100CE22FS
100CE22FS
    SUNCON
    SMD,D8xL10.2mm
    贴片铝电解电容 SMD
100CE22FS 数据手册
Aluminum Electrolytic Type / Surface Mount Type Aluminum Electrolytic Capacitors CE-FS RoHS compliance 105℃ Standard Series ● 105℃, 1,000 to 2,000hrs.   ● Solvent proof (within 2 minutes)   φ18×21.5 ■ Specifications Items Condition Specifications Rated voltage (V) − 6.3 10 16 Surge Voltage (V) Room temperature 8.0 13 20 CE-BJ・BE 25 35 50 63 32 44 63 79 100 125 CE-BD −55 to +105 Category temperature range (℃) − Capacitance tolerance (%) 120Hz/20℃ −40 to +105 CE-BS M : ±20 CE-BSS CE-FE φ4 to φ6.3 0.24 0.20 0.16 0.14 0.12 0.10 0.12 0.10 φ8 to φ18 0.28 0.24 0.20 0.16 0.14 0.12 0.12 0.10 Dissipation Factor(tanδ) 120Hz/20℃ Leakage current(LC) μA/after 2minutes (max) CE-LD When rated capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. CE-FU CE-FS CE-FSS Based the value at ー40℃ Z/Z20℃ 120Hz, +20℃ ー55℃ Z/Z20℃ Test φ4 to φ6.3, φ10 × 7.7 : 1,000hrs., φ8 to φ18 : 2,000hrs. Endurance 105℃ rated voltage applied △C/C Within ±25% of the initial value (With the rated ripple current) tanδ ≤ 2 times the initial specified value LC ≤ The initial specified value CE-FH CE-GA CE-AX The greater value of either 0.01CV or 3 Impedance ratio at low temperature CE-KX CE-LX 3 3 2 2 2 2 2 3 8 5 4 3 3 3 3 − CE-LS CE-LH CE-LL ■ Marking, Dimensions (Unit : mm) CE-PC [φD≤10] CE-NP CE-FN ME-SWB ME-UZ・SZ ME-UAX・SAX ME-SWG ME-LS ME-HC ME-CZ ME-CA ME-CX ME-AX ME-WX ME-WA ME-WL ME-WG ME-PX ME-HPC・HPD ME-FC・FD ME-FAZ ME-FH ME-SWN ME-HWN 36 H±0.2 C±0.2 R P±0.2 +0.1 −0.2 4  5.4   4.3 4.3 5.0 0.5 to 0.8 1.0 4  6.0±0.3 4.3 4.3 5.0 0.5 to 0.8 1.0 Series Symbol 5  5.4   −0.2 +0.1 5.3 5.3 6.0 0.5 to 0.8 1.4 6.3 5.4   −0.2 +0.1 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 6.0±0.3 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 7.7±0.3 6.6 6.6 7.3 0.5 to 0.8 2.2 8  10.2±0.3 8.3 8.3 9.0 0.7 to 1.0 3.2 10  7.7±0.3 10.3 10.3 11.0 1.0 to 1.4 4.6 10  10.2±0.3 10.3 10.3 11.0 1.0 to 1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0 to 1.4 4.6 16  16.5±0.5 16.3 16.3 17.3 1.8 to 2.1 7.0 18  16.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 18  21.5±0.5 19.0 19.0 20.0 1.7 to 2.1 7.0 Rated Voltage(6.3V→6) [φD≥12.5] Polarity (Cathode) Lot No. Indicated φD=16, 18 24T 4700 10 F W±0.2 L Rated Capacitance Lot No. Rated Capacitance Series Symbol Rated Voltage(6.3V→6) L A pressure relief vent is attached to products over φD=8 P 24 470 16 F W R (+) C CE-PF 0.3max H Polarity (Cathode) φD CE-PH D+0.5max Aluminum Electrolytic Type / Surface Mount Type RoHS compliance