REA470M2CBK-1020
REA470M2CBK-1020
    LELON(立隆电子)
    插件,D10xL20mm
    直插铝电解电容 AEC_D10X20MM_TM
REA470M2CBK-1020 数据手册
Aluminum Electrolytic Capacitors REA Features ‧85℃, 2,000 ~ 3,000 hours assured ‧Standard series for general purpose ‧ RoHS Compliance Sleeve & Marking Color: Blue & Black SPECIFICATIONS Performance Items -40℃ ~ +85℃ Category Temperature Range ±20% Capacitance Tolerance Leakage Current (at 20℃) Dissipation Factor (Tanδ at 120 Hz, 20℃) Rated voltage ≦100V Time after 2 minutes (at 120Hz, 20℃) >100V after 5 minutes CV > 1,000 CV ≦ 1,000 I = 0.01CV or 3 (μ A) Leakage Current I = 0.03CV+15(μ A) I = 0.02CV+25(μ A) whichever is greater Where, C = rated capacitance in μF V = rated DC working voltage in V Rated Voltage 6.3 10 16 25 35 50 63 100 160 200 250 350 400 450 Tanδ(max) 0.23 0.20 0.16 0.14 0.12 0.10 0.09 0.08 0.12 0.14 0.17 0.20 0.25 0.25 When the capacitance exceeds 1,000μ F, 0.02 shall be added every 1,000μ F increase. Impedance ratio shall not exceed the values given in the table below. Rated Voltage Low Temperature Characteristics (at 120Hz) 6.3 10 16 25 35 50 63 100 160 200 250 350 400 450 Z(-25℃) φD<16 6 4 3 3 2 2 2 2 Impedance /Z(+20℃) φD≧16 8 Ratio Z(-40℃) φD<16 10 6 4 4 3 3 3 3 8 6 6 4 3 3 3 /Z(+20℃) φD≧16 18 16 12 10 8 8 6 6 Test Time Endurance 3 6 8 12 14 16 4 8 10 16 18 20 2,000 Hrs (3,000 Hrs forφD≧10mm) Capacitance Change With in ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied with rated ripple current for 2,000/3,000 hours at 85℃. Shelf Life Test Test Time 1,000 Hrs Capacitance Change With in ±20% of initial value Dissipation Factor Less than 200% of specified value Leakage Current Within specified value * The above specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. The rated voltage shall be applied to the capacitors before the measurements for 160 ~ 450V (Refer to JIS C 5101-4 4.1). Freq. (Hz) Ripple Current & Frequency Multipliers 2011 Version Cap. ( μF) 60 (50) 120 500 1k 10k up 1.50 Under 100 0.70 1.00 1.30 1.40 100<C≦1,000 0.75 1.00 1.20 1.30 1.35 1,000 up above 0.80 1.00 1.10 1.12 1.15 Aluminum Electrolytic Capacitors REA DIAGRAM OF DIMENSIONS φD+βmax 15 min Sleeve LEAD SPACING AND DIAMETER φD P φd α β P±0.5 L+α max φd Vent≧6.3φ 4 min µF 6.3V (0J) φD×L mA *φD×L 10V (1A) mA φD×L mA *φD×L Contents 4R7 10 100 22 220 33 330 5×11 47 470 5×11 100 101 5×11 130 5×11 145 220 221 6.3×11 230 5×11 200 6.3×11 250 5×11 220 330 331 8×11.5 290 6.3×11 270 8×11.5 350 6.3×11 290 470 471 8×11.5 380 6.3×11 320 8×11.5 415 6.3×11 1,000 102 8×11.5 540 10×12.5 650 8×11.5 10×20 1,000 10×20 12.5×20 1,070 1,240 10×20 12.5×20 12.5×20 16×25 12.5×25 16×25 1,185 1,380 1,545 1,880 1,880 2,120 222 3,300 332 4,700 472 