2R5AREC821M0609
2R5AREC821M0609
    APAQ(钰邦)
    插件,D6.3xL8mm
    贴片铝电解电容 AEC_D6.3X8MM_TM
2R5AREC821M0609 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor AREC Series High Current   Super low ESR, High ripple current capability Rated voltage:2.5~16Vdc    Endurance 2000hrs at 105℃ Suitable for DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Category Temperature Range -55 to 105℃ Rated Capacitance Range 270 to 2200 (μF) Rated Voltage Range 2.5 to 16Vdc Capacitance Tolerance ±20% (M) Surge Voltage Rated voltage X 1.15 (at 105°C) Dissipation Factor Leakage Current Shall not exceed values shown in standard ratings. 0.1 max. (at 20°C 120Hz) (at 20°C after 2 mins.) 105℃, 2000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, no voltage applied Appearance No significant damage Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Series Polarity Date code Date code Capacitance marking (-) Voltage Product Specifications are subject to change without notice. SIZE Code øD±0.5 max 06X8 08X8 08A2 10A2 6.3 8.0 8.0 10.0 L α ød± 0.05 F±0.4 8.0 8.0 11.5 11.5 1.0 1.0 1.5 1.5 0.6 0.6 0.6 0.6 2.5 3.5 3.5 5.0 AP-CON Aluminum Solid Electrolytic Capacitor AREC Series High Current Standard Ratings ESR WV/Vdc (SV) 2.5 (2.9) 4 (4.6) 6.3 (7.2) 16 (18.4) Rated Ripple Current (mArms/ 105℃ /100kHz) Part No. 5,000 6,100 5,000 6,100 6,100 6,100 6,100 6,640 6,640 6,100 6,100 4,700 5,700 4,700 5,700 4,700 5,700 6,640 6,640 2R5AREC561M06X8 2R5AREC561M08X8 2R5AREC821M06X8 2R5AREC821M08X8 2R5AREC102M08X8 2R5AREC122M08X8 2R5AREC152M08A2 2R5AREC152M10A2 2R5AREC152M10A2 4R0AREC561M08X8 4R0AREC122M08X8 6R3AREC471M06X8 6R3AREC471M08X8 6R3AREC561M06X8 6R3AREC561M08X8 6R3AREC821M06X8 6R3AREC821M08X8 6R3AREC102M10A2 6R3AREC152M10A2 Cap (μF) Size Code Leakage Current (μA) 560 560 820 820 1000 1200 1500 1500 2200 560 1200 470 470 560 560 820 820 1000 1500 06X8 08X8 06X8 08X8 08X8 08X8 08A2 10A2 10A2 08X8 08X8 06X8 08X8 06X8 08X8 06X8 08X8 10A2 10A2 500 500 500 500 500 600 750 750 1,100 500 960 592 592 705 705 1,033 1,033 1,260 1,890 (mΩmax/20 %, 100k to300kHz) 7 7 7 7 7 7 7 7 7 7 7 8 8 8 8 8 8 7 7 270 08X8 864 10 5,000 160AREC271M08X8 270 330 470 680 820 08A2 08X8 08A2 10A2 10A2 864 1,056 1,505 2,176 2,624 10 10 10 10 10 5,230 5,000 5,230 6,100 6,100 160AREC271M08A2 160AREC331M08X8 160AREC471M08A2 160AREC681M10A2 160AREC821M10A2 Product Specifications are subject to change without notice.
2R5AREC821M0609 价格&库存
很抱歉,暂时无法提供与“2R5AREC821M0609”相匹配的价格&库存,您可以联系我们找货
2R5AREC821M0609
  • 5+0.91271
  • 50+0.73073
  • 150+0.63969
  • 500+0.55253
  • 2500+0.49788
  • 5000+0.47067
库存:29
