CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PSE25201B-000
REVISION
: A5
PAGE
: 1 OF 4
Sealed Choke Coil PSE25201B type
Features
Low profile 2.5mm x 2.0mm x 1.2mm
Low coil resistance with large currents.
High magnetic shield construction should actualize high resolution for EMC protection.
100% lead (Pb) free meet RoHS standard
Application
Cellular phones, LCD displays, HDDs, DVCs, DSCs, PDAs etc..
Outline Dimensions
W
L
Code
L
Dimensions (mm)
2.0 ± 0.2
W
2.5 ± 0.2
T
1.2 Max.
T
Note
:This graph is in regard to outline dimensions spec. For outer appearance, please refer to actual product.
Recommend Land Pattern Dimensions
The customer shall determine the land dimensions shown below after confirming and safety.
B
A
C
A
2.1
B
0.8
C
2.6
Unit : mm
Nov., 2014
Downloaded from Arrow.com.
CYNTEC CO., LTD.
乾坤科技股份有限公司
DOCUMENT
: PSE25201B-000
REVISION
: A5
PAGE
: 2 OF 4
Specifications
Part Number
PSE25201B-R24MS
PSE25201B-R47MS
PSE25201B-R50MS
PSE25201B-R68MS
PSE25201B-R82MS
PSE25201B-1R0MS
PSE25201B-1R5MS
PSE25201B-2R2MS
PSE25201B-3R3MS
PSE25201B-4R7MS
PSE25201B-6R0MS
PSE25201B-6R8MS
PSE25201B-100MS
PSE25201B-150MS
PSE25201B-220MS
L0
Inductance
( µH )
@ (0A)
Typical
0.24
0.47
0.50
0.68
0.82
1.0
1.5
2.2
3.3
4.7
6.0
6.8
10.0
15.0
22.0
27
31
36
37
63
80
140
190
260
325
360
820
910
Heat Rating Current
DC Amps. Idc ( A )
Saturation Current
DC Amps. Isat ( A )
Maximum
Typical
Maximum
Typical
Maximum
25
29
32
36
42
43
72
90
155
212
288
370
410
984
1,050
3.90
3.70
3.60
3.30
2.70
2.60
2.20
1.85
1.45
1.20
1.10
1.00
0.75
0.60
0.50
3.51
3.33
3.24
2.97
2.43
2.34
1.98
1.75
1.31
1.08
0.99
0.90
0.68
0.54
0.45
5.00
3.90
3.80
2.90
2.73
2.70
2.30
2.15
1.70
1.50
1.35
1.15
0.85
0.63
0.56
4.50
3.50
3.40
2.60
2.46
2.45
2.07
1.95
1.60
1.40
1.25
1.04
0.77
0.56
0.50
Rdc ( mΩ)
:If you require another part number please contact with us.
**:Inductance Tolerance ± 20%
Note 1.: All test data is referenced to 25℃ ambient.
Note 2.: Test Condition:1MHz, 1.0Vrms
: Idc : DC current (A) that will cause an approximate △T of 40℃
Note 4.: Isat : DC current (A) that will cause L0 to drop approximately 30%
Note 5.: Operating Temperature Range -55℃ to + 125℃
Note 6.: The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating.
Note 3.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling
provision all affect the part temperature. Part temperature should be verified in the end application.
Note 7.
: The rated current as listed is either the saturation current or the heating current depending on which
value is lower.
Nov., 2014
CYNTEC CO., LTD.
