OCETCLJANF-25.000000MHZ 数据手册
OC Type
7.0 x 5.0 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.3 mm ceramic SMD package.
- Output frequency up to 166MHz
- Tri-state enable/disable.
TYPICAL APPLICATION
- xDSL, WLAN, Fiber/10G-Bit Ethernet
- Notebook, PDA
- PC main board, VGA card
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ BOTTOM VIEW ]
[ TOP VIEW ]
5.08±0.20
5.00±0.20
#1
#2
1.40±0.20
#2
1.30±0.20
[ SIDE VIEW ]
Pin#
1
2
3
4
5.08
#4
#1
0.1µF
4.00
#3
2.00
#3
3.70±0.20
#4
1.10±0.20
7.00±0.20
Function
Tri-State
GND
Output
VDD
1.80
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
2.5V
Max.
Min.
1.8V
Max.
Supply Voltage Variation(VDD)
VDD -10% VDD+10% VDD -10% VDD+10% VDD -10% VDD+10%
Frequency Range
0.0137
166
0.0137
133
0.0137
125
Standard Frequency
2.048, 25, 26, 27, 50, 66, 667, 100, 125
Supply Current
_
_
_
1
13.7 kHz
Fo 70 kHz
1
1
_
_
_
10
0.3125 MHz
Fo < 35.328 MHz (A1)
7
8
_
_
_
30 MHz
Fo < 75 MHz
15
18
_
_
_
35
75 MHz
Fo < 133 MHz
25
30
_
_
_
_
45
133 MHz
Fo
40
_
_
_
2.97
2.25
1.62
Output Level (CMOS) Output High (Logic “1”)
_
_
_
Output Low (Logic “0”)
0.33
0.25
0.18
Transition Time:Rise/Fall Time
_
_
_
13.7 kHz
Fo 70 kHz
50
50
50
_
_
_
0.3125 MHz
Fo < 100 MHz
5
5
5
_
_
_
100 MHz
Fo
3
3
3
_
_
_
5
5
Start Time
5
_
_
_
15
Output Drive Capability (CL)
15
15
_
_
_
Tri-State (Input to Pin1) Enable (High voltage or floating)
2.31
1.75
1.26
_
_
_
Disable (Low voltage or GND)
0.99
0.75
0.54
_
_
_
Period Jitter(Pk-Pk)
40
40
40
_
_
_
RMS Phase Jitter (Integrated 12 kHz~20 MHz)
1
1
1
_
_
Standby Current
10
10
10
_
_
_
Aging (@ 25°C 1st year)
±3
±3
±3
Storage Temp. Range
-55
125
-55
125
-55
125
Min.
Max.
Min.
unit
V
MHz
mA
V
nSec
mSec
pF
V
pSec
pSec
µA
ppm
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15pF.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
-10 ~ +60
-20 ~ +70
-40 ~ +85
±20
±25
±50
○: Available △:Conditional X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
-40 ~ +125
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(32)08/2019
37
OCETCLJANF-25.000000MHZ 价格&库存
很抱歉,暂时无法提供与“OCETCLJANF-25.000000MHZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.74120
- 10+3.87720
- 30+3.44520
- 100+3.01320
- 500+2.45160
