CSM Series
Stackpole Electronics, Inc.
Molded Metal Plate Sensing Resistor
Features:
Resistive Product Solutions
High power metal alloy current sense resistor
Molded package for superior heat dissipation
Typical inductance 0.004Ω - 0.1Ω)
0.252 ± 0.008
6.40 ± 0.20
0.126 ± 0.008
3.20 ± 0.20
0.035 ± 0.008
0.90 ± 0.20
0.028 ± 0.008
0.70 ± 0.20
0.035 ± 0.008
0.90 ± 0.20
inches
mm
Power Derating Curve:
CSM2512
100
80
80
Rated Power(%)
Rated Power(%)
CSM0603
100
60
40
40
155
Ambient Temperature (ºC)
Rev Date: 06/28/2018
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
-55
170
1
www.seielect.com
marketing@seielect.com
CSM Series
Performance Characteristics
Test Items
Test Specifications
Test Condition
Temperature Coefficient of Resistance
CSM2512 ±75 ppm/ºC
CSM0603 ±100ppm/ºC
+25ºC ~ +125ºC
Load Life
±1%
1000 hours at rated power, 70ºC,
1.5 hours ON, 0.5 hours OFF
Short Time Overload
±0.5% (for 0.04 - 0.1Ω >
rated power x 2.5 for 5 seconds
5 X rated power for 5 seconds
Moisture No Load
±0.5%
85ºC, 85% RH, 1000 hours
±0.5%
-55ºC and +155ºC, 300 cycles,
15 minuntes per extreme condition
Resistance to Soldering Heat
±0.5%
260±5ºC for 20±1 seconds
Solderability
At least 95% of surface area of electrode
must be covered with new solder
245±5ºC for 2±0.5 seconds
High Temperature Exposure
±0.5%
170ºC for 1000 hours
Low Temperature Storage
±0.5%
-55ºC for 1000 hours
Temperature Cycle
Substrate Bending
±1%
Bending width 2mm
Insulation Resistance
> 100MΩ
100V DC for 1 minute
Storage Conditions: Temperature 5ºC ~ 35ºC; R.H. 40% ~ 75%.
Recommended Pad Layout
Type / Code
CSM0603
CSM2512
a
b
L
Unit
0.039
1.00
0.157
4.00
0.028
0.70
0.083
2.10
0.035
0.90
0.161
4.10
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSM
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
SMD
YES
100% Matte Sn over Ni
Always
Always
2
www.seielect.com
CSM Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the
eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the
electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and
products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of
Dodd-Frank Act regarding Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free
and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually
strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our
environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms
of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
C
S
M
2
5
1
2
F
T
1
L
Product Series
Description
Molded Metal Plate
CSM
Sensing Resistor
Code
Size
Code Power
0603 0.33W
2512
3W
Tolerance
Code Tol
F
1%
J
5%
Code
T
Packaging
Description
Size
Paper Tape
0603
Emboss
2512
3
Quantity
5,000
4,000
Resistance Value
Four characters with the multiplier
used as the decimal holder.
"L" used as multiplier of 10-3 for any
value under 0.1 ohm
0.001 = 1L00
0.01 = 10L0
0.1 ohm = R100
www.seielect.com
很抱歉,暂时无法提供与“CSM2512FT2L00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.24457
- 50+1.78190
- 150+1.58361
- 500+1.33618
- 2500+1.22602
