PPB102J3DD2R8LC
PPB102J3DD2R8LC
    SRD(圣融达)
    插件,P=15mm
    薄膜电容 径向
PPB102J3DD2R8LC 数据手册
金属化聚丙烯膜箔式高压盒装电容器---CBB81B(PPB)系列 Metallized Polypropylene Film And Foil Capacitors(Box )---CBB81B(PPB)series ■ 引用标准 Reference standards GB10188(IEC384-13) ■ 结构 Structure 介质:聚丙烯膜 电极:金属真空蒸发层 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: Polypropylene film. Electrode: metal vacuum evaporation layer. Encapsulation: inflame retardant power epoxy resin, conforming to UL94 V-0. Shell: imflame retardant PBT plastic shell, conforming to UL97 V-0. ■ 典型应用 Typical Application 高频、直流、交流及脉冲大电流场合. 如・灯具、电源、显示器及彩电行逆程线路等 电子镇流器、节能灯等. high frequency, direct current, alternating current or large pulse current occasion For example damp, power supply, display and colorful TV lines retrace circuits, electronic rectifier, energy-saving lamps etc. ■ 特点 Features 体积小,有良好自愈性能。高频损耗小,温升低 高冲击强度。高频交流条件下有良好的耐电压性能。 Small volume with good self-healing property, low dissipation at high frequency, low temperature rise, high dielectric strength. Good property to withstand voltage at high frequency in alternating current occasion. ■ ■ 符合 RoHS 及 REACH 环保标准 Compliance with RoHs & 电性能规范 Performance Specifications REACH requirements. 气候类别 Climate category -40-+85 ( 105)℃/56d 额定温度 Rated Temperature 85℃ 工作温度范围 -40℃--+105℃. Operating Temperature range (+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC) (+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC) 额定电压 Rated Voltage 630VDC, 1000VDC, 1250VDC, 1600VDC, 2000VDC, 3000VDC 容量误差 Capacitance Tolerance J: ±5% 容量范围 0.0010μF~0.22μF Capacitance Range 测试条件 Test Condition: 耐电压 Withstand Voltage 20℃, 1KHz, 1Vrms 无击穿或飞弧 2.0UR,5S No breakdown or electric arcing 损耗角 Dissipation factor ≤0.001 绝缘电阻或时间常数 CR≤0.1μF IR≥30000MΩ Insulation Resistance CR>0.1μF IR≥10000S (1KHZ ) 测试条件 Test Condition : 20℃ 1Vrms 测试条件 Test Condition : 20℃ 100V 1 min 最大脉冲爬升速率 P10 P15 P22.5 P27.5 P31.5 Max. Pulse Rise Time (dV / dt) 1200 1500 1000 1000 1000 金属化聚丙烯膜箔式高压盒装电容器---CBB81B(PPB)系列 Metallized Polypropylene Film And Foil Capacitors(Box )---CBB81B(PPB)series ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change ( relative to the initial value):△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0020(1KHZ),CR>1uF 耐久性试验 温度 Temp.: +85℃, 绝缘电阻 Insulation Resistance Endurance Test 电压 Voltage: IR:≥ 额定值的 50% IR:≥ 50% of rated value 1.25 Times Rated Voltage 持续时间 Duration Time: 1000H 损耗角增加:≤0.0040 dissipation factor rise:≤0.0040 容量变化(相对初始值):△C/C≤±10% Capacitance change (relative to the initial value):△C/C≤±10% ■ 产品编码说明 Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 P Digit 1-3 P B 1 0 3 J 3 型号代码 Product Name Code A D 11 12 13 14 15 2 R 8 * * PPB= CBB81B series Digit 4-6 标称容量 Rated Capacitance Value For example : 103 = 10×103pF = 0.01F Digit 7 容量偏差 Capacitance Tolerance J=±5% K=±10% Digit 8-9 额定电压 Rated Voltage Code 2J=630V 3A=1000V 3C=1600V 3D=2000V Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use 金属化聚丙烯膜箔式高压盒装电容器---CBB81B(PPB)系列 Metallized Polypropylene Film And Foil Capacitors(Box )---CBB81B(PPB)series ■ 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 系列 Part No. Series Capacitance (μF) 尺寸 Dimension (mm) W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 12 21.5 22.5 0.8 UR :1000Vdc PPB683K3AE6R8LC CBB81B 0.068 26 UR :2000Vdc PPB102J3DD2R8LC CBB81B 0.001 18 6 12 15.0 0.8 PPB103J3DE2R8LC CBB81B 0.01 26.5 7 16.5 22.5 0.8 PPB153J3DE3R8LC CBB81B 0.015 26.5 85 17 22.5 0.8 PPB183J3DE6R8LC CBB81B 0.018 26 12 21.5 22.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use.
PPB102J3DD2R8LC 价格&库存
很抱歉,暂时无法提供与“PPB102J3DD2R8LC”相匹配的价格&库存,您可以联系我们找货
