HMC0805JT50M0
HMC0805JT50M0
    SEI
    贴片电阻 0805
HMC0805JT50M0 数据手册
Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Features: • • • • • • R Value extension of RMCF product Highly stable performance over time Power derating from 100% at 70ºC to zero at 125ºC E12 and E24 values Nickel barrier terminations RoHS compliant and halogen-free Electrical Specifications Type/Code HMC0402 Power Rating (Watts) @ 70ºC Maximum Working Voltage 0.063W (1) 50V Maximum Overload Voltage 100V Resistance Temperature Coefficient 1% ±200 ppm/ºC 11M - 20M 0.1W 50V 100V HMC1206 0.125W 0.25W 150V 200V 400V HMC1210 0.33W 200V 400V HMC2010 0.75W 200V 400V HMC2512 1W 250V 500V 22M - 100M ±400 ppm/ºC 300V 10% - 11M - 20M ±500 ppm/ºC - ±200 ppm/ºC 11M - 20M 110M - 1G 22M - 100M ±400 ppm/ºC HMC0805 5% 22M - 100M ±400 ppm/ºC ±200 ppm/ºC HMC0603 Ohmic Range (Ω) and Tolerance ±500 ppm/ºC - ±1000 ppm/ºC - 110M - 500M 510M - 1G ±1500 ppm/ºC - 1.2G - 10G ±200 ppm/ºC 11M - 20M - ±400 ppm/ºC 22M - 100M 30M - 100M 110M - 500M ±500 ppm/ºC - ±1000 ppm/ºC - 510M - 1G ±1500 ppm/ºC - 1.2G - 10G ±200 ppm/ºC 11M - 20M ±400 ppm/ºC - 11M - 20M 22M - 100M ±200 ppm/ºC 11M - 20M ±400 ppm/ºC 22M - 100M ±200 ppm/ºC 11M - 20M ±400 ppm/ºC 22M - 100M (1) Lesser of √PR or maximum working voltage. Performance Characteristics Test Test Condition (JIS C 5202) Test Result Long Term Stability Nominal temperature & humidity for 1,000 hrs. ± 0.5% High Temperature Loading 15VDC, 1.5 hr. ON, 0.5 hr. OFF, 1,000 hrs. 70ºC ± 3% Resistance to Solder Heat 260ºC ± 5ºC, 10 seconds +1/-0 ± 1% Short Time Overload 5 seconds at maximum overload voltage ± 2% Voltage Coefficient of Resistance Per JIS C 5202 ± 0.5%/V Operating Temperature Range: -55ºC to +125ºC Rev Date: 08/20/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Mechanical Specifications Type/Code L Body Length W Body Width H Body Height a Top Termination b Bottom Termination Unit HMC0402 0.039 ± 0.002 1.00 ± 0.05 0.020 ± 0.002 0.50 ± 0.05 0.014 ± 0.002 0.35 ± 0.05 0.008 ± 0.004 0.20 ± 0.10 0.008 ± 0.004 0.20 ± 0.10 inches mm HMC0603 0.063 ± 0.004 1.60 ± 0.10 0.031 ± 0.004 0.80 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.012 ± 0.008 0.30 ± 0.20 inches mm HMC0805 0.079 ± 0.008 2.00 ± 0.20 0.049 ± 0.004 1.25 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.016 ± 0.008 0.40 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 inches mm HMC1206 0.122 ± 0.006 3.10 ± 0.15 0.061 ± 0.004 1.55 ± 0.10 0.022 ± 0.006 0.55 ± 0.15 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC1210 0.126 ± 0.008 3.20 ± 0.20 0.102 ± 0.006 2.60 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC2010 0.197 ± 0.008 5.00 ± 0.20 0.098 ± 0.006 2.50 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm HMC2512 0.250 ± 0.008 6.35 ± 0.20 0.126 ± 0.006 3.20 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.024 ± 0.010 0.60 ± 0.25 0.020 ± 0.008 0.50 ± 0.20 inches mm Recommended Pad Layouts Type/Code HMC0402 HMC0603 HMC0805 HMC1206 HMC1210 HMC2010 HMC2512 A B C Unit 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.079 2.00 0.150 3.80 0.193 4.90 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.035 0.90 0.035 0.90 0.063 1.60 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm Rev Date: 08/20/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 40 20 0 -60 125ºC 0 20 40 60 80 100 120 140 Ambient Temperature (ºC) RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) HMC High Value Thick Film Surface Mount Chip Resistor SMD YES(1) 100% Matte Sn over Ni Jan-04 04/01 Note (1): RoHS Compliant by means of exemption 7c-I. “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 08/20/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. HMC Series Resistive Product Solutions High Value Thick Film Chip Resistor Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 H M C 0 8 0 5 F T 4 7 M 0 Product Series Code Description High Value HMC Thick Film Code 0402 0603 0805 1206 1210 2010 2512 Size Power 0.063W 0.1W 0.125W 0.25W 0.33W 0.75W 1W Tolerance Code Tol Value F 1% E24 J 5% K 10% Rev Date: 08/20/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Code T 4 Packaging Description Size 0402 7" Reel 0603, 0805 Paper Tape 1206, 1210 7" Reel 2010 2512 Plastic Tape Resistance Value Quantity 10,000 5,000 4,000 Four characters with the multiplier used as the decimal holder. 30 Mohm = 30M0 100 Mohm = 100M 1.2 Gohm = 1G20 www.seielect.com marketing@seielect.com
HMC0805JT50M0
物料型号:TPS54360 器件简介:TPS54360是一款同步降压DC-DC转换器,具有高达4.5A的输出电流能力,适用于多种应用,包括便携式设备、电池供电设备和汽车系统。
引脚分配:1-VIN, 2-EN/UVLO, 3-FB, 4-GND, 5-SW, 6-VOUT, 7-LX, 8-HX 参数特性:输入电压范围为4.5V至38V,输出电压范围为0.8V至38V,开关频率高达700kHz,支持高达4.5A的连续输出电流。
功能详解:具有可编程的软启动、输出电压跟踪、输出电压设置、过流保护、过热保护和欠压锁定。
应用信息:适用于需要高效率、高电流输出的电源管理应用,如USB电源、便携式充电器、LED照明和工业控制系统。
封装信息:提供多种封装选项,包括QFN和D2PAK。
HMC0805JT50M0 价格&库存
很抱歉,暂时无法提供与“HMC0805JT50M0”相匹配的价格&库存,您可以联系我们找货
HMC0805JT50M0
  • 1+3.804521+0.48836
  • 10+2.1213410+0.27230
  • 25+1.7496525+0.22459
  • 50+1.5378450+0.19740
  • 100+1.36984100+0.17584
  • 250+1.19945250+0.15397
  • 500+1.10135500+0.14137
  • 1000+1.023491000+0.13138
库存:11399
HMC0805JT50M0
  • 5000+0.898635000+0.11535
  • 10000+0.8622010000+0.11068
  • 15000+0.8444215000+0.10840
  • 25000+0.8251625000+0.10592
  • 35000+0.8141335000+0.10451
  • 50000+0.8036950000+0.10317
库存:11399
