STANDARD SPECIFICATION
产品规格书
Customer:
Customer Part NO.:
Type & Freq:
SX-3225 27.120MHZ
TKD Part NO.:
SX32Y027120BA1T
10PF
±10PPM
Customer Approval :
(PLEASE RETURN A COPY WITH APPOVAL)
HUBEI TKD ELECTRONICS TECHNOLOGY CO.,LTD.
湖北泰晶电子科技股份有限公司
SUIZHOU TAIWARD ELECTRONIC TECHNOLOGY CO.,LTD
随州泰华电子科技有限公司
APPROVED
CHECK
DESIGNER
J.T Wang
Y Yang
Y.H Liao
地址:湖北省随州市经济开发区深圳工业园泰华科技
TEL:0722-7509016
FAX:0722-7509036
Page 1
REVISION
Rev
Date
00
2017-08-22
NO.
Description of Revision History
TEL:0722-7509016
FAX:0722-7509036
New Publication
Page 2
Spec Sheet Contents
NO.
Content
Page
1
QUARTZ CRYSTAL UNIT SPECIFICATION
4
2
DIMENSIONS & MARKING
5
3
INSIDE STRUCTURE
6
4
EQUIVALENT CIRCUIT
6
5
RELIABILITY SPECIFICATION
6
PACKING
9
7
FLOW CHART
10
8
HARMFUL SUBSTANCE CONTENT STATEMENT
11
TEL:0722-7509016
FAX:0722-7509036
7-8
Page 3
※ 1. QUARTZ CRYSTAL UNIT SPECIFICATION
1. Frequency:
27.120000MHz
2. Holder type :
SX-3225
3. Oscillation Mode:
Fundamental
4. Cutting Mode
AT cut
5. Measurement Instrument
S&A 250B(Measured FL)
6. Frequency Tolerance:
±10ppm at 25℃± 3℃
7. Equivalent Series Resistance:
40ΩMax.
8. Storage Temperature Range:
-40℃ ~ +85℃
9. Operating Temperature
-20℃ ~ +70℃
10.Frequency Stability:
Refer to Operating Temperature
±15PPM @ -20℃ ~ +70℃
11. Drive Level:
100uW/Max
12. Load Capacitance(CL):
10pF
13. Shunt Capacitance:
3.0pF
14. Insulation resistance :
500MΩ min /DC 100V
15. Aging:
±3ppm / Year
16. PACKING:
3000PCS / Reel
MAX
17. NOTE:
TEL:0722-7509016
FAX:0722-7509036
Page 4
※ 2.DIMENSIONS & MARKING
2.1 DIMENSIONS:
2.2 MARKING:
Frequency (MHz)
eg. 27.12=27.120000MHz
27.12
T YM
Y: Year code
M:Month code
TKD
Year : 1 2 3 4 5 6 7 8 9 0
Month : 1 2 3 4 5 6 7 8 9 10 11 12
Code: A B C D E F G H J K L M
TEL:0722-7509016
FAX:0722-7509036
Page 5
※ 3. INSIDE STRUCTURE
No.
COMPONENTS
MATERIALS
1
Package
Ceramic (AI2O3)
2
LID
KV(Fe/Co/Ni)
3
Crystal blank
SiO2
4
Electrode
Noble Metal(Ag)
5
Adhesive
Resin、Ag
※ 4. EQUIVALENT CIRCUIT
TEL:0722-7509016
FAX:0722-7509036
Page 6
※ 5. RELIABILITY SPECIFICATION
NO.
1
JIS C 6701
REFER
ITEM
FREE FALL
CONDITIONS
BASIS OF VERDICT
FREE DROPPING FROM 75 cm HEIGHT 3 TIMES
ON A HARD
F±5ppm
CI±15% or 5Ω
FREQUENCY
2
VIBRATION
:10〜55Hz,
:1.5mm±15%,
:1MIN, 3 DIRECTION(X, Y, Z) EACH
AMPLITUDE (TOTAL EXCURSION)
SWEEP TIME
F±5ppm
CI±15% or 5Ω
FOR 2 Hrs.
THE CRYSTAL UNIT SHALL BE SUBJECTED TO 100
SUCCESSIVE CHANGE OF TEMPERATURE CYCLES
+85+4/-0
30
3
TEMPERATURE
CYCLE
+25
±3min
F±5ppm
CI±15% or 5Ω
±2℃
-40+0/-6℃
30±3min
1 Cycle
4
FINE LEAK
HELIUM BOMBING 5.0
PEAK:260℃ ± 10℃
〜5.5 Kgf / cm²,FOR 2 HOURS.