乾坤科技股份有限公司
REVISION
: A5
PAGE
: 3 OF 4
100
80
0.20
60
INDUCTANCE(µH)
TEMP.RISE( )
40
0.10
0.00
3.0
4.0
5.0
6.0
0.27
TEMP RISE ( )
0.5
1.0
1.5
2.0
0.84
80
0.70
60
0.3
INDUCTANCE(µH)
40
0.0
INDUCTANCE(µH)
100
TEMP RISE( )
INDUCTANCE(µH)
0.4
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
INDUCTANCE(µH)
0.28
TEMP RISE( )
80
1.0
40
0.0
INDUCTANCE(µH)
TEMP RISE ( )
2.0
2.4
2.8
3.2
3.6
1.0
1.5
80
1.2
60
0.9
40
INDUCTANCE(µH)
0.0
1.6
2.0
DC BIAS(Amps)
3.5
4.0
4.5
2.4
2.8
3.2
100
80
60
INDUCTANCE(µH)
0.6
TEMP RISE (
0.4
40
0.8
1.2
1.6 2.0 2.4
DC BIAS(Amps)
2.8
3.2
3.6
4.0
PSE25201B-2R2MS
100
2.25
INDUCTANCE(µH)
1.5
0.8
3.0
0.8
2.70
TEMP RISE( )
INDUCTANCE(µH)
100
0.4
2.5
PSE25201B-1R0MS
0.0
PSE25201B-1R5MS
0.0
2.0
0.0
4.0
1.8
TEMP RISE (
DC BIAS(Amps)
0.6
40
0.14
1.2
INDUCTANCE(µH)
1.2
100
60
0.42
100
60
0.8
5.0
80
0.0
TEMP RISE( )
INDUCTANCE(µH)
0.6
0.4
4.5
DC BIAS(Amps)
0.8
0.0
4.0
0.56
5.5
PSE25201B-R82MS
0.4
3.5
PSE25201B-R68MS
DC BIAS(Amps)
1.0
3.0
0.00
2.5
DC BIAS(Amps)
0.5
TEMP RISE (
7.0
PSE25201B-R50MS
0.2
40
0.18
DC BIAS(Amps)
0.6
60
INDUCTANCE(µH)
TEMP RISE( )
2.0
80
0.36
TEMP RISE( )
1.0
0.45
0.00
100
80
1.80
60
1.35
INDUCTANCE(µH)
0.90
TEMP.RISE( )
40
TEMP RISE( )
0.15
INDUCTANCE(µH)
0.25
PSE25201B-R47MS
0.54
TEMP RISE( )
PSE25201B-R24MS
0.30
INDUCTANCE(µH)
: PSE25201B-000
Current Characteristic
TEMP RISE( )
DOCUMENT
0.0
0.3
0.6
0.9
1.2
1.5
1.8
2.1
2.4
2.7
DC BIAS(Amps)
Nov., 2014
60
INDUCTANCE(µH)
2.1
TEMP RISE ( )
40
1.4
INDUCTANCE(µH)
2.8
PAGE
: 4 OF 4
PSE25201B-4R7MS
80
4.0
60
3.2
INDUCTANCE(µH)
2.4
TEMP RISE (
1.6
0.4
0.6
0.8
1.0 1.2 1.4
DC BIAS(Amps)
1.6
1.8
2.0
PSE25201B-6R0MS
7.5
INDUCTANCE(µH)
6.0
100
9.0
80
7.5
60
4.5
INDUCTANCE(µH)
3.0
40
TEMP RISE ( )
1.5
0.2
0.4
0.6
0.8
1.0
1.2
1.4
0.2
0.4
0.6
0.8
1.0
1.2
DC BIAS(Amps)
80
60
INDUCTANCE(µH)
6.0
TEMP RISE ( )
4.0
40
TEMP RISE( )
8.0
0.0
60
4.5
INDUCTANCE(µH)
0.2
0.4
0.6
0.8
1.0
TEMP RISE ( )
0.2
0.4
0.6
0.8
1.0
DC BIAS(Amps)
60
TEMP RISE ( )
PSE25201B-150MS
100
15.0
80
12.0
60
9.0
40
INDUCTANCE(µH)
6.0
TEMP RISE( )
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
40
0.0
TEMP RISE( )
80
20.0
INDUCTANCE(µH)
1.4
100
25.0
10.0
1.2
DC BIAS(Amps)
PSE25201B-220MS
15.0
1.2
DC BIAS(Amps)
30.0
40
3.0
0.0
100
80
18.0
INDUCTANCE(µH)
10.0
1.8
6.0
0.0
100
PSE25201B-100MS
1.6
PSE25201B-6R8MS
DC BIAS(Amps)
12.0
1.4
0.0
1.6
2.2
INDUCTANCE(µH)
0.0
INDUCTANCE(µH)
40
0.8
0.0
INDUCTANCE(µH)
100
4.8
TEMP RISE( )
80
: A5
5.6
TEMP RISE( )
INDUCTANCE(µH)
3.5
REVISION
TEMP RISE( )
100
: PSE25201B-000
TEMP RISE( )
PSE25201B-3R3MS
4.2
DOCUMENT
TEMP RISE( )
CYNTEC CO., LTD.
乾坤科技股份有限公司
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
DC BIAS(Amps)
Nov., 2014
很抱歉,暂时无法提供与“PSE25201B-220MS”相匹配的价格&库存,您可以联系我们找货
