Aluminum Electrolytic Type / Surface Mount Type
Capacitors
CE-FS
RoHS compliance
105℃ Standard
Series
● 105℃, 1,000 to 2,000hrs.
● Solvent proof (within 2 minutes)
φ18×21.5
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
6.3
10
16
Surge Voltage
(V)
Room temperature
8.0
13
CE-BJ・BE
25
35
50
63
32
44
63
79
100
125
CE-BD
−55 to +105
Category temperature range (℃)
Capacitance tolerance (%)
120Hz/20℃
−40 to +105
CE-BS
M : ±20
CE-BSS
CE-FE
φ4 to φ6.3
0.24
0.20
0.16
0.14
0.12
0.10
0.12
0.10
φ8 to φ18
0.28
0.24
0.20
0.16
0.14
0.12
0.12
0.10
Dissipation Factor(tanδ)
120Hz/20℃
Leakage current(LC)
μA/after 2minutes (max)
CE-LD
When rated capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
CE-FU
CE-FS
CE-FSS
Based the value at ー40℃ Z/Z20℃
120Hz, +20℃ ー55℃ Z/Z20℃
Test
φ4 to φ6.3, φ10 × 7.7 : 1,000hrs., φ8 to φ18 : 2,000hrs.
Endurance
105℃
rated voltage applied
△C/C
Within ±25% of the initial value
(With the rated
ripple current)
tanδ
≤ 2 times the initial specified value
LC
≤ The initial specified value
CE-FH
CE-GA
CE-AX
The greater value of either 0.01CV or 3
Impedance ratio at
low temperature
CE-KX
CE-LX
3
3
2
2
2
2
2
3
8
5
4
3
3
3
3
CE-LS
CE-LH
CE-LL
■ Marking, Dimensions
(Unit : mm)
CE-PC
[φD≤10]
CE-NP
CE-FN
ME-SWB
ME-UZ・SZ
ME-UAX・SAX
ME-SWG
ME-LS
ME-HC
ME-CZ
ME-CA
ME-CX
ME-AX
ME-WX
ME-WA
ME-WL
ME-WG
ME-PX
ME-HPC・HPD
ME-FC・FD
ME-FAZ
ME-FH
ME-SWN
ME-HWN
36
H±0.2
C±0.2
R
P±0.2
+0.1
−0.2
4
5.4
4.3
4.3
5.0
0.5 to 0.8
1.0
4
6.0±0.3
4.3
4.3
5.0
0.5 to 0.8
1.0
Series Symbol
5
5.4
−0.2
+0.1
5.3
5.3
6.0
0.5 to 0.8
1.4
6.3
5.4
−0.2
+0.1
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
6.0±0.3
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
7.7±0.3
6.6
6.6
7.3
0.5 to 0.8
2.2
8
10.2±0.3
8.3
8.3
9.0
0.7 to 1.0
3.2
10
7.7±0.3
10.3
10.3
11.0
1.0 to 1.4
4.6
10
10.2±0.3
10.3
10.3
11.0
1.0 to 1.4
4.6
12.5
13.5±0.5
12.8
12.8
13.5
1.0 to 1.4
4.6
16
16.5±0.5
16.3
16.3
17.3
1.8 to 2.1
7.0
18
16.5±1.0
19.0
19.0
20.0
1.7 to 2.1
7.0
18
21.5±0.5
19.0
19.0
20.0
1.7 to 2.1
7.0
Rated Voltage(6.3V→6)
[φD≥12.5]
Polarity
(Cathode) Lot No.
Indicated φD=16, 18
24T
4700
10 F
W±0.2
L
Rated Capacitance
Lot No.