≤1×10-9Pa.m3/s
Time:15±5 sec
15±5sec
260±10
5
RESISTANCE
TO SOLDERING
HEAT
217
150~200
SOLDERABILITY
7
HIGH TEMP. &
HUMIDITY
HIGH
8
TEMPERATURE
STORAGE
℃以上
90±30sec
6
105±45sec
± ℃ SOLDER
THE LEAD IS IMMERSED IN A 260 5
BATH WITHIN 2±0.6 SECONDS.
± ℃ AND HUMIDITY 90〜95% FOR
STORED AT 60 2
500
±12 H.
F±5ppm
CI±15% or 5Ω
STORED AT 85±2
more than 95% of lead shall be
covered by new solder
F±5ppm
CI±15% or 5Ω
℃ FOR 720±12H. ( If Customer's
temperature request is higher than the
standard,Temperature test must be done for customer
F±5ppm
CI±15% or 5Ω
requirements. )
TEL:0722-7509016
FAX:0722-7509036
Page 7
LOW
9
TEMPERATURE
STORAGE
STORED AT –40±2
℃ FOR 500±12H. ( If Customer's
temperature request is lower than the
F±5ppm
CI±15% or 5Ω
requirements. )
SHALL BE PRESSURIZED AT A SPEED OF
APPROX.0.5mm/sec IN
THE DIRECTION INDICATED BY THE ARROW
UNTIL THE
10
TERMINAL
STRENGTH
BENDING WIDTH REACHES 3mm AND HELD FOR 5
SECONDS.
F±5ppm
CI±15% or 5Ω
A R0.5 JIG SHALL BE USED TO APPLY A 10N DEAD
LOAD IN THE
DIRECTION INDICATED BY THE ARROW TO THE
ELEMENT AND
RETAIN IT FOR 10 SECONDS.
11
F±5ppm
CI±15% or 5Ω
STICKING
TENDENCY
A R0.5 PRESSURIZED BAR SHALL BE USED TO
APPLY A 10N
LOAD IN THE CENTER OF ELEMENT AND RETAIN
ELEMENT
12
ASSEMBLY
IT FOR 10
SECONDS.
STRENGTH
TEL:0722-7509016
FAX:0722-7509036
F±5ppm
CI±15% or 5Ω
Page 8
※ 6. PACKING
6.1 CARRIER TYPE(unit:mm)
Marking
Marking
A
B
C
D
E
F
G
H
J
K
t
2.7
3.4
8.0
3.5
1.75
4.0
2.0
4.0
1.55
1.4
0.25
6.2 REEL(unit:mm)
M
N
P
Q
R
S
U
178.0
60.2
11.5
8.0
2.5
11.0
13.0
TEL:0722-7509016
FAX:0722-7509036
Page 9
※ 7. FLOW CHART
TEL:0722-7509016
FAX:0722-7509036
Page 10
※ 8. HARMFUL SUBSTANCE CONTENT STATEMENT
随州泰华电子科技有限公司 SX-3225 产品
有毒有害物质或元素的名称及含量表
有毒有害物质或元素
材料名称
铅(Pb)
汞(Hg)
镉(Cd)
六价铬
(Cr(VI))
多溴联苯
(PBB)
多溴二苯醚
(PBDE)
BLANK
ND
ND
ND
ND
ND
ND
Package
ND
ND
ND
ND
ND
ND
LID
ND
ND
ND
ND
ND
ND
Electrode
Adhesive
ND
ND
ND
ND
ND
ND
ND
ND
ND
ND
ND
ND
备注
拆分部件 n
○:表示该有毒有害物质在该部件所有均质材料中的含量均在 SJ/T11363-2006 规定的限量要求以下
×:表示该有毒有害物质至少在该部件的某一均质材料中的含量超出SJ/T11363-2006 规定的限量要求。
(供应商应将其原材料按要求进行拆分,并按照此表格进行详细标注,对不能满足标准要求的零部件进行具体
的原因描述)
TEL:0722-7509016
FAX:0722-7509036
Page 11
很抱歉,暂时无法提供与“SX32Y027120BA1T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.55430
- 10+0.45600
- 30+0.37510
- 100+0.33770
- 300+0.30790
- 3000+0.28990
