(立隆电子)
    插件,D10xL20mm
    直插铝电解电容 AEC_D10X20MM_TM
RXC100M2GBK-1020 数据手册
Aluminum Electrolytic Capacitors RXC Features ‧ 105℃, 2,000 ~ 3,000 hours assured ‧ Low ESR, suitable for switching power supplies, UPS ‧ Smaller size with large permissible ripple current ‧ RoHS Compliance Sleeve & Marking Color: Brown & White SPECIFICATIONS Items Category Temperature Range Performance 160 ~ 400V -40℃ ~ +105℃ 450V -25℃ ~ +105℃ Time Leakage Current (at 20°C) Dissipation Factor (Tanδat 120Hz, 20°C) Low Temperature Characteristics (at 120Hz) (at 120Hz, 20℃) ±20% Capacitance Tolerance Leakage Current Rated Voltage Tanδ (max) 160 0.20 After 5 minutes CV ≤ 1,000 CV > 1,000 I = 0.03CV(µA) I = 0.02CV(µA) 200 0.20 250 0.20 350 0.24 400 0.24 450 0.24 Impedance ratio shall not exceed the values given in the table below. Rated Voltage 160 200 250 350 400 450 3 3 3 3 5 6 Impedance Z(-25℃)/Z(+20℃) Ratio Z(-40℃)/Z(+20℃) 4 4 4 4 6 - 2,000 Hrs for φD ≦ 10 mm; 3,000 Hrs for φD ≧ 12.5 mm Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000/3,000 hours at 105℃. Test Time Endurance Shelf Life Test Test Time 1,000 Hrs Capacitance Change Within ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Less than 500% of specified value * The above specifications shall be satisfied when the capacitors are restored to 20°C after exposing them for 1,000 hours at 105°C without voltage applied. The rated voltage shall be applied to the capacitors before the measurements (Refer to JIS C 5101-4 4.1). Freq.(Hz) Ripple Current & Frequency Multipliers 2011 Version Cap. (µF) 1 to 82 100 up 120 1k 10k 100k 1.00 1.00 1.20 1.18 1.40 1.35 1.50 1.45 Aluminum Electrolytic Capacitors RXC DIAGRAM OF DIMENSIONS Unit: mm φD+βmax 15 min Sleeve LEAD SPACING AND DIAMETER φD P φd α β P±0.5 L+α max φd Vent≧8φ 4 min 8 3.5 V.DC 160V (2C) φD×L µF φD×L 250V (2E) Ripple Current 120 Hz 100k Hz 3.3 8×11.5 4.7 8×11.5 10 10×16 22 10×16 33 1.5 0.5 φD×L 350V (2V) Ripple Current 120 Hz 100k Hz φD×L 400V (2G) Ripple Current 120 Hz 100k Hz 78 Ripple Current 120 Hz 100k Hz 10×12.5 48 8×11.5 47 71 10×12.5 55 83 10×16 66 72 99 10×12.5 80 120 10×16 75 113 10×20 85 128 8×11.5 58 87 10×12.5 88 132 10×16 105 158 10×20 120 180 10×20 100 150 100 150 10×16 125 188 10×20 165 248 10×20 150 225 10×20 145 218 155 233 10×20 170 255 12.5×20 240 360 12.5×20 240 360 12.5×25 260 390 10×20 220 330 12.5×20 275 415 12.5×25 365 550 12.5×25 300 450 12.5×25 285 430 47 12.5×25 340 510 12.5×20 295 445 12.5×25 390 585 16×25 410 615 16×31.5 445 665 68 12.5×25 385 580 12.5×25 395 595 16×25 485 730 16×31.5 485 730 16×31.5 490 735 100 12.5×25 450 655 16×25 550 800 16×31.5 630 915 16×31.5 520 755 18×31.5 610 885 150 16×25 610 885 16×31.5 720 1,045 18×31.5 780 1,130 220 16×31.5 755 1,095 18×35.5 900 1,305 18×40 970 1,405 330 18×35.5 940 1,360 V. DC 52 φD×L 72 Contents 48 18 7.5 0.8 0.6 1.5 2.2 16 Dimension: φD × L(mm) Ripple Current: mA/rms, 105°C 200V (2D) Ripple Current 120 Hz 100k Hz 12.5 5.0 1.0 DIMENSION & PERMISSIBLE RIPPLE CURRENT Contents 10 450V (2W) φD×L µF Ripple Current 120 Hz 100k Hz 1.5 10×12.5 50 75 2.2 10×16 68 102 3.3 10×20 88 132 4.7 12.5×20 140 210 10 12.5×25 200 300 22 16×25 305 460 33 16×31.5 410 615 47 18×31.5 495 745 68 18×35.5 540 810 2011 Verison
RXC100M2GBK-1020 价格&库存
很抱歉,暂时无法提供与“RXC100M2GBK-1020”相匹配的价格&库存,您可以联系我们找货