Rated Capacitance
Series Symbol
L
A pressure relief vent is attached to
products over φD=8
P
24
470
16 F
W
R (+)
C
CE-PF
0.3max
H
Polarity
(Cathode)
φD
CE-PH
D+0.5max
RoHS compliance
V
μF
6.3
10
16
25
4.7
10
35
4×5.4
13
4×5.4
14
4×5.4
18
5×5.4
5×5.4
21
22
4×5.4
22
5×5.4
25
5×5.4
27
6.3×5.4
36
6.3×5.4
38
33
5×5.4
27
5×5.4
30
6.3×5.4
40
6.3×5.4
44
6.3×6.0
42
47
5×5.4
33
6.3×5.4
41
6.3×5.4
48
6.3×6.0
48
6.3×6.0
49
100
6.3×5.4
50
6.3×5.4
53
6.3×5.4
60
6.3×7.7
91
6.3×7.7
84
6.3×6.0
62
6.3×7.7
95
8×10.2
140
8×10.2
155
10×7.7
155
6.3×7.7
105
6.3×7.7
105
8×10.2
175
8×10.2
190
10×7.7
175
8×10.2
220
10×10.2
300
150
6.3×6.0
220
67
Capacitors
■ Size List, Rated Ripple Current
CE-BJ・BE
CE-BD
CE-BS
6.3×7.7
330
105
8×10.2
470
210
8×10.2
210
10×7.7
210
1000
8×10.2
230
1500
10×10.2
310
680
8×10.2
8×10.2
210
10×7.7
210
195
10×7.7
195
8×10.2
230
10×10.2
310
CE-BSS
10×10.2
300
410
12.5×13.5
430
16×16.5
700
CE-FSS
16×16.5
740
CE-FH
18×16.5
950
18×21.5
1200
CE-LD
12.5×13.5
310
12.5×13.5
460
500
16×16.5
510
805
2700
12.5×13.5
3300
16×16.5
520
840
3900
4700
16×16.5
930
8200
CE-FU
18×16.5
1040
18×21.5
1280
CE-GA
CE-AX
CE-KX
CE-LX
16×16.5
880
18×16.5
1150
CE-LH
18×21.5
1350
CE-LL
5600
6800
CE-FE
12.5×13.5
CE-FS
10×10.2
12.5×13.5
2200
8×10.2
195
18×16.5
1090
18×21.5
1300
CE-LS
10000
18×16.5
1200
CE-PC
12000
18×21.5
1350
CE-PH
CE-PF
V
μF
50
63
100
CE-NP
0.47
4×5.4
3.5
4×5.4
3.5
1.0
4×5.4
7.0
4×5.4
7.0
4×6.0
7.0
2.2
4×5.4
11
4×5.4
11
6.3×6.0
14
3.3
4×5.4
13
5×5.4
14
6.3×6.0
5×5.4
16
5×5.4
16
6.3×6.0
25
CE-FN
ME-SWB
ME-UZ・SZ
ME-UAX・SAX
10
6.3×5.4
24
6.3×5.4
24
6.3×7.7
35
ME-SWG
22
6.3×6.0
42
6.3×7.7
49
8×10.2
84
ME-LS
33
6.3×7.7
60
8×10.2
112
10×10.2
133
ME-HC
47
6.3×7.7
63
8×10.2
119
12.5×13.5
240
ME-CZ
8×10.2
126
12.5×13.5
245
ME-CA
10×10.2
196
16×16.5
490
16×16.5
500
18×16.5
650
18×21.5
700
68
82
10×7.7
140
100
8×10.2
140
ME-CX
150
220
10×10.2
220
330
12.5×13.5
365
390
12.5×13.5
380
470
680
1000
16×16.5
655
1500
18×21.5
1100
Please refer to page 15 for the
ripple current frequency coefficient.
12.5×13.5
287
ME-AX
ME-WX
ME-WA
ME-WL
16×16.5
630
ME-WG
18×16.5
750
ME-PX
18×21.5
900
ME-HPC・HPD
ME-FC・FD
Case size:φDxL(mm)
10×7.7:CE-FSA
φ16, φ18:CE-FST
ME-FAZ
Rated ripple current
mArms(120Hz, 105℃)
ME-FH
ME-SWN
ME-HWN
■ Model No.
FS
FSA
16 CE 470 FS
FST
10 CE 470 FSA
Series code
Rated capacitance code
Type code
Rated voltage
Series code
Type code
Rated voltage
10 CE 4700 FS T
Sn plating terminal code
Series code
Type code
Rated voltage
37
很抱歉,暂时无法提供与“100CE4R7FS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.99501
- 50+0.79802
- 150+0.69952
