CRYSTAL UNIT
YSX530GA
Glass Sealed
Applications
Features
‧Industrial Control
Consumers.
‧Dimensions:5.00 x 3.20 x 1.20 mm.
‧2 pads SMD glass sealed crystal units.
‧Standard Frequency: 8~54MHz
‧Contains Pb in sealing glass exempted by RoHS directive.
Specifications
Standard Frequency
8~54 MHz
Vibration Mode
AT Fundamental
Load Capacitance
10pF,20pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±20ppm,or specify
-20~+70℃,-40~+85℃,or specify
-55~+125℃ or specify
Storage Temperature
Shunt Capacitance
5 pF Max.
Level of Drive
1~300μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
8 ~ 16MHz
16 ~ 25 MHz
25 ~ 54 MHz
Fundamental
Dimensions and Patterns [unit:mm]
80 Ω Max.
40~60 Ω Max.
30~40 Ω Max.
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX530GA
Glass Sealed
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-5032
180±2.0
12.0±0.3
6.35±0.1
3.85±0.1
8.00±0.3
1.80±0.1
61.0±1.0
12.0±1.0
1000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X50322863636MSB2GI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.09450
- 50+0.84070
- 1000+0.77610
- 国内价格
- 10+3.13270
- 100+1.86870
- 500+1.30810
- 1000+0.93440
- 2000+0.88770
- 10000+0.82220
- 国内价格
- 5+1.85102
- 50+1.46837
- 150+1.30443
- 1000+1.03022
- 2000+0.93906
- 5000+0.88442