6,800 682 1.0 16 7.5 1.5 Unit: mm 18 22 7.5 10 0.8 1.0 2.0 0.5 φD×L mA *φD×L 25V (1E) mA φD×L mA 5×11 31 *φD×L mA 5×11 49 5×11 54 5×11 75 5×11 80 72 5×11 84 5×11 90 5×11 97 90 5×11 100 5×11 110 5×11 115 6.3×11 180 5×11 160 6.3×11 190 8×11.5 300 6.3×11 260 8×11.5 320 8×11.5 370 6.3×11 290 10×12.5 470 8×11.5 440 350 10×12.5 520 8×11.5 440 545 10×16 785 10×12.5 635 930 1,160 1,240 1,460 1,600 1,700 1,890 2,170 620 955 1,090 1,540 1,660 1,800 2,070 2,100 2,420 10×12.5 550 10×16 10×20 12.5×20 12.5×25 16×25 16×25 16×31.5 16×25 16×31.5 18×35.5 2,450 mA 16×25 2,330 22,000 223 18×40 3,320 µF 12.5 5.0 70 103 V. DC 0.5 10 5.0 0.6 5×11 10,000 10×16 845 mA 12.5×16 970 12.5×16 960 12.5×20 1,420 16×16 1,310 16×16 1,410 12.5×25 16×25 1,780 1,980 16×20 1,660 16×25 2,220 16×20 18×20 18×31.5 2,000 2,020 2,780 16×31.5 16×35.5 22×40 2,370 2,430 3,790 16×16 16×20 16×20 18×20 16×20 18×25 18×40 1,420 1,560 1,700 1,870 2,050 2,370 3,370 mA φD×L mA 35V (1V) Contents φD×L 8 3.5 16V (1C) mA 4.7 2,200 6.3 2.5 Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 85°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 5 2.0 *φD×L 12.5×20 1,295 12.5×20 12.5×25 16×25 16×31.5 16×25 16×31.5 1,450 1,655 2,090 2,260 2,280 2,520 12.5×16 16×16 16×16 16×20 16×20 18×20 18×20 18×25 18×31.5 2,590 16×35.5 22×40 3,900 φD×L mA 50V (1H) *φD×L 12.5×16 830 16×16 16×20 16×20 18×20 1,150 1,360 1,490 1,720 18×25 2,170 2,880 18×31.5 2,550 22×40 3,440 18×40 3,080 φD×L mA 63V (1J) mA *φD×L 100V (2A) *φD×L mA 0.1 0R1 5×11 1.5 5×11 3 5×11 3 0.22 R22 5×11 3.5 5×11 4.5 5×11 5.8 0.33 R33 5×11 5 5×11 7.5 5×11 8.8 0.47 R47 5×11 7 5×11 9.5 5×11 12 1 010 5×11 15 5×11 17 5×11 22 2.2 2R2 5×11 29 5×11 30 5×11 33 3.3 3R3 5×11 35 5×11 37 5×11 40 4.7 4R7 5×11 40 5×11 42 5×11 45 5×11 48 10 100 5×11 58 5×11 65 5×11 70 6.3×11 80 5×11 59 22 220 5×11 87 5×11 95 6.3×11 115 8×11.5 135 6.3×11 115 33 330 6.3×11 115 5×11 108 6.3×11 136 8×11.5 150 6.3×11 140 10×16 195 8×11.5 145 47 470 6.3×11 145 5×11 130 6.3×11 165 8×11.5 190 6.3×11 170 10×16 255 10×12.5 235 100 101 8×11.5 240 6.3×11 210 8×11.5 260 10×12.5 320 8×11.5 245 10×20 370 10×16 325 220 221 10×12.5 420 8×11.5 385 10×16 490 10×12.5 455 10×20 565 10×16 490 12.5×25 675 12.5×20 640 330 331 10×16 570 10×12.5 490 710 16×25 825 16×20 695 740 585 610 745 10×20 10×16 10×16 12.5×16 16×16 765 471 16×25 1,050 12.5×20 900 16×31.5 1,070 16×25 910 1,000 102 12.5×20 1,145 635 755 860 1,340 1,530 12.5×20 470 12.5×20 10×20 12.5×20 12.5×25 16×25 16×20 1,160 16×25 1,560 16×20 1,260 22×40 2,600 18×40 2,410 16×16 1,010 5×11 125 16×25 1,785 16×20 1,390 2,200 222 18×40 2,231 16×35.5 2,075 18×40 2,385 18×31.5 1,955 16×31.5 1,890 18×20 1,560 16×31.5 2,070 3,300 332 18×25 1,970 22×40 2,785 18×35.5 2,500 22×40 3,000 18×40 2,660 16×35.5 2,275 4,700 472 18×35.5 2,700 Remark: The Case size 12.5×16, 16×16, 16×20, 18×20 and 18×25 are used flat type rubber bung. Case size in mark of “*” is downsize. 