O705054MHEA4SI
O705054MHEA4SI
    YXC(扬兴科技)
    SMD7050_4P
    有源晶振 54MHz 2.25V~5.5V-40℃~+85℃
O705054MHEA4SI 数据手册
YSO752ST Features 000 X . 5 X 1 2 XX C Y X . External dimensions: 7.5 x 5.0 x 1.6 mm. . Frequency range: 1MHz ~ 150MHz. .Smallest & Thinest SMD package. .Excellent temperature range, Best Reliability. .Excellent total frequency stability. .Applications: WLAN, Bluetooth, DSC, DSL, IP CAM, SSD,e-books and other IT product. Electrical Specifications Item / Type YSO752ST Output Frequency Range 1~90MHz Supply Voltage Current Consumption ( Max. ) 90~150MHz 1.8V 2.25~5.5V 1.6~3.6V 5.0V 18mA 46mA 48mA 80mA Output Type CMOS Oscillation Mode Fundamental / 3rd Overtone Frequency Tolerance ± 20ppm, ± 25ppm, or specify Output Load 15 pF, or specify Operating Temperature Range - 40 ~ + 85 ℃, or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Vol ( Min. ) 90%Vdd min./10%Vdd max Symmetry 45~55%DT,40/60~60/40%Svm Rise ( Tr ) / Fall ( Tf ) Time 10Max./8 ns Max. Start-up Time 10 ms Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. Phase Noise(Pn) Three State Function -125 Max. dBc/Hz @1khz Enable Voltage 70%Vdd Min. By Low Pressure 30%Vdd Max. Dimensions 引脚功能定义 引脚 .YXC XXXX 1 功能 E/D 定义 三态/无三态 2 GND 接地 3 OUTPUT 输出 4 Vdd 电源电压 6 3 125.000 Units: mm 1/2 YSO752ST ★ PART NUMBER GUIDE 部件号示例 Frequency Stability output Overall (ppm) Quartz Crystal Oscillator Dimensions Frequency Supply voltage (Hz) (V) O 125M 7050 Supply voltage H Frequency tolerance 1.8V D ±20PPM C -20 to 70 ℃ 3.3V E ±25PPM I -40 to 85 ℃ F G 5.0V 3.3Vto5V H ±50PPM F -40 to 105 ℃ A -40 to 125℃ H 2.25Vto5.5V ★ TAPING SPECIFICATION (Unit: mm) φ1.31 Material Operating Temp. Range I S Output Operating temperature E Pin 4 A E A 4.0 YSO 7 52ST=7 .0×5.0 SMD SEAM TYPE e.g. O 7 050125MH EA4 SI A CMOS 编带规格 1.02 12 0° φ13 2.0 C B D OSC-SMD7050 G A F E A B 178±2.0 16.0±0.3 C 8.40±0.15 D 5.80±0.15 E F G 7.88±0.1 1.90±0.1 58.0±1.0 1000 pcs per reel ★ REFLOW SOLDERING PROFILE ★ Test Circuit 回流焊特性 2/2
O705054MHEA4SI 价格&库存
很抱歉,暂时无法提供与“O705054MHEA4SI”相匹配的价格&库存,您可以联系我们找货
