X5H015360FK1H-X
X5H015360FK1H-X
    HELE(加高电子)
    SMD5032_2P
    无源晶振 SMD5032_2P
X5H015360FK1H-X 数据手册
SPECIFICATIONS FOR APPROVAL GP X5H015360FK1H-X Customer Part No.: HELE. Part No: Application For: Products: Accepted Model: Type & Freq.: HSX530G/ 15.360MHz EOS-C30225-1 Sample Order No: Date: QUARTZ CRYSTAL 2012/03/14 Approved By : HARMONY ELECTRONICS CORP. HARMONY ELECTRONICS (THAILAND) CO., LTD. HARMONY ELECTRONICS (SHENZHEN) CORP., LTD. TAIPEI OFFICE: 公司:(114) 台北市內湖區堤頂大道 2 段 409 號 2 樓 2F., NO.409, SEC.2, TIDING BLVD., NEIHU DISTRICT, TAIPEI CITY 114, TAIWAN (R.O.C.) TEL:886-2-26588883 FAX:886-2-26588683 TAIWAN FACTORY: 工廠:(831) 高雄市大寮區大發工業區華東路 39 號 No.39, Hua dong Rd., Daliao Dist.,Dafa Industrial Park., Kaohsiung City 831, Taiwan (R.O.C.) TEL: (07)787-1555-6 FAX: (07)787-1557 Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY THAILAND FACTORY: 66MOO 5, KAONGU-BEOKPRAI RD., T.BEOKPRAI, A. BANPONG, RAJCHABUREE PROVINCE 70110, THAILAND TEL: (032)221994-6, 200740-1 FAX: (032)200742 SHENZHEN FACTORY: 深圳市福永鎮塘尾村塘橋路聚源工業區 QIAO TANG RD., TANGWEI VILLAGE FU YONG TOWN SHENZHEN CITY CHINA TEL: 0755-7309272 / 7309262 FAX: 0755-7309755 Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 1 HSX530G SPECIFICATION INDEX ITEM PAGE 1. QUARTZ CRYSTAL UNIT SPECIFICATION............. 3 2. MARKING & DIMENSIONS.................... 4 3. INSIDE STRUCTURE....................... 5 4. EMBOSS CARRIER TAPE&REEL.................. 6 a. DIMENSIONS OF CARRIER TAPE................ 6 b. DIMENSIONS OF REEL..................... 6-7 c. STORAGE CONDITION..................... 7 d. STANDARD PACKING QUANTITY................. 7 e. MATERIAL OF TAPE....................... 7 f. LABEL CONTENTS....................... 7 g. TAPING DIMENSION....................... 8 h. JOINT OF TAPE......................... 8 i. RELEASE STRENGHT OF COVER TAPE............... 8 j. PACKAGE.......................... 9 5. MECHANICAL ENDURANCE................... 10-11 6. ENVIRONMENTAL ENDURANCE................. 12 7. Flow Chart........................... 13 8. Environmental Workload Chemical Substance Components List.. 14 9. TEST DATA............................ Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 2 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 15.360000MHz 2. Holder type : HSX530G 3. Frequency tolerance: +/-30ppm at 25deg.C+/- 3deg.C 4. Equivalent resistance: 100 ohms Max. / SERIES 5. Storage temperature range: -40deg.C To +85deg.C 6. Operable temperature range: -40deg.C To +85deg.C 7. Temperature drift: +/-50ppm 8. Loading capacitance (CL) : 20.0pF 9. Drive level: 10 uW 10. Shunt Capacitance: 7.0 pF Max. 11. Insulation resistance : More than 500M ohms at DC 100V 12. Mode of oscillation: Fundamental 13. Circuit: Measured in HP/E5100A,S&A 250B 14. Shocking : Dropping from 50 cm height 3 times on firm wood Variation : -40deg.C To +85deg.C (300uW Max) Frequency less than +/-5 ppm Resistance less than +/- 15 ﹪or 2ohms max. 15. Aging: Less than +/-5 ppm/Year 16. Holder HSX530G Ceramic Base 17.Dimensions and marking Refer to page.4 18 Emboss carrier tape & reel 19 Note: Refer to page.6 and page.7 Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 3 2. HSX530G MARKING & DIMENSIONS *Marking should be printed as following: Nominal Frequency, Logo, Manufactured year & month *Nominal frequency (j)= 3 number after decimal point MAX. ( ex. 12.000 MHz Æ 12.000 ) *Manufacturing Lot No. (Y: year) ex. 2000 shall be marked as ‘ 0 ’ (As shown on the Table-1) (M: month) ex. June shall be marked as ‘ F ‘ (As shown on the Table-2). Marking : Laser marking. (Table-1) Year Code 2000 2010 0 2001 2011 1 2002 2012 2 2003 2013 3 2004 2014 4 2005 2015 5 2006 2016 6 2007 2017 7 2008 2018 8 2009 2019 9 (Table-2) Jan. A Feb. B Mar. C