2011 Verison Aluminum Electrolytic Capacitors Dimension: φD × L(mm) Ripple Current: mA/rms at 120 Hz, 85°C DIMENSION & PERMISSIBLE RIPPLE CURRENT V. DC 160V (2C) Contents φD×L REA 200V (2D) 250V (2E) 350V (2V) mA *φD×L mA φD×L mA *φD×L mA φD×L mA *φD×L mA φD×L mA *φD×L mA R47 6.3×11 15 5×11 13 6.3×11 16 5×11 14 8×11.5 21 5×11 14 8×11.5 21 6.3×11 18 1 010 6.3×11 24 5×11 20 6.3×11 25 5×11 21 8×11.5 32 5×11 21 8×11.5 32 6.3×11 27 2.2 2R2 6.3×11 34 5×11 29 6.3×11 37 5×11 29 8×11.5 49 6.3×11 42 8×11.5 49 6.3×11 42 3.3 3R3 8×11.5 50 6.3×11 43 8×11.5 54 6.3×11 46 8×11.5 60 6.3×11 46 10×12.5 70 8×11.5 60 4.7 4R7 8×11.5 60 6.3×11 51 8×11.5 64 6.3×11 50 10×16 93 8×11.5 72 10×16 93 10×12.5 80 10 100 10×12.5 104 8×11.5 75 10×12.5 112 8×11.5 81 112 10×20 150 10×16 138 220 10×20 189 10×16 150 12.5×16 280 12.5×25 282 12.5×20 255 228 270 318 354 490 510 582 710 138 220 255 310 348 420 468 10×12.5 22 10×16 10×20 12.5×20 12.5×20 12.5×25 12.5×25 16×25 16×16 350 16×25 390 12.5×25 348 16×20 420 16×31.5 474 16×20 385 18×20 490 16×35.5 732 16×31.5 645 18×40 685 16×31.5 645 22×40 1,150 18×40 985 µF 0.47 10×20 204 10×16 155 10×20 12.5×20 12.5×20 12.5×25 18×20 16×25 16×35.5 230 288 330 378 490 582 678 12.5×16 16×16 16×16 16×20 16×16 16×20 18×25 280 350 390 420 470 520 590 18×31.5 885 68 680 100 101 150 151 10×20 12.5×20 12.5×20 12.5×25 16×20 12.5×25 16×25 18×25 220 221 18×35.5 900 16×31.5 792 18×35.5 1,000 330 331 18×40 1,010 18×35.5 984 18×40 1,200 33 330 47 470 V. DC 12.5×16 305 12.5×16 16×16 16×16 16×20 18×20 18×20 360 420 440 560 590 640 400V (2G) Contents φD×L 450V (2W) mA *φD×L mA φD×L mA *φD×L mA R47 8×11.5 21 5×11 15 8×11.5 21 6.3×11 18 1 010 8×11.5 32 5×11 22 8×11.5 32 6.3×11 25 2.2 2R2 10×12.5 57 6.3×11 33 10×12.5 57 8×11.5 45 3.3 3R3 10×16 78 78 4R7 10×20 103 40 80 55 10×16 4.7 8×11.5 10×12.5 8×11.5 10×20 103 10×12.5 10×12.5 8×11.5 65 80 55 10×20 12.5×20 12.5×20 12.5×25 16×25 16×25 16×31.5 18×31.5 140 174 240 280 390 445 475 560 12.5×16 150 12.5×20 174 10×20 140 16×16 280 16×25 354 12.5×25 300 16×20 355 16×31.5 435 16×20 355 18×20 435 16×35.5 510 16×31.5 475 18×31.5 560 µF 0.47 10 100 22 220 33 330 47 470 82 820 18×40 630 18×35.5 600 Remark: The case size of 12.5×16, 16×16, 16×20, 18×20 and 18×25 are used flat type rubber bung Case size in mark of “*” is downsize. 500 WV specifications are available upon request. 100 101 2011 Version 22×40 710 18×35.5 600 22×45 750
REA470M2CBK-1020 价格&库存
很抱歉,暂时无法提供与“REA470M2CBK-1020”相匹配的价格&库存,您可以联系我们找货