V μF 6.3 10 16 25 4.7 10  35 4×5.4  13 4×5.4  14 4×5.4  18 5×5.4  20 5×5.4  21 22  4×5.4  22 5×5.4  25 5×5.4  27 6.3×5.4  36 6.3×5.4  38 33  5×5.4  27 5×5.4  30 6.3×5.4  40 6.3×5.4  44 6.3×6.0  42 47  5×5.4  33 6.3×5.4  41 6.3×5.4  48 6.3×6.0  48 6.3×6.0  49 100  6.3×5.4  50 6.3×5.4  53 6.3×5.4  60 6.3×7.7  91 6.3×7.7  84 6.3×6.0  62 6.3×7.7  95 8×10.2 140 8×10.2 155 10×7.7  155 6.3×7.7  105 6.3×7.7  105 8×10.2 175 8×10.2 190 10×7.7  175 8×10.2 220 10×10.2 300 150  6.3×6.0  220  67 Aluminum Electrolytic Capacitors ■ Size List, Rated Ripple Current CE-BJ・BE CE-BD CE-BS 6.3×7.7  330  105 8×10.2 470  210 8×10.2 210 10×7.7  210 1000  8×10.2 230 1500  10×10.2 310 680  8×10.2 8×10.2 210 10×7.7  210 195 10×7.7  195 8×10.2 230 10×10.2 310 CE-BSS 10×10.2 300 410 12.5×13.5 430 16×16.5 700 CE-FSS 16×16.5 740 CE-FH 18×16.5 950 18×21.5 1200 CE-LD 12.5×13.5 310 12.5×13.5 460 500 16×16.5 510 805 2700  12.5×13.5 3300  16×16.5 520 840 3900  4700  16×16.5 930 8200  CE-FU 18×16.5 1040 18×21.5 1280 CE-GA CE-AX CE-KX CE-LX 16×16.5 880 18×16.5 1150 CE-LH 18×21.5 1350 CE-LL 5600  6800  CE-FE 12.5×13.5 CE-FS 10×10.2 12.5×13.5 2200  8×10.2 195 18×16.5 1090 18×21.5 1300 CE-LS 10000  18×16.5 1200 CE-PC 12000  18×21.5 1350 CE-PH CE-PF V μF 50 63 100 CE-NP 0.47 4×5.4  3.5 4×5.4  3.5 1.0  4×5.4  7.0 4×5.4  7.0 4×6.0  7.0 2.2  4×5.4  11  4×5.4  11  6.3×6.0  14  3.3  4×5.4  13  5×5.4  14  6.3×6.0  20  4.7  5×5.4  16  5×5.4  16  6.3×6.0  25  CE-FN ME-SWB ME-UZ・SZ ME-UAX・SAX 10   6.3×5.4  24  6.3×5.4  24  6.3×7.7  35  ME-SWG 22   6.3×6.0  42  6.3×7.7  49  8×10.2 84  ME-LS 33   6.3×7.7  60  8×10.2 112  10×10.2 133  ME-HC 47   6.3×7.7  63  8×10.2 119  12.5×13.5 240  ME-CZ 8×10.2 126  12.5×13.5 245  ME-CA 10×10.2 196  16×16.5 490  16×16.5 500  18×16.5 650  18×21.5 700  68   82   10×7.7  140  100   8×10.2 140  ME-CX 150   220   10×10.2 220  330   12.5×13.5 365  390   12.5×13.5 380  470   680   1000   16×16.5 655  1500   18×21.5 1100  Please refer to page 15 for the ripple current frequency coefficient. 12.5×13.5 287  ME-AX ME-WX ME-WA ME-WL 16×16.5 630  ME-WG 18×16.5 750  ME-PX 18×21.5 900  ME-HPC・HPD ME-FC・FD Case size:φDxL(mm) 10×7.7:CE-FSA φ16, φ18:CE-FST ME-FAZ Rated ripple current mArms(120Hz, 105℃) ME-FH ME-SWN ME-HWN ■ Model No. FS FSA 16 CE 470 FS FST 10 CE 470 FSA Series code Rated capacitance code Type code Rated voltage Series code Rated capacitance code Type code Rated voltage 10 CE 4700 FS T Sn plating terminal code Series code Rated capacitance code Type code Rated voltage 37
100CE22FS 价格&库存
很抱歉,暂时无法提供与“100CE22FS”相匹配的价格&库存,您可以联系我们找货