Apr. D May. E Jun. F Jul. G Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Aug. H Sep. J Oct. K Nov. L Dec. M Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 4 3. INSIDE STRUCTURE ※Reference drawing (1) Base: Alumina Ceramic (Al2O3) Metallized Pad: Ni Plating Au Plating (2) Cap: Alumina Ceramic (Al2O3) (3) Crystal Enclosure Seal: Seal Glass (4) Crystal Blank Rectangular At-Cut Quartz Crystal Blank (5) Adhesive Silver Conductive Silicon Resin (6) PAD Alumina Ceramic (Ni. Au) Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY The use prohibition chemistry substance of Table 1 of DHE-0204-1 (HE-QA-24) is not included in this item. Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 5 4. HSX530G EMBOSS CARRIER TAPE & REEL a.) Dimensions of Carrier Tape b.) Dimensions of Reel Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 6 (Table-2) (UNIT: mm) MARK DIMENSIONS‧ANGLE Diameter A ψ180+0/-3 Inner Width W1 12.8+/-0.3 Outer Width W2 Out Line diameter B 15.5+/-1.0 ψ60.5+/-0.5 F1 3.0+0.5/-0 F2 4.0+0.5/-0 F3 5.0+0.5/-0 q C 120deg ψ13.2+/-0.5 E 3.0+/-0.2 ITEM FLANCE HUB Width Center Core slit Position Spindle diameter Key Ditch Width c.) Storage condition Temperature: +40℃ Max. Relative Humidity: 80% Max. d.) Standard packing quantity 1,000 PCS / REEL e.) Material of the tape Tape Carrier tape Top tape Material PS PET f.) Label contents Sticks label for every reel. Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 7 g.) Taping dimension Cover-tape Leader Carrier-tape Cover-tape Terminal Carrier-tape Terminal The length of cover-tape in the leader is more than 400 mm including empty embossed area. After all products were packaged, must remain more than twenty pieces or 400 mm empty area, which should be sealed by cover-tape. The tip of cover-tape shall be fixed temporary by paper tape and roll around the core of reel one round. The empty embossed area which are sealed by top cover-tape must remain more the 40 mm. Components Leader Emptv compartments Emptv compartments Top cover-tape Embossed Carrier-tape h.) Joint of tape The carrier-tape and top cover-tape should not be jointed. i.) Release strength of cover tape It has to between 0.1N to 0.7N under following condition. Pulling direction 165° to 180° Speed 300mm/min. Otherwise unless specified. 165°~ 180° Pulling direction Other standards shall be based on JIS C 0806-1990. Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 8 j.) Package Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 9 5. Mechanical Endurance: Provided that measurement shall be carried out after it alone in the room temperature for 1 hour. Specifications Item Test Methods Code 1 Drop 2 Vibration 3 Substrate Bending 4 Adhesion 5 Body strength Should be satisfied after dropping three times from the height of 50 cm onto hard wooden board of thickness more than 30mm. Should be satisfied after supplying following vibration. (1)Vibration Frequency: 10~55Hz (2)Cycle: 1 to 2 Min. (3)Amplitude: 0.8mm (4)Direction: X.Y.Z (5)Time: 2 Hours / Each Direction Mount the specimen on substrate. Apply the following pressure Direction: see Fig –1 Speed: 0.5 mm/sec Hours: 5 ± 1 sec Amount of substrate: 3 mm Max. Mount the specimen on substrate. Apply the following pressure Direction: see Fig –2 Weight: 5N Hours: 10 ± 1 sec Mount the specimen on substrate. Apply the following pressure Direction: see Fig –3 Weight: 10N Hours: 10 ± 1 sec A A C L >= W Pressure jig P.C.B. R 0.5 W L Pressure jig Pressure jig P.C.B. specimen R 230 R 0.5 specim en 45±2 45±2 0.5L L Fig-1 Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Fig-3 Fig-2 Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 10 6 Seal 7 Solder ability Less than 1.0 x 10-8 Pa.m3/sec by Helium leak detector. Also, no serial bubble is observed by Fluorinate tests. --- 3sec +/-0.5sec. Dip in 245deg.C+/-5deg.C solder. (Use ROSIN type flux for solder.) B Run in reflow Reflow soldering shall be allowed Only two (2) time. Available for Lead Free Soldering 8 Resistance to Soldering Heat Temperature 260 deg.C 220 deg.C A (3) 160~180deg.C (2) (1) Time (1) Preheat 160~180 deg.C 120sec. (2) Primary heat 220 deg.C 60sec. (3) Peak 260 deg.C 10sec. Max. Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 11 6. Environmental Endurance: Provided that measurement shall be carried out after letting it alone in the room temperature for 1 hour. Item Should be satisfied after letting it alone at +60deg.C+/-2deg.C in humidity of 90% ~ 95% for 240 hours. A A 1 Humidity 2 Storage in Low Temperature Should be satisfied after letting it alone at –40deg.C+/-2deg.C for 240 hours. 3 Storage in High Temperature Should be satisfied after letting it alone at +85deg.C+/-2deg.C for 240 hours. Thermal Shock Should be satisfied after supplying the following temperature cycle (25 cycles). (Refer to Fig-4). Temperature increasing or reducing time within 3 minutes. 4 Specifications Code Test Methods A A 85+/-2℃ 30 min (Fig-4) 25+/-5℃ 2 min 25+/-5℃ 2 min 30min -40+/-2℃ 1 CYCLES Specifications code A B C Specifications Frequency variation shall be within +/-5ppm and equivalent resistance shall be within the specification after the test More than 90% of lead shall be covered by new solder. Without mechanical damage such as breaks. Without electrode peeling. Electrical characteristics shall be satisfied. Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 12 7. Flow Chart CAP(外 殼 蓋 ) BLANK(晶 片 ) CAP進 料 檢 查 1 Incoming Inspection of CAP BASE(基 座 ) BLANK進 料 檢 查 3 4 5 6 BASE進 料 檢 查 Incoming Inspection of BLANK 2 Incoming Inspection of BASE 化學蝕刻 Etching 頻率選別 Freq. Sorting 蒸著前洗淨 Cleaning before Base Plating 7 微蝕刻 8 基礎蒸著 Flash Etching Base Plating 9 押入接著 10 接著硬化 11 12 13 14 Blank Ass'y Adhesive Curing 接著檢查 Bonding Check 調整蒸著 Partial Adjustment 中 間 檢 查 ($) Middle Check 高真空烘烤 High Vacuum Annealing 15 封 止 Sealing 16 強 力 振 Over Drive 17 REFLOW 18 老 化 Aging 19 印 字 +外 觀 檢 查 22 氣 密 檢 查 II(HE) 23 最 終 檢 查 ($) 24 TAPING 25 Taping外 觀 檢 查 26 出貨檢查 Leak Check II Final Check Check of Taping Marking&Check 20 21 ($): 特 殊 特 性 (For Special Characteristics) *Remark: 此 流 程 不 適 用 SMD3225 及其以下小型化之產品 (The process couldn't be available for SMD3225 and the smaller PKG.) 氣 密 檢 查 I (AIR) Leak Check I 氣 密 檢 查 II(氦 氣 加 壓 ) Leak Check II (Helium Pressurization) QUARTZ CRYSTAL SPECIFICATION Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY 出貨捆包 Packing to Shipment/stock 出 貨 Shipment Tittle HSX530G Date 27 Outgoing Inspection Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 13 8. Environmental Workload Chemical Substance Components List Environmental Workload Chemical Substance Components List TYPE H(D)SX530G PERCENTAGE 47(mg) ppm Silicon(Si) 0.21150 99.4050 Gold(Au) 0.06110 28.7170 Fluorinre(F) 0.98700 463.8900 Titanium(Ti) 0.22560 106.0320 Boron(B) 0.06110 28.7170 Cobalt and its compound(Co) 0.04042 18.9974 Lead(Pb) 3.40280 1599.3160 Bismuth(Bi) 0.23500 110.4500 Silver(Ag) 0.08930 41.9710 Chromium and its compound(Cr) 0.07520 35.3440 Zinc(Zn) 0.68620 322.5140 21.14530 9938.2910 Manganese and its compound(Mn) 0.22090 103.8230 Wolfram and its compound(W) 0.24910 117.0770 Nickel and its compound(Ni) 0.17390 81.7330 Iron(Fe) 1.82830 859.3010 Chemical Substance Components Aluminum(Al) Tittle HSX530G QUARTZ CRYSTAL SPECIFICATION Date Confirm 2012/03/14 F. S. TSAI Check Prepare C. L. WANG U. F. CHEN HARMONY Country of origin TAIWAN FACTORY THAILAND FACTORY SHENZHEN FACTORY Spec. No. Rev. Page X5H015360FK1H-X ELECTRONICS CORP. 0 14
